> MazdaSpeed 3 - How-To's
Like Tree12Likes
 Old 04-26-2017, 05:23 AM   #41
alden's Avatar
Posts: 400   (View Stats)
alden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant future
Such a detailed How-To! Greatly appreciated. I'll be attempting this over the weekend!
DynoBunny likes this.
alden is offline   Reply With Quote
 Old 05-15-2017, 11:29 PM   #42
alden's Avatar
Well, attempted this, and everything went smoothly! I attribute my success to this thread. Thank you for this how-to!
The Following User Says Thank You to alden For This Useful Post:
DynoBunny (01-30-2020)
 Old 12-20-2017, 10:12 AM   #43
Mtspeed's Avatar
Posts: 1   (View Stats)
Mtspeed is an unknown quantity at this point
Are these parts the same on the 2009?
Mtspeed is offline   Reply With Quote
 Old 12-22-2017, 01:28 PM   #44
DynoBunny's Avatar
Posts: 66   (View Stats)
DynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond repute
Groaned at 9 Times in 4 Posts
Yes, as far as I'm aware they're the same.
Glad this is still up, years of write-ups I've done were messed up as I used photobucket to host and they got rid of 3rd party hosting without paying. Pretty lame. Flickr is still good for it thankfully.
DynoBunny is offline   Reply With Quote
The Following User Says Thank You to DynoBunny For This Useful Post:
kgb (02-02-2019)
 Old 02-13-2018, 06:33 PM   #45
Batmzr's Avatar
Posts: 4   (View Stats)
Batmzr is an unknown quantity at this point
The old breather will not come out no matter what I do. Please help!
Batmzr is offline   Reply With Quote
 Old 02-13-2018, 06:38 PM   #46
Wcdfmt510's Avatar
Posts: 40   (View Stats)
Wcdfmt510 will become famous soon enoughWcdfmt510 will become famous soon enough
Just resealed mine. Super easy.took about 15-20 min
Sent from my Moto Z (2) using Tapatalk
Wcdfmt510 is offline   Reply With Quote
 Old 02-13-2018, 06:44 PM   #47
Batmzr's Avatar
I ordered the whole assembly and expected it to include the breather because all the pictures had one when you type that part number. It includes the bearing and seal. So I am trying to tap out the old breather so I can put it onto the new casing but it won't budge.
 Old 02-13-2018, 06:56 PM   #48
Batmzr's Avatar
Got it out. Ended up having to hammer it kind of hard used a 1/4 pin punch. And his instructions he used the same 5/32 used for the cotter pin( elastic pin).
 Old 02-14-2018, 12:34 AM   #49
alden's Avatar
Breather took quite a bit of force to hammer out for me.
 Old 02-20-2018, 05:44 PM   #50
AndyMZ3's Avatar
AndyMZ3 will become famous soon enough
First, thanks DB, excellent write up. I did the seal, bearing and breather repair this past weekend, and yes, "while you're in there" -- I replaced the gear oil. I paid $17 a quart for the Ford stuff. The color of the old stuff was pretty dark, and I had added about a half a quart of some 70W90 laying around to replace what was leaking out. Sorry so verbal, here is my comment -- never before had I heard what I have seen described as the whine or groan of the LSD when turning the wheel and cold. Never in 4 years of ownership, and now at 134K. Well I hear it now -- very pronounced. I am hopeful that I can find some research that informs me to replace the Ford unicorn stuff -- or just not worry about it. Again, thanks DB, at least I am not leaking everywhere!
---Andy
AndyMZ3 is offline   Reply With Quote
The Following User Says Thank You to AndyMZ3 For This Useful Post:
 Old 02-21-2018, 07:23 AM   #51
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I used oreillys generic gear oil. A lot cheaper and as good in my opinion.
Sent from my SM-G930T using Tapatalk
 Old 04-22-2018, 07:33 AM   #52
sarm1084's Avatar
Posts: 11   (View Stats)
sarm1084 is on a distinguished road
Groaned at 5 Times in 2 Posts
Awesome write up sir! I feel like I can handle this job like a pro thanks to you!
sarm1084 is offline   Reply With Quote
 Old 05-06-2018, 10:21 AM   #53
TR6
TR6's Avatar
Posts: 20   (View Stats)
TR6 will become famous soon enoughTR6 will become famous soon enough
I have a slight leak and going to replace the seal, but after reading this I think I will just do the full seal, breather, bearing combo. Thanks for the great write-up! Are the part numbers still the same for Gen 2 I assume?
TR6 is offline   Reply With Quote
The Following User Says Thank You to TR6 For This Useful Post:
 Old 05-06-2018, 11:30 AM   #54
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
It's the same. Job is pretty easy.
Stockish
 Old 05-07-2018, 11:32 AM   #55
TR6
TR6's Avatar
Cool, thanks. Parts are ordered and if all goes well they should will go in this weekend...
 Old 05-14-2018, 08:10 AM   #56
TR6
TR6's Avatar
Mission accomplished. It actually wasn't that bad and went fairly well thanks to the great info here. Much appreciated. I think it took almost 1.5 hours, and I went fairly slow and careful.
My breather was fine so I did not replace it, but I did do the bearing (even though it seemed fine as well). It seems maybe a SLIGHT improvement in shifting, but nothing as big as what some of you are reporting. But overall it does seem to be a small improvement, and no more leak
Thanks again for the great write up.
Oh, and I did have to remove the guide pin/bolt. I tried without removing it and it would not come out. I actually just loosened it some (didn't remove it all the way) and that worked.
Last edited by TR6; 05-14-2018 at 08:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-23-2018, 10:17 AM   #57
Lim075's Avatar
Posts: 9   (View Stats)
Lim075 is on a distinguished road
Originally Posted by dagrimey1 View Post
You don't need a press to remove or install this bearing. The how to explain how to do without one. Replacing that bearing made shifting a number night and day difference.
Sent using Moto Fo Sho Doe
I need help. I replaced the seal and bearing.. but it's stiffer than before and I can't push the shifter down to get into reverse! I am having trouble getting into first and second gear too! I only replaced the bearing bc of everyone saying how much better it was.. I'm wishing I only did the seal..
Lim075 is offline   Reply With Quote
The Following User Says NO Thank You to Lim075 For This Un-useful Post:
Db09ms3 (05-23-2018)
 Old 05-23-2018, 10:49 AM   #58
TR6
TR6's Avatar
Did you get it seated correctly when putting it back in? And did you put the pin back in?
I was actually going to post again today too:
Mine shifts fine and no more leak, but I am getting a bearing/whine noise, especially at higher speeds in higher gears. Any ideas? I did replace the bearing as well.
 Old 05-23-2018, 12:15 PM   #59
Lim075's Avatar
I did put the pin in, and tried as close to the picture as I could for the bearing. Just before the inside lip. I think it might be the shifter arms might be crossed.
 Old 05-23-2018, 06:36 PM   #60
Lim075's Avatar
Figured it out. The plastic black clip was vertical instead of horizontal. Now it's super smooth with a new bearing and seal. Although I might go back into it to do the breather.. it's kind of stiff now.
The Following User Says Thank You to Lim075 For This Useful Post:
dagrimey1 (06-06-2018)
 Old 05-23-2018, 06:48 PM   #61
Lim075's Avatar
Anyone know the part number for the plastic clip? Or have a part diagram of this assembly? I can't seem to find it in manual transmission or transfer case etc.
ms3_pivot_shaft_seal_replacment-056
Db09ms3 (05-24-2018)
 Old 05-24-2018, 10:57 AM   #62
Db09ms3's Avatar
Groans: 105
How about you don't clutter this awesome how-to and create your own thread?
Stockish
 Old 05-24-2018, 11:30 AM   #63
Lex2007's Avatar
Posts: 574   (View Stats)
He's asking questions related to the topic of the thread.
That's what the forum is for. Be nice.
 Old 05-24-2018, 01:05 PM   #64
TR6
TR6's Avatar
Exactly. Heaven forbid we follow the how-to and have additional questions or some issues arise, or someone has some other helpful info to add.
Glad he figured out his issue. I definitely have a whine/gear noise now (that was not there before) and seems to be getting louder. Could I have installed the bearing too far, or not far enough? How far in should it be installed? Anything else I could have done to cause the noise?
It shifts fine into all gears and runs fine, just making a whining noise that can't be good...
 Old 09-26-2018, 02:31 PM   #65
Axoid's Avatar
Posts: 3   (View Stats)
Axoid is an unknown quantity at this point
This is an awesome write-up. My 2008 MS3 (160k+) just started leaking around this area, and my local garage is estimating about $400 to repair it, all labor really. I ordered the parts from Avondale as they were the lowest cost I found and plan to do this myself soon.
My question is, before I start, how much of the trans fluid will I need to refill the case? Do I have to drain the whole case or just top it off when I am done? I called Mazda and the recommended fluid is
0000-77-5W90-QT
and it's about $15 a quart and takes 5 quarts to fill the case. I don't want to buy more than I need.
Thanks,
Don
Axoid is offline   Reply With Quote
 Old 09-26-2018, 03:32 PM   #66
Lex2007's Avatar
0000-77-5W90-QT
Thanks,
Don
You dont need to drain any gear oil. Its all from the top of the transaxle my bro. Just TAKE PICS so you know how everything goes back together!
 Old 09-26-2018, 04:25 PM   #67
Axoid's Avatar
Cool, thanks for the reply.
 Old 09-26-2018, 08:53 PM   #68
Lim075's Avatar
Also take your time putting it back together and putting it in.
Funny thing is, my local Mazda dealership doesn't sell the gear oil for the MS3.
 Old 01-28-2019, 03:24 PM   #69
rauce's Avatar
Posts: 10   (View Stats)
rauce is on a distinguished road
Used this how-to to fix my trans leak, thank you!
rauce is offline   Reply With Quote
The Following User Says Thank You to rauce For This Useful Post:
 Old 01-30-2019, 01:46 AM   #70
SeeMeGovan's Avatar
Posts: 945   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
Screw the mazda stuff, use Ford Motorcraft XT-M5-QS tranny oil. A bit pricier but sooo good. You only need 3 quarts btw, and you'll have a little left over.
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
 Old 01-30-2019, 07:11 AM   #71
dagrimey1's Avatar
Posts: 1,246   (View Stats)
If you didn't do the bearing and only fixed the seal, I'm sorry you missing out on these smooth transitions between gears.
Can't believe I using Tapatalk again!
The Following 2 Users Say Thank You to dagrimey1 For This Useful Post:
Db09ms3 (01-30-2019), DynoBunny (02-10-2019)
 Old 05-05-2019, 02:03 PM   #72
ACms6's Avatar
Posts: 2   (View Stats)
ACms6 will become famous soon enoughACms6 will become famous soon enough
Great write up! Huge thank you! Only took me about 2 hours
2006 Mazdaspeed 6 GT
2000 Honda Civic
2005 Acura TL - sold
ACms6 is offline   Reply With Quote
The Following User Says Thank You to ACms6 For This Useful Post:
 Old 06-18-2019, 09:37 AM   #73
JDTRUMPET's Avatar
JDTRUMPET is an unknown quantity at this point
I just wanted to say a HUGE thanks for this amazing write-up! I have the same pooling on my plate and very much need to fix this.
I drive a 2007 Mazdaspeed6, so from what I am reading it should be a very similar repair.... while just a bit different with the Transmission Mount for a bolt.
My main question is where you guys order your parts from? I can't find these anywhere!
I am a newb at ordering online, but this one is a must... Thanks!
JDTRUMPET is offline   Reply With Quote
 Old 06-18-2019, 09:46 AM   #74
ACms6's Avatar
@JDTRUMPET I purchased my rebuild kit on amazon for only $50 with free shipping. Delivered in 2 days to my door.
https://www.amazon.com/gp/aw/d/B01M3...b_b_asin_title
2000 Honda Civic
Db09ms3 (06-20-2019)
 Old 06-20-2019, 12:29 PM   #75
IDRIDR's Avatar
Posts: 18   (View Stats)
IDRIDR is a jewel in the roughIDRIDR is a jewel in the roughIDRIDR is a jewel in the rough
Or, it looks like this is the complete assembly with breather:
https://www.amazon.com/dp/B01M697X6T/
IDRIDR is offline   Reply With Quote
The Following User Says Thank You to IDRIDR For This Useful Post:
 Old 06-20-2019, 12:34 PM   #76
Db09ms3's Avatar
Groans: 105
Wow, they sell that whole assembly meow? Sex.
Stockish
 Old 06-20-2019, 12:44 PM   #77
SeeMeGovan's Avatar
Yeah might be worth the extra $30 to not have to tap out the bearing. I definitely need to do this soon, noticed a small puddle of oil on top of the plate.
Sent from my LG-H918 using Tapatalk
NATOR-WA 'GOVAN'
 Old 07-08-2019, 03:53 PM   #78
Hoobrus's Avatar
Posts: 7   (View Stats)
Hoobrus is an unknown quantity at this point
Hello, this is my first message on this forum. I recently purchased a used Mazdaspeed3 with 100k miles. Got a decent deal. The car is almost totally stock, including the original leaky seal
I am about to purchase a replacement and do the job myself, but I was curious if there is anything better than the OEM seal, since it seems kind of defective by design, apparently...
Hoobrus is offline   Reply With Quote
 Old 07-08-2019, 04:52 PM   #79
Db09ms3's Avatar
Groans: 105
No improvements on that bitch. I have 'heard' that short shift plates may exacerbate the issue but I have no proof on that fo'sho. The job is easy just follow this procedure.
Stockish
 Old 07-22-2019, 12:23 AM   #80
cwichman's Avatar
cwichman will become famous soon enoughcwichman will become famous soon enough
First post to the forums. Really just wanted to show my gratitude for this write up! Everything went smooth sailing thanks to everyone on here. Ended up just getting the whole plate from Amazon to save the hastle of pressing the bearings in and my speed3 shifts like new again with no puddle! Everyone on here is awesome.
Sent from my SM-G950U using Tapatalk
cwichman is offline   Reply With Quote
The Following 2 Users Say Thank You to cwichman For This Useful Post:
ACms6 (07-27-2019), DynoBunny (01-30-2020)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-mazdaspeed-3-pivot-shaft-seal-bearing-184322/
MS6 shifter seized in neutral? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-16-2015 06:45 AM
shaft pivot seal replaced - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-18-2015 05:28 PM
How-to: MS3 Pivot Shaft Seal, Bearing, Breather Replacement This thread Refback 04-04-2015 02:38 PM
HOW-TO: shaft pivot seal replaced jrzy ms6 MazdaSpeed 6 - How-To's 287 08-18-2018 07:47 PM
MS3 Shaft Pivot Seal Replacement jmen73 MazdaSpeed 3 - How-To's 9 06-22-2015 11:19 PM
Shifter Pivot/Seal Fix? Gru_Nuts MazdaSpeed 6 - How-To's 8 11-08-2014 12:03 PM
Shaft Pivot Seal replacement urgency? KSUWildcatFan MazdaSpeed 3 - Engine, Transmission & Driveline 19 06-23-2014 08:09 AM
Shaft pivot seal useless tip paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 1 07-11-2012 03:48 PM
Page generated in 0.57369 seconds with 41 queries
