> MazdaSpeed 3 - How-To's
  • 1 Post By mazdaspeedjay
 Old 04-04-2008, 06:02 AM   #1
mazdaspeedjay's Avatar
Posts: 99   (View Stats)
mazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the world
Default How-To install a turbo timer in a speed3
O.k. as of now you have to hard wire this into the wiring harness NO ONE to my knowledge has a plug and play kit out yet except for me but it's not ready for sale yet. I'm trying my heart out to get this out there to you all because it does make life so much easier but there's alot of R&D going into this and i want to make sure everything is perfect. here's the how to and final answer on installing a turbo timer on a speed 3. first off turbo timers are turbo timers there's no real difference in HKS, Greddy . Turbo what ever they all do the same thing unless yours is a full auto or auto timer which means that when set to a certain mode i.e. auto or full auto. the timer will set the idle down or cool down time based on how you drive the car usually using voltage or speed signal to check the load and base the time off certain specs. basicly i've always set my timers myself and set them between 2-3 minutes. for normal driving this should be enough. If your timer has serveral save settings you can program i always have one set for 5 minutes for track and race days or if you've driven you car really hard that day. All or most turbo timers use the same color wires Red , Blue , Green, Black and Gray. Some use pink or purple for accesory hook ups like A/F Ratio or speed signal. These are not needed for a basic install. The main things you want is your 12V constant , 12V ignition, 12V Accessory, Ground ( DUH ), and your E-brake. I stress that e-brake hook up is not needed but i highly recommend because it's a safety feature.
Other then monitor your speed the speed signal wire is also a safety feature. When connected if someone bypasses the e-brake wire the timer uses the speed signal to sense if the car starts to move and kills the car. Usually E-brake is enough because chances of someone bypassing it in the time set for cool down. E-brake is used so if you or say a thief drops the e-brake down to take off it kills the car automatically. I usually only hook up the brake wire cause the speedo is a pain and not needed. E brake is also not need for the timer to work it's your choice it's very easy to hook up so why not.
Tools Required:
-Good soldering iron and some solder. I only solder because only butt heads use butt connectors. That was a bad joke but seriously I've just had too much problems with them in the past and not when using soder.
-Good wire strippers and crimpers
-Razor blade or small razor knife ( basically something sharp to strip wires. Wire strippers and cut things unless you have those auto strippers those work well but i prefer to use razor blades for they're great in tight places )
-12V volt meter or test light. ( either one will work but i prefer a meter cause you can also check grounds )
-Good quality Electrical Tape. Anyone like me that has done alot of car audio or gauges or electrical installs knows the pain of using cheap tape trust me.
-Double sided tape and some Zip ties. Ties are used to clean up loose wires and i use double tape or velcro to mount your actual turbo timer.
*-Heat shrink tubing. Tape works just as good this is a personal preference for some people. Not needed just a personal preference.*
-Vacuum line and Vacuum T's.... This is only for those that their T T's read boost like Blitz units other wise skip this
-Assortment of screw drivers. Philips usually is good enough but it doesn't hurt to have a multiple choice.
-Assortment of I or eye hole connectors used for the ground wire if not given to you with your timer from the company most are good about that though
-Assortment of 1/4" or 3/8" sockets and tools. These will be used mainly for bolting the ground wire. Yes you can T into a ground but i always ground everything on it's own.
Tools for the easy way out:
-Basically everything above but except soldering iron and solder. Go buy plastic T taps connectors and Butt connectors.
* Everything Above Can be bought at your local radio shack even some Targets or wal marts might sell them but radio shack is your best bet. Solder or butt connectors are a personal choice. T taps and butt connectors are a lot faster and easier but Ii've had problems with them not connecting well or going up so if you solder and know how to solder you should have a connection good for the life of the car and no problems. Once again if you don't know how to solder then practice and learn the right way it is just like welding in a way. that there is a right way and a wrong way to do this. If you don't know how to then go with the T taps and butt connectors just double check and make sure all connections are nice and good.*
Getting started :
Start by removing the side skid plate that says Mazdaspeed on it and also the lower left kick panel held in place by a little plastic puch clip. First you want to remove your steering column the under cover and side trim pieces right under it basically where your knees or shins are when sitting in the car before you can remove the under cover you must dismount the hood latch lever. Do this by placing a small flat head screw driver, pocket size works best, threw the top of the assembly you'll see the little tab that needs to be pushed down in the center. Push it down and pull the whole lever assembly out. don't bother trying to take the cable off first this is impossible and not needed. Once that is removed you'll see a philips screw there remove that and pop out the bottom kick panel cover. BE CAREFUL it's only held in by plastic clips and you need to disconnect the dimmer switch and DSC switch wiring harness. There's three Philips screws holding the steering column pieces together you must remove the bottom shin cover and hood latch first to get access to the third screw on the steering column at the end. Remove all the trim pieces and set them in a safe place so you won't step on them or damage them remember everything is only plastic.
Next find a good location to mount your T T ( TT=turbo timer ). Make sure you'll have enough wire after mounting to make it to where you'll be T tapping into your ignition switch harness and E-brake harness wire. If you need to lengthen or anything make sure you use the right gauge wire for that wire or wires they are heavier gauge for a reason. Don't lengthen a 14 gauge wire with a 18 gauge. Buy some extra wire from radio shack just in case in the two gauges used for TTer's just in case doesn't hurt and it's cheap.
Wiring in the turbo timer :
Now you'll want to located your ignition switch connector and wiring harness should be a bunch of big gauge wires on the left ( left as in if you are looking at the steering wheel and column sitting in the driver seat ). Remove the foam pad at the end of the harness and start to un ravel the tap from the harness. I only unraveled down about six inches from the foam wraped around the harness this should be more then enough room. There will be three wires here you need to look for. Red or Black/Red ( Either one is a 12V Constant I used black with the red stripe ) These two are your 12v constant wires only one is needed so pick one. Next is a Green/Yellow wire ( Green with a yellow stripe) The green/yellow wire is going to be your ignition or switch 12V wire. Last is your Acc. wire. Find the same size All yellow wire. Now some others on other forums say to use the pink and yellow for ACC. My car is a '08 and they're full of shit BUT this is where a test light or Volt meter come in use. Check the yellow wire with your tool should have 0V with the key off and 12V ( or test light lights up ) WITH THE KEY IN ACC. POSITION ONLY. IF like mine the all yellow wire is it use that if not check the pink and yellow wire and use that one. Now you remove the skid plate and lower left kick panel for a reason. See that black ground with a 10mm bolt. That is going to be your ground and the best spot i found. Ground your TT there unless you found a better spot.
Wiring in the E-Brake Wire :
This wire is not needed for the timer to actually work but is highly recommended to install for safety and security. Also it's a easy way if you don't need to use the timer to to turn it. By droping the e brake it sends a signal to the timer and kills the TT automatically. I've seen some people even wire this up to clutch switchs or brake switchs at the pedals but not all cars work the same like that so we'll stick with the normal way and use the e brake.
Start first by removing the shift knob. Next remove the cup holder trim piece follow by the shifter boot and trim piece. Now the next step is not needed but will make running the wire alot easier to access. You'll see two 8mm or Philips screws holding in the ash tray assembly. remove the two screws and either pull just the ash tray and then the cig. lighter assembly above it or mine came out as one whole piece. Disconnect the cig. lighter, Passenger air bag light and any other connectors to remove the trim piece out of the way. Or there should be enough slack to just set it a side either way works. Locate the e brake signal wire. It's a Black with a light green stripe. It's a pain to remove and gain access to the harness so what i did is follow the wire from the e brake assembly. It goes to a plastic tube surrounding the wire it's a pain in the as but remove the tape and plastic tube covering the black/light green wire. Once done run the wire ( usually gray for TTer's ) for the e brake from the TTer assembly or harness and tap into the black and light green wire for the e brake. Secure wire and connection and tuck it back under the carpet making sure it doesn't come in contact with the e brake assembly. Re-install trim piece for the shifter and center console in reverse order and your done.
Final :
You should already have a place to mount the TT unit. Some TT units have a display unit and then a actual relay and brain unit so to say. I'm using a STRI Turbo timer. I never heard of them till a week ago but i picked it up from my local performance shop for only $30 so for the money you can't beat it. Some TT units also have a built in boost gauge. If like me you already have a boost gauge installed in your car you don't need to hook this up but if you want to you can T tap into the vacuum soruce right at your gauge instead of running everything threw the fire wall again unless you have a electronic gauge in which you'd have to run it threw the firewall again. I like the STRi unit that i have cause it's very small and discreet. I mounted my display unit in the little cubby hole where the OBD access port is on the left side of the bottom kick panel. it's out of the way no one can see if and it's easy to access if i want to. I mounted the brain for my TT to the left of the steering column on the brace for the front crash bar to give you guys a idea of how i installed mine. Reinstall all trim panels in reverse order and secure any loose wires and turn the key to full on ( two clicks on right before start ) and check to make sure your TT unit works properly. Have the E brake up and then turn it off. the TT if turned on should start to count down. Drop the e brake and check to make sure the TT unit turns off. If everything works fine congrats everything is hooked up right and in working order. If nothing is working right check all your connections if everything except the e brake kill is working then check your connection at the e brake wire. **The E brake must be in the engage and up postion when you turn the ignition off for it to work on most units. Some will work regardless but most need it to be up in order for it to work right.**
Enjoy no longer having to sit in your car and wait for it to idle down with your new turbo timer. IF you need pictures of anything just ask but i believe i described everything in good detail for there to not need pictures but if you do just ask.
VulgarKyle likes this.
mazdaspeedjay is offline   Reply With Quote
The Following 7 Users Say Thank You to mazdaspeedjay For This Useful Post:
Addikted To Boost (08-10-2009), AG. (10-03-2008), Jesse MS3GT (04-07-2008), mazpro (04-11-2008), occschemguy (04-05-2008), VulgarKyle (06-08-2013), Zeya (09-16-2008)
 Old 04-04-2008, 06:09 AM   #2
I do have pictures for everyone but i'm computer eliterate when it comes to that so someone would need to help me out with that part if they can but i think i worded everything pretty good.
The Following User Says Thank You to mazdaspeedjay For This Useful Post:
occschemguy (04-10-2008)
 Old 04-07-2008, 12:29 PM   #3
sleeper3's Avatar
Posts: 675   (View Stats)
sleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant future
lol @ eliterate
all you have to do is click the and upload your pics. they will attach at the bottom of your post and we can figure out the rest!
Ribs. I had ribs for lunch. That's why I'm doing this.
sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM)
sleeper3 is offline   Reply With Quote
The Following User Says Thank You to sleeper3 For This Useful Post:
 Old 04-07-2008, 12:30 PM   #4
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
u plug in yur storage device to a usb whole in yur computer
 Old 04-09-2008, 05:17 AM   #5
ahh ok i will try. when i tried on other forums sometimes my pics are too pic and i don't know how to re size them.
My car: 2008 Mica black Mazdaspeed3 sport model:
-Currently Serving in the United States Marine Corps. as a Machine Gunner ( 0331 ):
-Afghanistan southern heldman province Oct.09'-May.10'
MODS: COBB Short air intake, ONE OF THE FIRST PEOPLE TO HAVE THE ACCESS PORT BETA TESTER, Cobb access port, CP-E Catted Down pipe ( now no cat.'s ), Custom Exhaust,Turbo X's Hybrid BOV , Coil Pack spring mod, MY Very own Intercooler Cover mod, 8000K HiD Head Light upgrade, Stri electric boost gauge, EGT and turbo timer, AEM UEGO Wide band A/F Gauge, CP-e Dog bone lower mount with race bushing, Red Calibers, yellow fog lights. CP-E fuel pump upgrade.
 Old 04-10-2008, 11:11 AM   #6
Dont worry about the resize since my forum automatically resizes them for the forum view
 Old 04-11-2008, 10:10 AM   #7
Hypnotized's Avatar
Posts: 184   (View Stats)
Hypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to behold
thats a nice feature!!
Hypnotized is offline   Reply With Quote
 Old 05-07-2008, 12:42 PM   #8
Radar_This's Avatar
Posts: 1,134   (View Stats)
Radar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the world
i am a visual person...can we get some pics?...
nice write up BTW...
Radar_This is offline   Reply With Quote
 Old 08-26-2008, 02:00 AM   #9
diepanthony's Avatar
Posts: 63   (View Stats)
diepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the rough
when your engine is still on could you lock your doors? cuz my bros audi 1.8T has a turbo timer and he can not lock the door with his remote. he has to do it by putting in the key.
diepanthony is offline   Reply With Quote
 Old 08-27-2008, 10:37 PM   #10
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
mine wont let me arm the alarm but the doors still lock with the remote
reddeerspeed3 is offline   Reply With Quote
 Old 08-27-2008, 11:11 PM   #11
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
i cant lock or unlock or do anything with the remote during countdown.
 Old 10-02-2008, 09:52 PM   #12
desertrat's Avatar
Posts: 132   (View Stats)
desertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant future
I just rewired my STRI TT with this write up and I'm so happy I can lock my doors while the timer is on now. Thanks.
desertrat is offline   Reply With Quote
 Old 10-02-2008, 11:38 PM   #13
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
Pictures please!
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
 Old 10-06-2008, 09:52 AM   #14
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
i have a greddy full auto TT sitting around. i need a pictured how to for me to do it.
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 10-06-2008, 10:57 AM   #15
xandrake's Avatar
Posts: 575   (View Stats)
xandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the world
I have my apex'i full auto sitting in my trunk. I'd really like to get this done. bump for some pics and/or a harness that allows full auto!!! That'd be amazing.
xandrake is offline   Reply With Quote
 Old 10-16-2008, 11:22 PM   #16
the 3 wires you need, no guarantees that all our wiring harnesses came from the same place. i suggest you pin test before ever cutting a wire just to confirm the colors.
e-brake sensor wire
my finished product. i had to dremel out the corner of the cubby to make it fit straight but it was also convient to hide the wires.
 Old 12-10-2008, 11:20 PM   #17
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Thanks a ton for this how to man it helped me out a lot just now...Took me about two and a half hours total... It wasnt really that bad running my 02 sensor wire the one that was a bitch was the damn parking brake wire... i didnt realize at first that the clip came out making it much easier to put the wire tap on
09 MGM MS3
 Old 12-11-2008, 06:32 AM   #18
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
so you're telling me red and yellow wire huh? just give it a quick nudge and i can start your car =D RED AND YELLOW WILL START THE CAR!!! lol
but good write up man!
time to steal some speeds
Buildabong is offline   Reply With Quote
 Old 03-09-2012, 03:34 PM   #19
PhorB13's Avatar
Posts: 47   (View Stats)
PhorB13 is a jewel in the roughPhorB13 is a jewel in the roughPhorB13 is a jewel in the rough
I'm wondering if the the original poster ever made the wiring harness for the car that he w.was talking of making??
PhorB13 is offline   Reply With Quote
 Old 04-06-2012, 06:09 PM   #20
hey guys I was shocked this post was still on here. I had alot of plans for this forum write up how to's when i first became a member on here. shortly after this was posted and done I decided as some on here know I left the car business back on 2008 and joined the marine corp. my avatar is actaully a pic i took when i was in afghanistan. I've never forgotten about this place and still check in from time to time but being in the military now specially being that I'm in the infantry keeps me pretty busy and not much time to play with my speed or get online. thanks for all the positive feed back on here though.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-install-turbo-timer-speed3-2311/
APEXi turbo timer SOS This thread Refback 07-20-2012 11:32 PM
turbo timer - Mazda 3 Quebec This thread Refback 05-31-2011 03:24 PM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-04-2008 06:20 AM
How to install an oil catch can? Death-From-A-Mile MazdaSpeed 3/6 - Turbo Induction 7 09-13-2014 06:03 PM
PG manifold install ms3guy22 MazdaSpeed 3 - How-To's 27 08-28-2012 08:34 PM
How-To: Install Cobb Springs + Impressions. Sacrilicious MazdaSpeed 3 - How-To's 24 05-25-2010 02:14 AM
ATP Turbo Items for Speed3/6 IN STOCK! Performance Racing Mazdaspeed3/6 General Discussion 18 04-22-2008 08:56 AM
how NOT to install a TWM Short throw shifter CMESCOOT MazdaSpeed 3 - Engine, Transmission & Driveline 20 04-01-2008 09:06 AM
Page generated in 0.43839 seconds with 35 queries
