> MazdaSpeed 3 - How-To's
Like Tree16Likes
 Old 10-31-2016, 09:27 AM   #121
Police - Grammarhead
Vansquish's Avatar
I recently performed ~90% of this same procedure on my girlfriend's 2007 Escape Hybrid. The 2.3L block is pretty much identical, and the thermostat is identical to ours. It's a little harder to get to things despite the larger, deeper engine bay of the Escape, but only because some of the angles of attack for the spring clamps make it harder to gain access and leverage.
It still took about 1.5 hours to perform the swap, and all is now well with the Escape!
 Old 10-31-2016, 09:47 AM   #122
RalliartRsX's Avatar
Posts: 366   (View Stats)
RalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the world
Glad to hear @Vansquish!
I found smaller locking pliers were the key to these particular spring clamps. IMHO, I have found locking pliers overall are the best for spring clamps (once adjusted correctly ofcourse) and saves on a ton of energy exerted on my end. However, when the OEM decides they want to put the release portion of the spring clamp under a immovable object, I am ready to burn the car down to ashes lol.
All goes back to using the correct tools for the job. I cannot stress that enough lol
MortalMechanica likes this.
RalliartRsX is offline   Reply With Quote
 Old 07-04-2017, 01:20 AM   #123
HmoobBoi's Avatar
Posts: 10   (View Stats)
HmoobBoi can only hope to improve
Thank you very much for the post Mach...easy guide to follow..the only pain in the ass was the clamps besides that easy pezy
HmoobBoi is offline   Reply With Quote
 Old 11-30-2017, 07:07 AM   #124
Trinity's Avatar
Posts: 55   (View Stats)
Trinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud of
First: thanks so much for the write-up & roadmap on how to do this removal/install.
It's been forever since I've been on but I just got the P01206 engine light/code the other night on the ride home from work. I called my local stealership to ask a quote on replacing the thermostat and got the standard "we can't give a quote because we need to diagnose it and see if blah blah blah" runaround.
I'm nervous about doing this myself but I think I can get it done. Wanted to ask a couple questions:
1. Is there any way to get all the coolant out prior to removing the Thermostat? I've seen a few vids of people doing the install on youtube and it's always on a non-speed 3 & when they finally get the thermostat off there's a good amount of coolant that comes splashing out (theirs is above the alternator) is it the same with the Speed3? Can you loosen any of the other lower hoses carrying coolant to help drain the rest out?
2. I've never messed with the power steering pump before on any car but from the write up it seems once the belt is off it's easy enough to relocate it out of the way. Is there really enough slack in the hoses to do this without worry?
3. Has anyone else replace the coolant temp sensor along with doing the thermostat or in a separate step? I assume it would be smartest to do both at the same time while coolant is drained. I can't find a good picture of where the ECTS is on the speed 3.
Trinity is offline   Reply With Quote
 Old 11-30-2017, 09:18 AM   #125
HmoobBoi's Avatar
To flush the coolant, there's a plastic screw (you can't miss it) at the bottom right of the fan...unscrew that till the screw comes off...
Once you've released the belt tension, it's easier to get the power steering out of the way but first off, make sure your belt is tied to something so it's not so lose as to where you don't know how to put it back it on..only hard part is the screws holding the power steering
In order to get to the ECTS, you'll have to remove your intake, perhaps maybe your TIP also unless your hands small enough to fit through..I've replaced both at once, making it much easier than doing it later in the long run...
 Old 11-30-2017, 10:39 AM   #126
Trinity's Avatar
Many thanks. I'm aware of the draining/flushing of the coolant but my question was how much of the fluid stays in the system or does all of if come out via the radiator. I've seen a few videos of people doing this DIY in a regular Mazda 3 and when they finally remove the Thermostat a bunch more coolant comes flooding out even though they drained it. Wasn't sure if it was the same with the Speed 3 since the engines are different.
Thanks in advance.
 Old 11-30-2017, 11:53 AM   #127
HmoobBoi's Avatar
Thanks in advance.
I'm not sure how much fluid you have but when i flushed my coolant there were tons of fluid...so before hand, just let the coolant continue flushing, no need to rush to get to the thermostat...when removing the thermostat, get like one or two towel rag and let it sit right under the thermostat when removing..engines are somewhat similar but also different in ways...FYI you might use up one whole gallon of coolant
 Old 07-28-2018, 07:48 PM   #128
Bugeye60's Avatar
Posts: 6   (View Stats)
Bugeye60 will become famous soon enoughBugeye60 will become famous soon enough
Excellent write-up by mach69! Today I replaced the thermostat on my 08 ms3 (99,300 miles), flushed the system and replaced with FL22 coolant. All went well by following his instructions. About the only thing I did differently was to remove the two hoses before removing the thermostat.
Removing/installing the serpentine belt from the power steering pump by pulling on the tensioner was tough since there's not much room to do so, but I got it done. I don't know how anyone could remove the thermostat without removing the power steering pump, just because there's so little room to work in that vicinity with the pump there.
Bugeye60 is offline   Reply With Quote
 Old 11-16-2018, 06:25 AM   #129
Mazd1222's Avatar
Posts: 74   (View Stats)
Mazd1222 has a spectacular aura aboutMazd1222 has a spectacular aura about
Groaned at 16 Times in 7 Posts
thermostat replacement on the speed 6. When you drain the coolant from the radiator. You said that your refilling the overflow tank. My car does have a radiator cap so do I refill the radiator as well or just the overflow tank? Also do you need to burp the system if so how do you go about doing that on this car?
Mazd1222 is offline   Reply With Quote
 Old 11-16-2018, 06:43 AM   #130
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
When it's all back together, I fill the radiator, start the car with the rad cap off, add coolant to radiator as needed until it won't take any more. Install rad cap. Go for short drive around the neighborhood. Turn off engine. Once cooled down a bit, remove rad cap and top off with coolant. Verify overflow tank is at proper level. Should be good to go. Recheck overflow tank before each cold start to make sure it's not below the MIN line. If it's good and stable, send it.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-16-2018, 08:32 AM   #131
Posts: 2,237   (View Stats)
THis ^^^ plus i lift the front of the car higher than the back at time of filling it with the car iddling. It let air pocket to escape faster.
Db09ms3 (11-16-2018)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-thermostat-103450/
Thermostat beim Maza 3 MPS BK wechseln This thread Refback 11-30-2015 08:09 AM
Mazda 3 mps running fan/overheating ? Mazda MPS Owners Club This thread Refback 02-22-2015 10:20 AM
Mazda 3 mps running fan/overheating This thread Refback 07-30-2014 11:44 AM
Mazda 3 mps running fan/overheating This thread Refback 02-27-2014 02:29 AM
Engine Temperature stays low This thread Refback 12-23-2013 06:38 AM
Engnie Temperature stays low This thread Refback 11-28-2013 11:17 AM
Thermostat replaced: Speed 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 04-06-2012 04:08 PM
Replacing Thermostat socks Mazdaspeed3/6 General Discussion 23 10-06-2013 12:33 PM
Overheating....Thermostat?? MS6FL MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 11-25-2011 11:36 AM
Coolant Thermostat Install help? Scribbles MazdaSpeed 3 - Engine, Transmission & Driveline 7 06-11-2011 03:16 PM
getting dtc:P0126 Coolant thermostat stuck open ON 2 Thermostat dixie789456 MazdaSpeed 6 - Engine, Transmission & Driveline 4 06-08-2010 10:52 AM
cooler thermostat rodrigo MazdaSpeed 6 - Engine, Transmission & Driveline 26 07-07-2009 10:34 PM
Page generated in 0.33524 seconds with 28 queries
