> MazdaSpeed 3 - How-To's
 Old 11-15-2011, 02:16 PM   #81
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Originally Posted by broncojd78 View Post
if your pcv is leaking, then you will see air come through the valve cover vent.
if your bpv is leaking, you'll see air come out of there.
those both recirculate.
so if you want to see only if you're losing air out of the system, then you could leave those in place. then, you could address any potential BPV and PCV leaks after.
is that correct?
The BPV recirculates into the intake, which is also under pressure.
I have proven the valve cover vent pressure does not come from the PCV system, as I have opened the drain on my catch can with the intake pressurized and nothing came out (verifies my check valve from @MATT DAMOND seals).
Tapadatass
djuosnteisn (11-28-2011)
 Old 11-15-2011, 02:18 PM   #82
silvapain's Avatar
Groans: 136
What I'd like to do when I have the time is pull the valve cover and do a boost leak test. With the cover off I could better pinpoint where the air is escaping.
Tapadatass
 Old 11-15-2011, 02:22 PM   #83
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
i would imagine that a small amount of air escaping the VC is normal
minor blowby past the rings gets down into crank case, pcv valves are forced shut due to pressurized intake, so air naturally travels up through the valvecover vent since during normal operation it would never be under pressure, only vacuum
i verified this by leaving my valvecover vent in the intake and shooting my dipstick about 30 feet into the air along with half my oil
 Old 11-16-2011, 08:43 AM   #84
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
wait, wait, wait... if you leave the valve cover open and it leaks air, and then the pressure will drop... so how do you tell if you have a boost leak?
it's fun to do bad things
 Old 11-16-2011, 09:44 AM   #85
8.5MS3's Avatar
Groans: 326
the rate of flow out the valvecover is very minimal, half a pound every 3 seconds or so
pressurize the system, listen for hisses and/or spray with soapy water
repeat if pressure drops too low
 Old 11-16-2011, 09:50 AM   #86
DarkPasseng3r's Avatar
Posts: 165   (View Stats)
DarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond repute
Great write up. Will be doing this soon.
DarkPasseng3r is offline   Reply With Quote
 Old 11-16-2011, 10:12 AM   #87
silvapain's Avatar
Groans: 136
I stick my thumb over the valve cover vent when I boost leak test.
Tapadatass
 Old 11-16-2011, 10:20 AM   #88
Groans: 549
Tapadatass
what's the difference between that and just leaving it connected to the TIP?
 Old 11-16-2011, 11:35 AM   #89
8.5MS3's Avatar
Groans: 326
pressure in valvecover/crank slowly creeps up as opposed to being pressurized to whatever your testing at immediately
let it linger too long at too high a pressure and the dipstick will want out tho
The Following 3 Users Say Thank You to 8.5MS3 For This Useful Post:
djuosnteisn (11-28-2011), jack_hammer (11-16-2011), silvapain (11-16-2011)
 Old 11-16-2011, 11:59 AM   #90
bigriver's Avatar
Posts: 1,123   (View Stats)
Gonna try this this weekend as i think i have a leak in my cpe nano intake near the maf. The o-ring is fine but could be the maf housing.
So to clarify, you disconnect pcv hose at the intake and cap off the nipple at the intake? Dont want any oil ejac. = )
And to test bov/bpv you disconnect recirc hose at the bov/bpv and fold the hose over to cap off the hose?
Thanks!
Btw for the 1/4" threaded brass nipple on the 2" pvc cap, i used my 1/2" drill bit to make the hole and screwed in the threaded nipple in the hole. Then applied jb weld at the top. Saved a couple of bucks for the brass nut. Not a big deal. Thanks for a great writeup!
bigriver is offline   Reply With Quote
 Old 11-19-2011, 08:42 AM   #91
event's Avatar
Posts: 521   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
Does anyone else's leak tester invariably blow off the intake tube at around 16-18psi? I can see it start slipping at 16psi and then it violently blows off above that. I need to check my bpv for leaks above 16psi but I can't hold the pressure long enough before it blows off...
***sold*** 06 MS6 Cobb SRI 3.5" ETS TMIC Cobb AP Sure RMM JBR SSP EBay Catless DP Autotech HPFP Magnaflow
2013 Scion FR-S 6MT
1993 Mazda Miata with shocks, springs, fsb, GT2560r, Megasquirt
event is offline   Reply With Quote
 Old 11-19-2011, 09:11 AM   #92
8.5MS3's Avatar
Groans: 326
get a man to tighten shit down?
burtonshredder likes this.
 Old 11-19-2011, 09:46 AM   #93
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
I think without a bead rolled edge, the rubber is just too slippery. I was using a t-bolt clamp and it would still blow off eventually. The intake just wasn't meant for that kind of pressure, so it doesn't have the necessary edge.
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is offline   Reply With Quote
The Following User Says Thank You to Pedal-Force For This Useful Post:
 Old 03-17-2012, 02:56 AM   #94
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Putting all your ghetto leak testers to shame. Food grade 304 stainless with quick connect fitting.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 3 Users Say Thank You to 86AmishMs3 For This Useful Post:
djuosnteisn (03-19-2012), franz (08-27-2012), Mase (12-18-2012)
 Old 03-17-2012, 03:10 AM   #95
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
The Following User Says Thank You to dooderek For This Useful Post:
 Old 03-18-2012, 05:00 PM   #96
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
showoff
 Old 03-18-2012, 06:51 PM   #97
Should've rolled the lip. The only problem with mine was getting it to stay on under boost, since none of the pieces before the turbo are meant to have boost, they aren't rolled.
The Following 2 Users Say Thank You to Pedal-Force For This Useful Post:
86AmishMs3 (03-22-2012), djuosnteisn (03-19-2012)
 Old 03-22-2012, 02:30 AM   #98
86AmishMs3's Avatar
Groans: 338
Too thick of stainless to roll. If i have issues i'll just put a weld a bead all across.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 05-22-2012, 12:46 PM   #99
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Subbed for later.
Pickles Tune in progress
 Old 05-22-2012, 01:14 PM   #100
8.5MS3's Avatar
Groans: 326
Subbed for later.
really? theres a menu option to subscribe to a thread. nub
 Old 06-10-2012, 04:23 PM   #101
m4tic's Avatar
Posts: 4,928   (View Stats)
If you have a Cobb Sri check it... Mine has a nice crack in it. I know pressure doesn't flow through it and I can easily seal it... But still wtf
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 06-20-2012, 01:20 PM   #102
dacrowshadow's Avatar
Posts: 29   (View Stats)
dacrowshadow is a splendid one to beholddacrowshadow is a splendid one to beholddacrowshadow is a splendid one to beholddacrowshadow is a splendid one to beholddacrowshadow is a splendid one to beholddacrowshadow is a splendid one to beholddacrowshadow is a splendid one to behold
I know a stupid question, but I'm just making sure...
Wait but we also need a air compressor correct?
COBB Tuning SF/CORKSPORT Cold Air Box, Cobb Inlet, Cobb Short Shifter, COBB AP (PERM tuned ), Turbo Smart Dual Port Blow Off Valve, Saikou Michi Co. Stage 2 OCC, HKS Hi-Power CatBack Exhaust, Cobb DP, DNP Manifold, TRZ Rear Engine Mount, TopSpeed Passenger Mount, Hotchkis Front & Rear Sway Bars, Eibach Spring W/ Knoi Yellows, CP-E FMIC, CP-E FP, Short Throw Shift plate Kit, GTSpec Front Strut, Front & Rear Lower Tie & Rear V Brace & GTSpec Trunk Reinforcement, Link Reinforcement Panel... More to come!! (Summer Set: BFGoodRich g-Force (245/40) / Enkei RS05 18x8)
dacrowshadow is offline   Reply With Quote
 Old 06-20-2012, 01:40 PM   #103
silvapain's Avatar
Groans: 136
Yes, it is a stupid question, and yes, you need some sort of compressor for this. Im sure something like a bike pump would work, as long as you're willing to pump the fuck out of it.
Tapadatass
 Old 06-20-2012, 01:59 PM   #104
Tapadatass
LOL Thanks. Im also just trying to get my post count up.
 Old 08-27-2012, 01:41 PM   #105
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
I plan on building one of these since I cant track down a leak in my FMIC setup. How did you guys block off the BPV and VC tubes? I am going to measure them and try to find some rubber stoppers, but I wanted to see what you guys used first. My biggest concern is the rubber stoppers blowing out and killing someones cat or something.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
 Old 04-29-2013, 04:45 PM   #106
blackms3_71's Avatar
Posts: 2,250   (View Stats)
i just put this kit together and will be checking for leaks tomorrow, thanks op.
 Old 06-28-2013, 09:23 AM   #107
BrandonRKD's Avatar
Posts: 417   (View Stats)
BrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the world
So everything should be completely sealed when pressurizing the tip using this method? I can blow into it without much pressure at all and hear air coming from behind the intercooler. Also my stock bpv has no rubber seal and air comes out through the square hole on the side.
2006 WWP MS6
Cobb AP, SRI, TIP ▌CP-E HPFP, Safe Seals ▌CS TBE ▌TS BPV ▌Custom FMIC ▌NGK Colder Plugs ▌JBR TIG, EGR Blockoff ▌TB Coolant B/P ▌VTCS Delete ▌H&R Springs
FlowTuned By TiGraySpeed6
BrandonRKD is offline   Reply With Quote
 Old 06-28-2013, 11:28 AM   #108
If u hear air behind the intercooler it could be the ebcs lines but u need to pressurize the system to know and yes stock bpv should have rubber gasket
 Old 02-05-2017, 06:48 AM   #109
Tiner's Avatar
Posts: 116   (View Stats)
Tiner will become famous soon enoughTiner will become famous soon enough
Hi.
If I wanna test the whole system DO I need to take out the oil cap?
Just to avoid pressurising that place.
Thank you.
Enviado desde mi SM-G935F mediante Tapatalk
Tiner is offline   Reply With Quote
 Old 02-10-2017, 04:10 AM   #110
Tiner's Avatar
Originally Posted by Tiner View Post
Hi.
Thank you.
No one?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-find-boost-leak-89918/
Vacuum issues causing the car to not run - 4V Specific - SN95Source.com This thread Refback 02-15-2014 01:44 PM
POST TIME - Circulez... y'a rien à voir !! - Page 1232 - Mazda 3 Quebec This thread Refback 05-16-2013 02:24 PM
1 pinte d'huile pour 200km This thread Refback 01-18-2013 07:22 PM
HOW TO FIND A BOOST LEAK - Page 14 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 11-06-2012 08:55 PM
HOW TO FIND A BOOST LEAK - Page 13 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #46 Pingback 11-02-2012 12:41 PM
Replacing a turbo affect transmission/shifting? - Page 8 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 11-01-2012 07:01 PM
How to Find a Vacuum Leak Haltech Automotive News 0 02-28-2011 05:50 AM
Boost leak? dkspeed MazdaSpeed 3/6 - Turbo Induction 12 06-15-2010 07:54 AM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Boost Leak(need help phantomspeed3 MazdaSpeed 3/6 - Turbo Induction 30 05-21-2009 10:19 AM
Page generated in 0.47780 seconds with 37 queries
