> MazdaSpeed 3 - How-To's
Like Tree20Likes
Closed Thread
 Old 04-13-2011, 03:24 AM   #81
Night Wolf's Avatar
Posts: 894   (View Stats)
Night Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the world
Groans: 38
Originally Posted by WhoKnowsWho View Post
Did all the disassembly this past weekend but the CEL came back after 2 tanks of gas. And the sad thing is, all I have been using is QT for gas for years now so I don't think I can improve the gas I am using. I didn't do a scrub down cleaning though, I sprayed everything with brake cleaner, actuated the valve, and blew compressed air through the pipe. Could the actual mechanical actuator be bad? Or was my cleaning too lazy? Oh yeah, it's an '07 with 86K miles, mostly highway. Maybe I'll have to try the easy off oven cleaner.
I think it's just because of "lazy" cleaning. That carbon is sticking to valve like crazy and just spraying it with brake cleaner won't help much. I actually used brush and some wire to try to take as much out as possible. Did around 2000 miles since cleanup and it's still fine.
2008 Mazdaspeed 3GT
Wiseco pistons || K1 rods || GT3076 at 21 PSI (for now) || Built by Pablo and tuned by Dustin || Steedspeed exhaust mani || TIAL 38mm EWG || Custom dump tube || Grimmspeed EBCS
CP-e safe seals || CP-e 4" TIP || CP-e big maf || CP-e catless DP || CP-e HPFP || CP-e gauge pod with Prosport gauges || COBB FMIC || COBB XLE BPV || COBB STS || COBB AP
Matt Damond OCC || CNT exhaust || BSD || EGR del || DENSO ITV22 || TRZ RMM || TRZ TMM || JBR PMM || JBR shift knob || Stoptech slotted rotors || KONI FSD || ROTA GRID 18 x 8.5
NATOR NJ FTW
Night Wolf is offline
The Following User Says Thank You to Night Wolf For This Useful Post:
Raider (04-13-2011)
 Old 04-13-2011, 03:59 AM   #82
Well, do this. Unplug the top, remove the 4 screws holding the plastic top down. Pill it off. Then you can press down on the plunger. If you get resistance then you need to do a better job. If not, there is blockage after it. Take off the pipe and check that. It is probably on the engine block from egr to the pipe. That is where mine backed up.
Raider is offline
 Old 04-13-2011, 04:43 AM   #83
WhoKnowsWho's Avatar
Posts: 12   (View Stats)
WhoKnowsWho is an unknown quantity at this point
I took the top off when I had the whole assembly out. There wasn't really any resistance when I was pushing the valve down and spraying it. I wouldn't call it smooth as silk but it wasn't hard. And the pipe seemed to be okay after spraying compressed air through it. There was a small pile of carbon deposits in the engine block between the EGR and pipe but compressed air blew most of that out too. I didn't stick a hanger wire into the pipe, I suspect it was more clogged than I thought. Guess I should buy a turbo inlet if I have to do it all again.
WhoKnowsWho is offline
 Old 04-13-2011, 06:05 AM   #84
It should move freely. Any resistance, CEL. Clean it again, but do it in depth this time.
Raider is offline
 Old 04-13-2011, 06:22 AM   #85
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
You really have to make sure that the valve isn't sticking at all before you put it back on. moving it and spraying brake cleaner in there isn't enough.
Did you remove the pipe before spraying compressed air in there? Some people have noted that the pipe has caked up carbon in there and you need to stick a hanger down there to break it up.
GL man!
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline
 Old 04-13-2011, 03:10 PM   #86
GL man!
I did remove the pipe but didn't stick a hanger through it. Well, at least taking it all apart a second time will be much quicker and easier.
 Old 04-18-2011, 03:03 PM   #87
clydesdale29er's Avatar
clydesdale29er will become famous soon enough
Great write up, did this yesterday among other maintenance TLC.
Dont waste your time with brake cleaner, oven cleaner was awesome! squeaky clean now, like brand new.
clydesdale29er is offline
 Old 04-18-2011, 03:31 PM   #88
Great! Since my how-to saved you $430 on a new egr and or helped, please donate a minimum of $10 to the forums. Go to the top of the main page and select donate. Thanks!
Raider is offline
pzr2874 (05-17-2011)
 Old 05-14-2011, 07:53 AM   #89
Mistersix's Avatar
Posts: 2,585   (View Stats)
If you remove the TB is it necessary to replace the thin metal gasket?
Mistersix is offline
 Old 05-14-2011, 03:23 PM   #90
Only if you lose or damage it.
Raider is offline
 Old 05-14-2011, 07:28 PM   #91
Mine came apart beautifully, and I was able to reuse it.
 Old 05-14-2011, 08:26 PM   #92
Cool. If my how to worked, donate $10 to support the forum and go VIP...
Raider is offline
 Old 05-16-2011, 06:37 PM   #93
Mistersix's Avatar
Thanks, yeah mine looked ok and seems to be working fine.
Gonna get some over cleaner and clear up this P0401 code. Thanks for this useful write up.
The Following User Says Thank You to Mistersix For This Useful Post:
 Old 05-17-2011, 07:03 PM   #94
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
^^post back yur results w/oven cleaner por favor
pzr2874 is offline
 Old 05-17-2011, 07:55 PM   #95
Mistersix's Avatar
Very well. However, i won't be getting to that this weekend. Should have it done by the end of the month.
 Old 05-17-2011, 08:28 PM   #96
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
have any of you doing this had success cleaning your throttle body with oven cleaner? since it's off and all.. and mazda wants 70 dorra to do it..
tddvrrn is offline
 Old 05-22-2011, 06:36 PM   #97
Tommy's Avatar
Posts: 2,309   (View Stats)
Tommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the world
Groans: 155
Groaned at 44 Times in 37 Posts
subbing for future use. thanks.
Tommy is offline
 Old 05-24-2011, 01:30 PM   #98
SuperTrooper169's Avatar
Posts: 323   (View Stats)
SuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the world
Groaned at 53 Times in 6 Posts
My two week old (to me) MS6 has shown up with the CEL twice now. The first time it came on two Fridays ago I had it scanned at AutoZone and it was the EGR valve code. The CEL went off the next time I filled the car with gas. I thought maybe it was the gas cap or the gas being below the 1/8th tank level, but last night on the way to the grocery store the CEL came back on. Guess I'm going to have to attemp to give the EGR a cleaning this weekend. Glad I found this thread because it's a stellar DIY so hopefully all goes well and I can report back with a non-existant CEL.
SuperTrooper169 is offline
 Old 05-24-2011, 01:40 PM   #99
Every 4th drive, the CEL will go off.
I have also found a way to check for clogged EGR versus clogged pipe.
Take the 4 screws off the top and remove it, (you might need to remove some electrical connectors) and be careful not to lose the metal gasket. Push down on the plunger for the EGR. See if it sticks at all. Sticky=EGR cleaning too. Hotdog town a hallway, then try cleaning the pipe itself. It might save some time. Not exactly how true this is, but it worked recently for me. pipe was clogged again, EGR was not sticky.
Will edit post #1 with this info.
And for all brownies who have used this how-to and not donated, fuck you, donate.
Raider is offline
karl-hungus (05-24-2011)
 Old 05-24-2011, 07:01 PM   #100
I figured the gas fill up was just pure coincidence. So literally every 4th drive shuts the CEL off? What's the purpose of the CEL then? I mean why would Mazda make it come on but then turn off a few drives later if it's serious enough to throw the CEL in the first place? There's no ill effects driving with the CEL light on until I can around to cleaning the EGR out is there?
 Old 05-24-2011, 07:15 PM   #101
It is not life altering so keep driving. No idea on the process, but it is not major, I guess that is why it goes out. It will come back though.
Raider is offline
 Old 05-25-2011, 10:54 AM   #102
lazn's Avatar
Posts: 138   (View Stats)
lazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond repute
Groaned at 11 Times in 1 Post
Well mine has stayed off for over 10k miles after just switching to good gas and running a bottle of techron through it. (it was on pretty solid before that) I only fill up at Chevron or QuickTrip now.
Far easier than taking it apart.
lazn is offline
 Old 05-25-2011, 11:09 AM   #103
i have noticed it is more apparent in colder temps, too. I have not had any problems with it since colder weather.
Seafoam treatment also have been shown to make the CEL stay off for a while. Bottom line, if the valve is stuck, CEL. If the pipe is clogged, CEL. Clear it out, the problem goes away.
Raider is offline
 Old 05-29-2011, 12:05 AM   #104
Thanks so much for this DIY write up. I tackled this today and was amazed at how clogged my EGR tube was. I could not blow any air through it at all until I let it soak in brake cleaner and ran a few pieces of rag through it with some wire. The EGR valve didn't seem stuck but it was caked with carbon and even had a dead spider chilling on the top of the plunger. The hardest part was getting the hose clamp off the TB inlet which I struggled with for 30 minutes. The bolt at the end of the EGR tube was a bitch too because I could only turn it a fraction of a turn each time due to the tight space, but I finally pulled out the adjustable wrench and made quick work of it. I would have taken more photos but it was a damn dirty job especially once the brake cleaner came out, but here's a few shots from the process.
Nothing like breaking the seal with a new car by pulling a bunch of parts off of it.
Spider power
Lots 'o carbon
jwilson0514 and freakyfrogz like this.
The Following 3 Users Say Thank You to SuperTrooper169 For This Useful Post:
JS + MS3 (05-29-2011), Mistersix (06-17-2011), Speed3eak (07-06-2011)
 Old 05-29-2011, 04:11 AM   #105
Glad you got it worked out. Lol at the spider.
Raider is offline
 Old 05-29-2011, 11:40 AM   #106
RichB's Avatar
I wonder how the spider got in there?
RichB is offline
 Old 05-29-2011, 12:34 PM   #107
There is an opening on the bottom
Raider is offline
 Old 05-29-2011, 12:55 PM   #108
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
Good to see you here ST!
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline
 Old 05-29-2011, 09:20 PM   #109
RichB's Avatar
I thought the system is a closed loop. I guess the spider had to come in from somewhere.
RichB is offline
 Old 05-30-2011, 05:25 PM   #110
jwilson0514's Avatar
Posts: 54   (View Stats)
jwilson0514 has a spectacular aura aboutjwilson0514 has a spectacular aura aboutjwilson0514 has a spectacular aura about
Spider power
Lots 'o carbon
Man i have to do this but im so not looking forward to doing this lol. Im lazy but needs to get done.
jwilson0514 is offline
The Following User Says NO Thank You to jwilson0514 For This Un-useful Post:
deuce_WI (07-06-2011)
 Old 06-01-2011, 11:04 AM   #111
pzr2874's Avatar
Groans: 146
Get a 12pk before u start.
pzr2874 is offline
The Following User Says Thank You to pzr2874 For This Useful Post:
Tommy (06-01-2011)
 Old 06-16-2011, 08:28 PM   #112
radbrad's Avatar
Posts: 538   (View Stats)
Great write up. I will be doing this tomorrow.
07Speed3
radbrad is offline
 Old 06-16-2011, 08:45 PM   #113
Have fun!
Raider is offline
 Old 06-17-2011, 09:32 PM   #114
Mistersix's Avatar
My P0401 code came back today. Its like my car is saying "CLEAN THE FUCKING EGR ALREADY......JEEEEEZZZ!!!".
 Old 06-18-2011, 06:28 AM   #115
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
So why don't you just uncheck the P0401 code in ATR?
Does this not work on the MS6?
cld12pk2go is offline
 Old 06-19-2011, 09:07 AM   #116
Mistersix's Avatar
Didn't know you could do that. I'm having AP issues atm.
 Old 06-19-2011, 10:46 AM   #117
Eth/Meth Junkie
cld12pk2go's Avatar
Your path to WIN in ATR is to click on:
Edit, Advanced Parameters, Toggles (Base), and then unselect P0401.
Mistersix (06-20-2011)
 Old 06-21-2011, 10:10 PM   #118
prenedo's Avatar
Posts: 423   (View Stats)
prenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the world
Great write up man. I was just gonna clean the tube before reading this. My plunger was stuck to the point that it couldn't have been operating (not that this is a bad thing, but I can't have a CEL on when I trade in the car a few months down the road ) I have 85k miles and it was horrible; oil was dripping out of my throttle body (thought it was coolant drops, definately not coolant) and was littering my entire intake tract. Thanks to whoever suggested the oven cleaner, I got some stuff that foams up and cleaned the shit outta this thing and my throttle body. Seafoam up next; she's gotta make it through the summer...
prenedo is offline
 Old 07-06-2011, 12:55 PM   #119
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
I haven't popped this code as of yet, but my question is: Will this help with rough idling even after warm up? I've been idling erratically lately and I'm thinking this is a good place to start. The weather has been hot lately and on the first start of the day, the idle seems to be excessively high as some people mentioned this was a symptom. Thanks in advanced.
AtTheDriveIn is offline
 Old 07-06-2011, 01:47 PM   #120
RichB's Avatar
Nah, this code usually occurs when it is cold outside. To me it sounds like you have a vacuum leak. Check your hoses and maybe you'll find something. The small hose at the top of the BPV is a good place to start.
RichB is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-clean-your-1st-gen-mazdaspeed-3-a-50596/
After refueling, Passat is slow to start and temporarily running roughly : MechanicAdvice This thread Refback 07-28-2015 08:18 AM
Help Needed Please Cold Start issues ? Mazda MPS Owners Club This thread Refback 06-01-2015 01:22 PM
To throw or not to throw CEL - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-05-2015 02:37 AM
I broke the testpipe/downpipe bolts on my 2010 Mazdaspeed 3 last night. Need some advice. : cars This thread Refback 10-25-2014 07:32 PM
Help Needed Please Cold Start issues This thread Refback 06-16-2014 05:44 PM
Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA > Ìàçäà 3 1.6ÀÒ_Ïðè ðàçãîíå îùóùàåòñÿ ïîòåðÿ ìîùíîñòè This thread Refback 08-22-2013 04:05 AM
Ìàçäà 3 1.6ÀÒ_Ïðè ðàçãîíå îùóùàåòñÿ ïîòåðÿ ìîùíîñòè - Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA This thread Refback 08-19-2013 06:00 AM
bastion72 comments on And this, gentlemen, is why EGR valves are literally Hitler. This thread Refback 06-28-2013 06:53 PM
And this, gentlemen, is why EGR valves are literally Hitler. : Justrolledintotheshop This thread Refback 06-27-2013 07:30 AM
EGR valve - 07 MS6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-22-2013 11:14 AM
Advice requested regarding a smoking 2008 CX7 : mazda This thread Refback 01-29-2013 03:15 PM
Check engine light code P0401 (EGR) - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-10-2013 02:58 PM
Mazda3 - Éteint au arrêt. - Mazda 3 Quebec This thread Refback 12-18-2012 02:42 PM
Sprawd? silnika ?wiat?a kod P0401 (EGR) - Mazda3 forum: # 1 Mazda 3 Forum This thread Refback 12-16-2012 09:24 AM
Probleme mazdaspeed3 - Mazda 3 Quebec This thread Refback 12-06-2012 05:27 AM
Cold Start problems on a stock MPS6 This thread Pingback 10-30-2012 11:36 PM
Check engine light code P0401 (EGR) - Mazda3Forums.com This thread Refback 09-03-2012 03:57 PM
EGR valve needs cleaning! - DFW Mazdas This thread Refback 06-14-2012 01:15 PM
AnandTech Forums for Mobile Devices - I want to know more about EGR valve CEL This thread Refback 03-28-2012 09:51 AM
What Did You Do To Your MAZDASPEED3 Today - Page 24 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 03-20-2012 12:25 PM
????? ?????????. ??????? ? ???? ??????. This thread Refback 02-13-2012 12:56 PM
I want to know more about EGR valve CEL - AnandTech Forums This thread Refback 12-07-2011 03:31 PM
Mazda MPS Owners Club • View topic - Help Needed Please Cold Start issues This thread Refback 10-18-2011 05:53 PM
Rough Idle possible EGR? This thread Refback 09-16-2011 08:27 PM
2 issues with my Mazdaspeed 6 - DFW Mazdas This thread Refback 08-21-2011 12:17 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 08-08-2011 10:37 AM
I want to know more about EGR valve CEL - AnandTech Forums This thread Refback 06-07-2011 02:42 PM
EGR Valve.... - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-14-2011 05:02 PM
check engine light on and off...code p0401 - DFW Mazdas This thread Refback 04-01-2011 08:42 PM
hi - AZMC - Arizona Mazda Club This thread Refback 03-18-2011 03:29 PM
mazdaspeed3 egr valve - Zuula Search This thread Refback 04-08-2010 07:05 PM
Mazdaspeed CAI filter- how to clean? red07 MazdaSpeed 3 - Engine, Transmission & Driveline 13 08-15-2012 02:24 PM
how to: clean up oil from your driveway phillyb MazdaSpeed 3 - How-To's 26 11-04-2009 02:06 PM
Page generated in 0.63190 seconds with 37 queries
