| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() | | #81 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score
__________________ Some things. |
![]() | | #82 | ![]() |
![]() Join Date: May 2009
Rep Power: 371 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score does it look gay ? I was hoping for some BLACK hose, not some gay crap that looks like it came from the 70's. Thanks for the tip however, if I can't find anything else I may have to go this route.
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
![]() | | #83 | ![]() |
![]() No, it doesn't look gay, and it's quite functional. Just get some vacuum hose if you prefer. Vacuum is not made for carying oil or fuel, but honestly not that much will be going through it, and the stock hose is vacuum. At any rate you can't see it from the engine bay.
__________________ Some things. | |
![]() | | #84 | ![]() |
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount | |
![]() | | #85 | ![]() |
![]() Join Date: Apr 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 151
| Neutral : +1 score man, getting the hose onto the original pcv was a super pain in the ass. I think it was because of the hose i used. It was very rigid and made this job a huge pain in the ass. |
| The Following User Says Thank You to dcphantom For This Useful Post: | 3Gee Tee (09-11-2012) |
![]() | | #86 | ![]() |
![]() Join Date: Oct 2008 Location: Hustle town Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 143 Times in 33 Posts
| Not Ranked : 0 score Im installing my occ next week and was wondering if there is a way to not only connect the OCC to the intake manifold and crank case but to also merge it with he valve cover pcv to intake line and eliminate the contaminated air from the valve cover from entering our intake pipe. will this work? can i basically keep the oem valve cover pcv and just "T" it into the line that connects the crank case to the OCC? please advise!!!! |
| The Following User Says Thank You to Wenis Prinkle For This Useful Post: | corbs (08-01-2009) |
| The Following 2 Users Say NO Thank You to Wenis Prinkle For This Un-useful Post: |
![]() | | #87 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score I do believe you will need a 2nd catch can for that. |
![]() | | #88 | ![]() |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 854 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Neutral : +1 score Pics of where I mounted my SM catch can. I don't even have to lift the car or use tools to drain it. I mounted it via heavy duty ty-wraps to the bracket that holds to two hard lines that run on the passenger's side bottom of the radiator (I didn't even look to see if those were AC lines, oil lines, or whatever). I used a 3" hole saw to cut the hole in the 3 pieces of plastic that converge on that area with no problems. Gotta watch those damn parking curbs even more now though, I tweaked it just a bit even with it NOT being the lowest thing hanging down... Still though, it works like a charm. I also did something I doubt nobody else has done. I used copper hard line instead of the heavy duty hose. I tried the braided clear hose from Home Depot and it's not fuel resistant and was getting some deforming. The heavy duty heater hose was getting some collapsing, so I got some 5/8" nominal (1/2" ID) formable copper tube and bent my own hard lines. I'll get pics at the next oil change.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall |
| The Following User Says Thank You to bnoon For This Useful Post: | here.n.there (10-10-2016) |
![]() | | #89 | ![]() |
![]() Join Date: Aug 2008 Location: Cerritos, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score will fuel hose from autozone work? they sell 5/8th ID for cheap and it looks like its reinforced on the inside |
![]() | | #90 | ![]() |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score thats what i used and it seems like its collapsing a little bit but not completely.
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() | | #91 | ![]() |
![]() Join Date: Oct 2008 Location: Frederick, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 913
| Not Ranked : 0 score I first used heater hose and it collapsed. The same happened when I used the braided nylon from Home Depot. I got a thick walled 5/8" ID water hose at Home Depot, its about $2.00 a foot, and it seems to be holding up. They sell it in the same section as the heater hose. Yes this is the third time I replaced the hose. Hopefully, the 3rd time is the charm.
__________________ CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic. |
![]() | | #92 | ![]() |
| Not Ranked : 0 score I used marine grade hose |
![]() | | #93 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Nice write up...i appreciate the time u put in and explaining how to install it. |
![]() | | #94 | ![]() |
![]() Join Date: Sep 2009 Location: Seattle WA
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Nice info |
![]() | | #95 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score great write up! very helpful thanks man |
![]() | | #96 | ![]() |
![]() Join Date: Aug 2009 Location: Nor Cal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Sucks that advanced auto's pcv valve lets air escape on both sides of the valve. I need to go buy the factory valve now. Unless it's suppose to do that?
__________________ 2007 Cosmic Blue Speed3 [ MS CAI w/Straightener] [Cobb AP] [ RPMC TI ] [ FORGE BPV ] [ SU RP ] [ PG FMIC ] [Denso Plugs] [Trz MM] [ TWM SS&Bushings ] [ Greddy TT ] [ Defi Boost Gauge ] Not going to install-Weapon R catch can. Piss on doing that install |
![]() | | #97 | ![]() |
| Not Ranked : 0 score Air should only be able to escape one direction. If blowing on both ends of the PCV allows air through, yea, just goto a dealership and grab one, under $10 IIRC. Some air might leak one direction with light pressure as it takes a bit to plug up.
![]() | | #98 | ![]() |
| Not Ranked : 0 score I'm an idiot, I should have checked it before I bought everything to and put it all together. Thanks for the info
![]() | | #99 | ![]() |
![]() Join Date: Dec 2008 Location: Allentown, PA
| Not Ranked : 0 score sweet write up! thanks for the info |
![]() | | #100 | ![]() |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Consider using the high pressure check-valves from PTP performance. They are generally SRT4 folks, but the specs could meet/exceed a 2nd PCV valve and hold the flow forward and stop high pressure boost backwards. I have one my stage3 Neon SRT-4 and it works great. When I get around to an OCC on the MS3, I'll go the same way more than likely. PT-Performance.com Excerpt of specs: So after doing months of testing and we finally got a competitor valve for testing... we are ready to release our PCV check valve. Test results: Ours Pressure hold: 125 psi, and spike to 170 before leaking CV (flow): 1.26 Crack pressure: .58 hg (14.43 test) Competitor: Pressure hold: 100 psi and spike to 110 CV (flow): .96 (not enough to support proper vacuum signal to the OEM PCV system, thus causing oil to leak from the valve cover vent hole) Crack pressure: 1.11hg (14.43 test) We have used these check valves for the last 5 years for every turbo charged application on the market, we have had zero issues with them (other than noise indicating that they are working). Our valves come with complete directions for install and are sized for the PCM supply line (proper size). The kit comes with 2 zip ties, the valve with fittings, and directions for install. Takes 5 minutes to install. Reason you need one? The factory PCV system leaks at pressures above 17 psi (proven this with boost leak checking). Not only that, but you will see oil collecting in your stock air box due to the system blowing oil out the drivers side vent hole (bad). The consistant boost pressures over time will wear out the stock PCV valve, thus the need for a check valve. $39.50 + shipping (normally around $4.50) We have used this on the shop car boosting over 35 psi without any problems, and the PCV valve is still brand new. We ran this for 20k miles so far on the car without one adverse effect on emissions or oil control. Its a must for your car if you plan on rasing the boost levels. I will be adding them to the site in the coming week, or you can send payment to our PP account at ptperformance@comcast.net for a total fo $44.00 |
![]() | | #101 | ![]() |
Using the above check valve instead of the 2nd PCV valve will also let you be less "directionally dependent" of the 2nd PCV valve having to have the orange side down as per below and stated in the directions on page 1: The valve-based check-valve is also not "directional dependent" like one of those wobbly 2nd PCV Valves. Hence, you don't have to worry about the orange end staying "down" as the directions state below in the excerpt. It uses a custom plenum and spring valve I believe that will work in any direction. Excerpt from poster who did an excellent job: Updated!! Now connect the short hose with PCV valve to the intake manifold nipple. Then tighten down the clamp. And you are done connecting the hoses! Important!! The orange end must face straight down or the PCV may not function properly! | |
![]() | | #102 | ![]() |
![]() Join Date: Mar 2008 Location: Austin, TX
Rep Power: 0 ![]() Thanks: 0
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score Awesome writeup and pics! Thanks. Is there a location that is available that allows easier draining of the OCC? |
![]() | | #103 | ![]() |
![]() Join Date: Jan 2010 Location: Brevard, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Anybody care to comment on the procedure of just venting the crankcase PCV to atmosphere and plugging the IM nipple on a MS3 not running higher than normal boost..? Also, on the valve cover vent, is there a PCV there ?? (someone mentioned that was the case but I don't see why since it doesn't see boost pressure). Is the direction of air in this valve cover system from valve cover to air intake or does it draw air into the valve cover, subsequently the crankcase like some of the older recirculation systems ? |
![]() | | #104 | ![]() |
![]() Join Date: Oct 2009 Location: King of Prussia, Pa
Rep Power: 0 ![]() ![]() Thanks: 3
Groaned at 8 Times in 2 Posts
| Not Ranked : 0 score Is anyone having problems when using the OEM PCV valve on the CC setup? I got one from a dealer and it seems like a cheap piece of sh*#. I know it has to be positioned properly but even when doing this, it seems to leak a small amount of air instead of sealing. And as far as the valve cover breather and the PT Performance pill, I used a section of heater hose with a small socket inside to reduce the outlet size the same way the PTP Pill does. Bit of a rig job but it works. It's just vented to atmosphere now, not recircing back into the intake. |
![]() | | #105 | ![]() |
| Not Ranked : 0 score I can't send PMs yet since I'm new (less than 15 posts). Adding this here since Yammer1 wanted to know via PM. Can't answer back just yet. You can get any size check valve you want from McMaster-Carr (which is what I ended up doing. I'm still designing my catch-can set up). But McMaster-Carr has a bevy of different check-valves, both male-end, female-end, and then get hose-barbs). I ended up getting the 3/8" valve with the following specs: 7775K53 BRASS SPRING-LOADED PISTON CHECK VALVE, 3/8" NPTF DRYSEAL FEM CONN, FLUOROELASTOMER SEAT Run a search on McMaster-Carr I am also trying to figure out a way to get my catch-can to mount on the passenger side corner near the heat shield. But I have concerns about the hose length and low spots after engine shut-off that might cause some pooling in the hose instead of the catch-can. Last edited by cudaman; 02-26-2010 at 02:41 PM. |
![]() | | #106 | ![]() |
![]() Join Date: Jan 2010 Location: Hayward, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 814
| Not Ranked : 0 score Nice ' How To ' |
![]() | | #107 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
also the can that i purchased came with interchangable 5/8 1/2 in connections....would it be ok to run 2 different sizes for ease of installation? or is that a no no? Last edited by TRex; 03-15-2010 at 11:46 AM. Reason: additional info | |
![]() | | #108 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Nice write up. Thanks for the post. |
![]() | | #109 | ![]() |
![]() Join Date: Apr 2010 Location: Northern VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 110
Groaned at 32 Times in 15 Posts
| Not Ranked : 0 score yes, lower
__________________ ---Stupid kid can haz car. |
![]() | | #110 | ![]() |
![]() Join Date: Jul 2010 Location: Chicago IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score this still looks like a big PITA. I want it so bad though arghh |
![]() | | #111 | ![]() |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
| Not Ranked : 0 score Thanks for the write up, hopefully he's still making these so I can order one!
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
![]() | | #112 | ![]() |
![]() Join Date: Mar 2011 Location: niles,il
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 4 Times in 1 Post
![]() | | #113 | ![]() |
| Not Ranked : 0 score Always good to have, for the price its a great safety buffer that can help with fuel dilution in the oil, crank case pressure, and oil in the intake.
![]() | | #114 | ![]() |
| Banned ![]() Join Date: Apr 2009 Location: Northwood NH
| Not Ranked : 0 score I'm wondering why return the PCV from the catch can back to the intake and not vent it through a valve cover breather to air? Then just cap off the nipple on the intake. Jaz make a plastic brather tank with a filter allready on the top. ..:: JAZ PRODUCTS ::... |
![]() | | #115 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Subbed for dipstick blowing out
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #116 | ![]() |
![]() Join Date: Nov 2010 Location: Baltimore, Md
Rep Power: 356 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,356
| Not Ranked : 0 score doing this tonight thanks for the awsome write up
__________________ _____________________________________________ 2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, . |
![]() | | #117 | ![]() |
| Not Ranked : 0 score The percentage of brownies in this thread is ridiculous.
![]() | | #118 | ![]() |
![]() Join Date: Oct 2011 Location: Sugar Hill, GA
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score I just received the Saikou OCC from Matt Damon, without instructions, and there are a couple of parts that I am not sure where they go. I didn't put the car up yet but if any of you know where this goes, I appreciate it. |
![]() | | #119 | ![]() |
| Not Ranked : 0 score And this is the whole kit, if it helps, thanks. |
![]() | | #120 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score The black hose I think goes on the drain fitting, and the male to male fitting I used to connect the new hose to the old black hose thats coming off the stock pcv.
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
| The Following User Says Thank You to Etipp98 For This Useful Post: | adrianhan (10-30-2011) |
| How to install an oil catch can? | Death-From-A-Mile | MazdaSpeed 3/6 - Turbo Induction | 7 | 09-13-2014 06:03 PM |
| Catch Can Install | bova | MazdaSpeed 3 - How-To's | 67 | 12-03-2009 01:56 PM |
| Cops now charging for gas used to catch you | Haltech | Automotive News | 2 | 06-20-2008 11:46 AM |
| $20 catch can yay or nay? | kraz3y | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 04-30-2008 04:58 AM |
| Catch can installed but I am still smoking | Death-From-A-Mile | MazdaSpeed 3/6 - Turbo Induction | 21 | 03-28-2008 12:28 PM |
