> MazdaSpeed 3 - How-To's
 Old 07-17-2009, 04:54 PM   #1
retrobmx63's Avatar
Posts: 436   (View Stats)
retrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the world
Default How To: Retain stock shift height with TWM short shifter
Hey, do my fingers smell like your mother?
retrobmx63 is offline   Reply With Quote
 Old 07-19-2009, 10:42 AM   #2
dcphantom's Avatar
Posts: 634   (View Stats)
dcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the world
How do the rubber o-rings effect the feel of pushing it down for reverse? I could imagine it makes it very spongey.
dcphantom is offline   Reply With Quote
 Old 07-19-2009, 01:20 PM   #3
Its awesome to see Nator Performance has finally gotten some recognition for their V2.0 Washers.
 Old 07-19-2009, 01:59 PM   #4
retrobmx63's Avatar
Great question. I thought the same. I can't even notice it. It's solid like my cock.
I think it's due to two things, the diameter of the o-rings is quite small, also like my cock. So there isn't much give at all. Also, the washers as you can imagine is stiff... again like my cock.
Oh and another thing to note. Ideally you'd want the shift boot height to JUST about hit where the knob would stop threading naturally. This way pushing down on the knob is not really pushing on the boot at all (where any sponginess would be felt), and it's really already bottomed out internally in the knob itself (with included height adjustment spacers).
The Following User Says Thank You to retrobmx63 For This Useful Post:
dcphantom (07-20-2009)
 Old 07-19-2009, 02:18 PM   #5
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Silver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the world
Groaned at 81 Times in 33 Posts
I actually did this already. Bought some washers at the store and i'm very happy with where it's at now.
I installed only the 1 single locking nut inside the top of the shift knob and that was about enough of what I wanted in terms of a compromise of drop but keeping it shorter.
This is the best pictures I had taken before and after:
Before
After
Mike
2008.5 CWP Mazda CX-7 Sport FWD - hers
2008.5 CWP Mazdaspeed 3 GT - traded
2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold
Silver Ecstasy is offline   Reply With Quote
 Old 06-01-2010, 03:16 PM   #6
heeltoe's Avatar
Posts: 387   (View Stats)
heeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond repute
Groaned at 8 Times in 7 Posts
couldn't u just use a nut and washer instead of all those washers?
///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Act Stage 1 Streetlite///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP V3. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt///ProClip,GPS,AP,I5///
heeltoe is offline   Reply With Quote
 Old 06-02-2010, 08:18 PM   #7
boosthead's Avatar
Posts: 138   (View Stats)
boosthead has much to be proud ofboosthead has much to be proud ofboosthead has much to be proud ofboosthead has much to be proud ofboosthead has much to be proud ofboosthead has much to be proud ofboosthead has much to be proud ofboosthead has much to be proud of
or two washers with a small bushing between them. Bottom line, this gets you thinking about solution that works for you.
boosthead is offline   Reply With Quote
 Old 06-03-2010, 09:45 AM   #8
heeltoe's Avatar
Thank god twm now makes shift extenders. To retain stock height or higher like rally racers
 Old 06-09-2010, 11:56 AM   #9
TWM Performance's Avatar
Posts: 2,486   (View Stats)
TWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the worldTWM Performance is the leader of the world
Indeed! Some people like the short height, and others like it stock, and in some cases even taller. I like them nice and tall personally
Patrick
Team TWM Performance
TWM Performance is offline   Reply With Quote
 Old 06-06-2010, 02:48 PM   #10
AverageTanner's Avatar
Posts: 65   (View Stats)
AverageTanner is a glorious beacon of lightAverageTanner is a glorious beacon of lightAverageTanner is a glorious beacon of lightAverageTanner is a glorious beacon of lightAverageTanner is a glorious beacon of lightAverageTanner is a glorious beacon of light
Good stuff mate!
Tanner Smith
Cincinnati, OH... Soon to be back in Central Texas
AverageTanner is offline   Reply With Quote
 Old 06-11-2010, 08:12 PM   #11
idaners7's Avatar
Posts: 55   (View Stats)
idaners7 has a spectacular aura aboutidaners7 has a spectacular aura about
Groaned at 24 Times in 3 Posts
haha funny video.. but good info
idaners7 is offline   Reply With Quote
 Old 06-18-2010, 04:30 AM   #12
spike589's Avatar
Posts: 295   (View Stats)
spike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond repute
Groaned at 6 Times in 3 Posts
does anyone know what that bus connector chillin inside the the hole where the shifter is on the top right
spike589 is offline   Reply With Quote
 Old 06-18-2010, 04:59 AM   #13
retrobmx63's Avatar
No idea, I would likely guess some common harness for a regular 3's sunroof or other option or maybe Bose shit that I don't have.
DIY short throw shifter jweller MazdaSpeed 3 - How-To's 6 04-02-2011 02:30 PM
Will SPC links be ok at stock ride height thanotosq MazdaSpeed 3/6 - Suspension & Brakes 12 04-21-2009 07:58 PM
Some ?'s: Engine mount, shift spacers, short throw shifter, data management Burnsmz MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-02-2008 02:27 PM
Page generated in 0.34006 seconds with 29 queries
