> MazdaSpeed 3 - How-To's
Like Tree12Likes
 Old 07-22-2019, 12:23 AM   #1
cwichman's Avatar
Posts: 1   (View Stats)
cwichman will become famous soon enoughcwichman will become famous soon enough
First post to the forums. Really just wanted to show my gratitude for this write up! Everything went smooth sailing thanks to everyone on here. Ended up just getting the whole plate from Amazon to save the hastle of pressing the bearings in and my speed3 shifts like new again with no puddle! Everyone on here is awesome.
Sent from my SM-G950U using Tapatalk
cwichman is offline   Reply With Quote
The Following 2 Users Say Thank You to cwichman For This Useful Post:
ACms6 (07-27-2019), DynoBunny (01-30-2020)
 Old 07-27-2019, 04:26 PM   #2
rgurleyjr's Avatar
Posts: 21   (View Stats)
rgurleyjr has a spectacular aura aboutrgurleyjr has a spectacular aura aboutrgurleyjr has a spectacular aura about
Guys, for the whole kit for $83, is all you have to do is unbolt the cover and that's it?
rgurleyjr is offline   Reply With Quote
 Old 07-28-2019, 11:56 AM   #3
IDRIDR's Avatar
Posts: 18   (View Stats)
IDRIDR is a jewel in the roughIDRIDR is a jewel in the roughIDRIDR is a jewel in the rough
Not quite. You'll need to remove the shaft from the old plate kit and install it in the new one.
2009 Mazdaspeed 3 GT
almost stock
IDRIDR is offline   Reply With Quote
 Old 07-28-2019, 02:54 PM   #4
rgurleyjr's Avatar
Ok, the shaft you're referring to is not the big, long piece deep in the transmission is it? The write up has us removing a bolt and pulling something big out. Trying to avoid that.
 Old 07-29-2019, 08:19 AM   #5
IDRIDR's Avatar
You're not going to avoid that.
The complete kit comes with a new bearing, installed, so you don't need to remove and install a new bearing in the existing part. It also comes with a new breather that you'll need to drive in, and a new rubber bonnet. You'll still need to pull the complete assembly with shift shaft, remove the indexing bolt, drive out the pin to remove the shaft, then re-assemble with the new parts.
almost stock
 Old 07-29-2019, 03:51 PM   #6
rgurleyjr's Avatar
Mich thanks. I'll have to do this later, not up to deal with it now.
 Old 09-09-2019, 08:03 PM   #7
Tommy's Avatar
Posts: 2,309   (View Stats)
Tommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the world
Groans: 155
Groaned at 44 Times in 37 Posts
This job looks worse than it is. If you can work a ratchet and a hammer, you're golden. Got it done in under 2 hours with a tea break.
@dynobunny, thank you so much for such a detailed post. I owe you a beer for sure.
Want to win a v3 Cobb Access Port? Enter the raffle and help a good cause.
http://www.mazdaspeedforum.org/forum/forum/f510/cobb-accessport-v3-raffle-good-cause-190013/
Tommy is offline   Reply With Quote
 Old 12-07-2019, 10:39 PM   #8
acgollapalli's Avatar
acgollapalli is an unknown quantity at this point
I’m not certain this was how this was supposed to go. I tried to unstick the gasket on the plate with a chisel, but just managed to bend the chisel pretty good. Do I need a better one, or have I misinterpreted the directions?
Thanks!
File Type: jpeg 54A9A940-AFA5-43E8-874E-AFC9AD9F8509.jpeg (2.69 MB, 10 views)
acgollapalli is offline   Reply With Quote
 Old 12-10-2019, 09:13 AM   #9
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Thanks!
Try getting a rubber mallet and whack the side of the plate. That worked for me.
Stockish
 Old 12-08-2019, 10:28 AM   #10
Lex2007's Avatar
Posts: 574   (View Stats)
I did this repair along time ago but I sure dont remember needing to use any force to remove anything. Be careful.
 Old 12-11-2019, 05:07 AM   #11
djern's Avatar
Posts: 1,139   (View Stats)
Groans: 27
the metal of that chisel is too soft.
im going to leave the rest of the comments to myself.
a screwdriver or the punch you are going to use later on would be a much better choice to insert in to get the pivot shaft assembly out.
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
twitter.com/djern
instagram.com/djern
facebook.com/djern
 Old 02-15-2020, 07:22 PM   #12
cost0305's Avatar
Posts: 6   (View Stats)
cost0305 has much to be proud ofcost0305 has much to be proud ofcost0305 has much to be proud ofcost0305 has much to be proud ofcost0305 has much to be proud ofcost0305 has much to be proud ofcost0305 has much to be proud ofcost0305 has much to be proud of
I saw this thread and made a video of the process start to finish.
Like others have said here, the job is about two hours. The video shows every painful detail and is just over an hour long.
https://www.youtube.com/watch?v=vdFXj7mo0cE
cost0305 is offline   Reply With Quote
The Following User Says Thank You to cost0305 For This Useful Post:
manu (02-15-2020)
 Old 02-15-2020, 08:49 PM   #13
Lex2007's Avatar
Thanks for putting this video together. Awesome.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-mazdaspeed-3-pivot-shaft-seal-bearing-184322/
MS6 shifter seized in neutral? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-16-2015 06:45 AM
shaft pivot seal replaced - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-18-2015 05:28 PM
How-to: MS3 Pivot Shaft Seal, Bearing, Breather Replacement This thread Refback 04-04-2015 02:38 PM
HOW-TO: shaft pivot seal replaced jrzy ms6 MazdaSpeed 6 - How-To's 287 08-18-2018 07:47 PM
MS3 Shaft Pivot Seal Replacement jmen73 MazdaSpeed 3 - How-To's 9 06-22-2015 11:19 PM
Shifter Pivot/Seal Fix? Gru_Nuts MazdaSpeed 6 - How-To's 8 11-08-2014 12:03 PM
Shaft Pivot Seal replacement urgency? KSUWildcatFan MazdaSpeed 3 - Engine, Transmission & Driveline 19 06-23-2014 08:09 AM
Shaft pivot seal useless tip paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 1 07-11-2012 03:48 PM
Page generated in 0.37482 seconds with 29 queries
