> MazdaSpeed 3 - How-To's
Like Tree12Likes
 Old 03-27-2016, 09:06 AM   #11
dagrimey1's Avatar
Posts: 1,246   (View Stats)
You don't need a press to remove or install this bearing. The how to explain how to do without one. Replacing that bearing made shifting a number night and day difference.
Sent using Moto Fo Sho Doe
The Following User Says Thank You to dagrimey1 For This Useful Post:
DynoBunny (12-14-2016)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-mazdaspeed-3-pivot-shaft-seal-bearing-184322/
MS6 shifter seized in neutral? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-16-2015 06:45 AM
shaft pivot seal replaced - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-18-2015 05:28 PM
How-to: MS3 Pivot Shaft Seal, Bearing, Breather Replacement This thread Refback 04-04-2015 02:38 PM
HOW-TO: shaft pivot seal replaced jrzy ms6 MazdaSpeed 6 - How-To's 287 08-18-2018 07:47 PM
MS3 Shaft Pivot Seal Replacement jmen73 MazdaSpeed 3 - How-To's 9 06-22-2015 11:19 PM
Shifter Pivot/Seal Fix? Gru_Nuts MazdaSpeed 6 - How-To's 8 11-08-2014 12:03 PM
Shaft Pivot Seal replacement urgency? KSUWildcatFan MazdaSpeed 3 - Engine, Transmission & Driveline 19 06-23-2014 08:09 AM
Shaft pivot seal useless tip paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 1 07-11-2012 03:48 PM
Page generated in 0.60001 seconds with 45 queries
