| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Apr 2008 Location: Edgewater, MD
Rep Power: 201 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
(Thread Starter) | Not Ranked : 0 score There are quite a few threads out there claiming this is possible, but none that are easily searchable that describe it very accurately/thoroughly, so I thought I'd steal a couple of Haltech's downpipe install pics for illustration purposes and describe what I found to be the least painful way to replace the front sway bar bushings without dropping the front subframe. Required tools: Ramps, jack + jack stands, or lift Socket wrench w/ 14mm and 10mm sockets Blue thread locker (not strictly required, but it might save you from having to tighten bolts again in three weeks) Suggestions: I kept both 3/8" and 1/2" wrenches handy for this. A 3/8" wrench fits in the accessible area better, but a 1/2" wrench will make it easier to reach the bolts on the front side of the bar (you'll be reaching over it to access them). Use ramps or a four-post lift rather than jack stands. I've found it's easier to button up suspension components with everything loaded. Steps: 1) Jack it up, ramp it up, lift it up, etc. Make sure you have the nose way up in the air. You'll need to be able to scoot past the rear (dogbone) mount area for ease of access. Chock the wheels if necessary. 2) Slide on back past the front subframe. The first thing you want to do is remove the chassis brace and skidplate that protects the fuel lines (all one piece). It's held on by four 14mm bolts and one 10mm bolt. Remove the 10mm bolt (red highlight) first so that the plate isn't hanging from it after you remove the 14s. No sense bending it up too badly. Step 1.jpg This weighs a couple pounds and will fall and hit you in the face once it's free if you don't keep your hand on it. So, y'know, do that. Or don't. It's your face. 3) Now that you have some room to work, get on your back so that you can look toward the front of the car. You should be looking at the back of the engine. If you peek up over the subframe, you should be able to eyeball the steering rack and at least part of the sway bar, depending on how big your head is. It's okay if you can't see it. You just need to reach it. I found the best way to do this was to reach up through the exhaust hangers and then hook my arm toward the outside of the car to reach the two bolts holding each bracket. Use the clearance of the exhaust tunnel to crank the wrench. This is a lot easier than trying to fit the wrench in at a straight north-south angle. Step2.jpg From here, it's as simple (or not) as undoing the four bolts, yanking the brackets, and fitting the new ones. The crossmember is raised where the brackets are anchored, and between those bumps and the shaft collars on the bar itself, you should be able to feel around in there to re-attach the brackets with minimal frustration. If you have small hands, you can also reach your fingers in under the loop in the sway bar from the wheel well to feel around for the front bolt holes. That's easier than trying to angle them in from the back. That's it. Don't forget to reinstall the chassis brace/skidplate. Crack a beer. You're done.
__________________ '08.5 MS3 GT -- Metropolitan Grey www.speedsportlife.com |
| The Following 14 Users Say Thank You to DeadWayt For This Useful Post: | allo80 (02-18-2015), Atticaz (11-15-2015), BackRoads (04-23-2015), DuBz (03-11-2013), friesx100 (07-02-2014), ge3kspd (04-13-2015), jack_hammer (03-11-2013), Jakeypoo (10-16-2016), jasper (08-22-2013), Leila (05-30-2014), mach69 (05-03-2013), mazdaspeeding (03-12-2013), RoadTripSaloonGT (12-23-2018), xtasy (03-11-2013) |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score if you're just doing the bushings, you should be able to get to them from the wheel well. 1) take off wheels 2) disconnect end links 3) reach in and disconnect the bushings caveat: the front bolt on the driver side bushing might require some extra work, extensions, u-joints, etc. and when you put it back together, you have to just up the control arm put a load on the wheels. but, that's just another option.
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | ge3kspd (04-13-2015) |
(Thread Starter) | Not Ranked : 0 score I tried doing it from the wheel wells, but I couldn't get a wrench in at an angle to engage the bolts and have cranking room.
![]() Join Date: May 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Gonna give this a shot tomorrow. Im tired of the clunking. Tried to go in through the wheel well when I replaced the end links but I couldn't find a way to crank the bolts, no room.
__________________ 2008 MS3....Vrroooom, spool, pshhhht! |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
| Not Ranked : 0 score Did it today.......car has 70k miles and I drive it in the winter. I almost gave up with the bolts, took me 3 hours. I think dropping the sub might be better with higher mileage cars. |
| The Following User Says Thank You to stockms3 For This Useful Post: | Tommy (11-28-2014) |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
Sent via stockish Black Mica Pu
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
| The Following User Says Thank You to himurax13 For This Useful Post: | rfinkle2 (04-13-2015) |
![]() Join Date: Sep 2009 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Thanks. I plan on doing this tomorrow, 5/4. Hopefully it will be as easy as you describe. I do own a gen won, FML.
__________________ 2008 Mazdaspeed 3 - True Red Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings Last edited by mach69; 05-03-2013 at 11:33 PM. Reason: Forgot a word |
Groans: 255
| Not Ranked : 0 score Well, its done. After two hours of pissing and moaning. I handicapped myself by working out my shoulders and biceps earlier in the day. The ramps i built helped.
__________________ 2008 Mazdaspeed 3 - True Red Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings |
__________________ '08.5 MS3 GT -- Metropolitan Grey www.speedsportlife.com | |
| Thief! lol
![]() Join Date: Sep 2012 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score Did mine today, took about an hour including lifting the car. Your directions were perfect. The hard part is getting leverage to loosen the bolts. In all, in various ways I used a tall 14 mm, a regular 14 mm and a short extension, in 3/8"s. I used a 14 mm in 1/2" for the brace bolts. I was surprised how loose the sway bar is once the bolts were off. Greased up the new ones and put them in place. That persistent knock is gone.
__________________ 09 SPEED 3 CWP installed: CP-e DP, CP-e FMIC, CP-e CAI, Cp-e TIP, Cp-e S2RMM, Cp-e PSMM, Cp-e DSMM, Cp-e Cat back, HKS SSQV, Steed manifold, DO meth injection with HP Controls controller, Cobb ap, Saiko Michi OCC TWM Short shifter and bushings, Rallysport mud flaps, 5%tint all around, 55 w 8000 k fogs, low and high beams. Led 6000 k switchbacks, Led reverse and turn signals. 18 X 8 45 offset w/245/40's, Raceland Coil overs |
![]() Join Date: Feb 2011 Location: Lancaster, PA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Just did it. Took me about 2 hrs. Had a ratchet with a flex head, which really helped. One of the bolts were stubborn. WD-40 fixed it.
__________________ 07 MS3 with MS CAI. |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Thanks for posting this DeadWayt. Much appreciated. You're a good and decent man. |
![]() Join Date: Nov 2013
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score doing this thursday night on my Gen 1. Replaced PMM with a CP-e hoping that was the clunking. nope. lol |
![]() Join Date: Nov 2010 Location: Austin, TX
| Not Ranked : 0 score Finished up doing this on my Gen1 this morning. Thanks for posting the details on this, DeadWayt. I used a 24" breaker bar (1/2") to back off three of the four front bolts, but the front driver bolt was a serious pain because my breaker wouldn't fit in there. Soaked it in WD-40 and left it overnight. Came right out with a big ratchet the next morning. I replaced the front and rear for good measure.....and my CLUNKING IS GONE! Thank you Jesus. btw, I envy the guys who got this done in under an hour. My rears only took me about 30 min, but the fronts.... |
| The Following User Says Thank You to stewart stewart For This Useful Post: | Leila (05-30-2014) |
![]() Join Date: Jul 2012 Location: Toledo, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,271
| Not Ranked : 0 score I find it easier to drop the subframe, more room to work with on genjuan. I wasn't worried because I already needed an alighnment. Dropping subframe, swapping bushings and putting all back together only took about hour and half tops.
__________________ 07 Mazdaspeed 3 Grand Touring Black Mica (The Summer Daily / Toy) Fanboy Brand Mods: A'PEXi Turbo Timer, Autotech Internals, BNR S3 V1, Bosch 3 Bar MAP, CNT 3" CBE, COBB AP V3, STS, FMIC Piping, Corksport Adjustable Shocks/Struts, CP-E Dash Pod, Safe-Seals, Enkei Evo IX (17x8+38), Exide 51RX Battery, FoMoCo XT-M5-QS, Grimmspeed EBCS, Ground Control Bumpstops, Hankook RS-3 (235/45/17), H&R Springs, Hawk HPS Pads, HTP 51R Battery Tray, JBR 88d RMM, 80d PMM, Shifter Bushings, TIG's, Secondary EGR Delete, 3.5" Aluminum WP, Mudflaps, Kozmic Primary EGR Delete, maisonvi Knob Collection, Damond OCC, NGK LTR7IX-11, Progress RSB, Prosport Boost, Oil Temp, Oil Press, Redline Tuning Hood Struts, SPC Camber Arms, Speed Daddy (Ebay) Catless DP, SP63 MAP Harness, Stratified Guardian Angel, Treadstone TR8, TRZ TMM, TurboXS H-RFL VTA BOV, XS Power V1 Manifold Maisonvi's Inherited Motor Build: ARP L19 Head Studs, Crank Bolt, Cam Bolts, Manley H-Beam Rods, SP63 Wiseco Armor Plated Pistons, New Rice, AKA To be Installed: Autoexe Front Bumper Cover, GT Spec Strut Brace, Wedge Engineering Seat Base, Sparco Speed Bucket Seat, 08 Mazda 6i Hatchback (The Daily MPG Commuter) 93 Mazda B2600i 4wd (The Winter Beater / terMINATOR Parts Hauler) |
![]() Join Date: Nov 2018
Rep Power: 0 ![]() Thanks: 0
thanks again | |
![]() Join Date: Jan 2011 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 180
| Not Ranked : 0 score I'm an asshole and didn't post here when I did mine a few months ago. This was a great help and my little girl hands were able to get in and out without a problem! Thanks!
__________________ Stella: 2008 CBM MS3 GT Done: AWR RMM, Cobb AP, Cobb SF Intake, Cobb TIH, Greddy ti-c Exhaust, JBR SSP & Bushings, Modified/Painted Badges, TWM Big Type R Shifter, Smoked Reflectors/Indicators, Yellow Fogs, Sharkfin Antenna, Enkei FLC-01 Bronze wheels, Corksport TMIC, Corksport BPV Hose and IC Hoses, JBR RCA, SURE SBB Planned: Corksport Catted DP/racepipe, CP-e HPFP |
$350....that's nuts. Having no sway bar connected = lots of SWAY and fully independent suspension. | |
![]() | | #24 | ![]() |
Youre 100% correct. I misspoke. At least one of those bolts on each side is only reachable with a super long ratchet or an air ratchet. I used an air ratchet and I did not torque to spec, just tightened as much as possible and used a lot of silicone grease. | |
![]() | | #25 | ![]() |
![]() | Not Ranked : 0 score
Sway Bar Bushings | SURE Motorsports | |
![]() | | #26 | ![]() |
![]() Join Date: Aug 2013 Location: Alpharetta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score I didnt bother using a torque wrench, best tool i use was http://i.imgur.com/vlk3H0B.jpg. Made it a fuck ton easier and I wouldnt have been able to do it any other way.
__________________ 2008 Mazdaspeed 3 GT - Cobb SRI, HKS BOV, Cobb AP V2, Sure RMM, EBC Front Rotors, Hawk HPS, ROCA PMM, Yokohama YK580, SenSen Rear shocks Planned: Cobb TIP, Autotech HPFP, MattD RMM, Koni Street Shocks/struts |
![]() | | #27 | ![]() |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Two additional observations. Those new bushings need to be liberally greased before installing. Second, if you use aftermarket bushings, the brackets are likely to be wider than stock. The slots will likely not line up with the bolt holes. You will have to either tap the "keeper" rings on the swaybar inward to make room, or widen the slot on the bracket to make it fit. I could not get those rings to move, even hammering on them, and had to modify the JBR bushing brackets. I chose JBR because they have re-greasable zerk futtings to keep things quiet.
![]() | | #28 | ![]() |
![]() Join Date: Jan 2011 Location: Watertown MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,085
| Not Ranked : 0 score Try replacing the end links. I had to do both the bushings and the end links to fix all my clunks. Nice and quiet now.
__________________ //AT INTERNALS //COBB AP // COBB SRI // UR TEST PIPE // FORGE V1// JBR SSP // JBR RSB // KONI YELLOWS // CS SPRINGS // |
| The Following 2 Users Say Thank You to xshigeox For This Useful Post: | license2ill (03-26-2015), ohioan (06-29-2014) |
![]() | | #29 | ![]() |
I'll fix it before I trade it in or sell it. With as many miles as I have on the car (116k), I don't think I'll be tracking it again. Plus Nelson's Ledges road course is closing from what I hear. Thanks guys for the help again. | |
![]() | | #30 | ![]() |
Groans: 111
| Not Ranked : 0 score I just came across this thread... I or the mechanics who worked on my car never dropped, loosened or even touched the subframe. The only scenario they had to drop the subframe is for the gen2 1.6 diesels. It;s indeed a pain both in the ass and balls to change the bushings, it's 30 minutes of frustration and cursing but the subframe stays there. Keep in mind that the second you loosened all the bolts on the sub-frame you may need to re-do the alignment just to be sure. It's not mandatory but recommended even if you draw any marks with the previous position.
![]() | | #31 | ![]() |
![]() Join Date: Sep 2013 Location: Seattle WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score My turn tomorrow... crazy thing is it didn't start to clunk until very recently... I about died when I saw this gap considering most folks had clunk with no visible signs of wear.
__________________ 2007 Mazdaspeed 6 GT 2003 Ford Ranger XLT |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Have fun, im gonna imagine its harder on the speed 6 to do but either way good luck. I finally replaced my rears (easiest thing in the world) cause they started to creak real bad now that its colder.
![]() | | #33 | ![]() |
![]() Join Date: Jun 2013 Location: London, ON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score Tried my front ones on the weekend. Rear bolts on the brackets are easy. Front ones are seized. Gave up after 4hrs and spraying with pb blaster in preparation for a second try this weekend.
__________________ JBR SRI+TIP, Autotech internals, Stratified stage 2 flash tune, Corksport BPV, UR test pipe, Damond Motorsports RMM |
![]() | | #34 | ![]() |
| Neutral : +1 score ImageUploadedByTapatalk1416092163.189862.jpg One bolt sheared off. Am I screwed? Probably have to drop the sub frame to get the other half of the bolt out? I got the bushings changed but still clunks on the side missing this bolt. Hoping it'll be ok through winter. Not clunking anywhere near as much as before.
![]() | | #35 | ![]() |
| Not Ranked : 0 score Uh...how the fuck...Yah you will need to find a way to get the other piece out but likely will need to drop it now cause I dont know how the hell you would get a drill in there. Unless you can do it from underneithe vs top.
![]() | | #36 | ![]() |
Yeah I guess I'm too strong for these bolts lol. Fucker was seized. Used pb blaster but this one decided to break in half. I'm going to have to look into what to do to get the sub frame down without taking a whole bunch of shit apart. It can't be reached from below because there's no hole lined up with the bolt.
__________________ JBR SRI+TIP, Autotech internals, Stratified stage 2 flash tune, Corksport BPV, UR test pipe, Damond Motorsports RMM | |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Fuck it, time to get a new car.
| The Following User Says Thank You to azarashi For This Useful Post: | OverBoosted (11-15-2014) |
![]() | | #38 | ![]() |
![]() Join Date: Oct 2014 Location: Worcester MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 338
| Not Ranked : 0 score So I have access to a lift. I'm going to guess removing the subframe would be the best plan to get to both the bushings and the end links. Or is that just a headache in its self?
__________________ 2009 Metro Gray Mica Mazdaspeed 3 Cobb AP - HTP INTAKE - HKS BPV - GrimmSpeed EBCS - Autotech HPFP - ATP catless DP - JBR EGR full delete - Damon RMM PMM TMM- TR8/CX Piping - Damon Catch Can - FREEKTUNED |
![]() | | #39 | ![]() |
| Not Ranked : 0 score It would certainly make it easier to get the bolts and bushings out if you drop the sub frame. There's very limited space to get a socket in there and you can't use a long one either. I found the only real way to fit the socket wrench in there was around the down pipe area and you have limited movement like 1/3 turn at the most.
![]() | | #40 | ![]() |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 1415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,027
Groans: 155
Groaned at 44 Times in 37 Posts
| Not Ranked : 0 score My '07 bolts are frozen on there. I gave up on this. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-front-sway-bar-bushing-replacement-w-140109/ | ||||
| Considering upgrading to a 3 MPS (Speed) from a 2.0 sport. What are they like to live with? : mazda | This thread | Refback | 01-31-2015 06:13 PM | |
| How-To: MS6 Front Sway Bar Bushing | TiGraySpeed6 | MazdaSpeed 6 - How-To's | 44 | 08-23-2017 09:16 AM |
| Front Lower Control Arm Bushing Motion | TRex | MazdaSpeed 3/6 - Suspension & Brakes | 0 | 10-21-2012 07:43 PM |
| MS6 driver-side sway bar bushing removal | wdautrem | MazdaSpeed 3/6 - Suspension & Brakes | 16 | 06-01-2012 10:44 PM |
| Front Strut Bushing | Spirry | MazdaSpeed 3/6 - Suspension & Brakes | 0 | 04-18-2011 08:17 AM |
