> MazdaSpeed 3 - How-To's
Like Tree4Likes
 Old 03-07-2011, 06:14 PM   #1
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Default Mazda 5 rear brake conversion
Did this after reading someone on Mazda3forums do it.
Nothing really difficult about the install. Just replace the bracket holding the caliper. The following is worth noting:
* Mazda 5 rear brake discs are larger in diameter than MS3 but same width and offset.
* Mazda 5 rear calipers have the same piston diameter as the MS3. I read they weren't but I measured and they are exactly the same. The only difference to the MS3 calipers is the bracket which extends a little longer as the pics show to accommodate the larger disc.
* Mazda 5 pads are shorter than the MS3s but will fit.
******************* you need caliper brackets of a Mazda5 2008.5 or earlier******************************************* **
Impressions: Don't feel anything different than stock. It looks better due to the larger rotor but that's about it.
The Following 15 Users Say Thank You to Tomas For This Useful Post:
3mazdaspeed (03-10-2011), ak_spray (03-26-2011), asall667 (09-08-2011), Awal (06-17-2015), BLURSPORTS (03-07-2011), Easter Bunny (06-26-2013), grantmm (02-17-2013), gtlaw (03-08-2011), impossible (05-25-2016), silvapain (08-26-2012), SLOWHATCH (06-26-2013), snailD (03-09-2017), super_pablo_ (01-09-2013), uninc (04-08-2011), xcoldricex (03-07-2011)
 Old 03-07-2011, 06:43 PM   #2
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Groaned at 22 Times in 16 Posts
where did you get the brackets? might be worthwhile if you need to replace the rotors anyway
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
 Old 03-07-2011, 07:36 PM   #3
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
forgive me for asking - it's implied but not absolutely clear - so you can reuse the ms3 calipers with the mz5 brackets correct? all you replaced were the rotors and the bracket?
what's the rotor diameter of the ms3 vs. the mz5? larger rotor will net you better cooling for the track i suppose, probably no difference on the street.
 Old 03-07-2011, 08:13 PM   #4
Bob Ross Fanclub
Tomas's Avatar
had to buy complete calipers at junk yard. $150
correct. you can re-use stock calipers. Just change bracket.
hold on re rotor size.
ok, here it is. stock is 280mm. Maxda 5 is 302mm
The Following 5 Users Say Thank You to Tomas For This Useful Post:
ak_spray (03-26-2011), Easter Bunny (06-26-2013), gtlaw (03-08-2011), super_pablo_ (01-09-2013), xcoldricex (03-08-2011)
 Old 03-08-2011, 07:21 AM   #5
wootms3woot's Avatar
Posts: 172   (View Stats)
wootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant futurewootms3woot has a brilliant future
this is a cool find...might be doing this at my first brake change!
COBB SRI/TIP, HKS SSQV, HYPERTECH TUNE (COBB), CS TEST PIPE, HKS CBE, KONI YELLOWS, H&R SPRINGS, GT SPEC TRUNK CAGE, PROGRESS RSB, E4P SHORT SHIFTER, SU RMM, TRZ TRANNY MOUNT, KONIG COUNTERSTEERS...OTHER AESTHETIC MODS
wootms3woot is offline   Reply With Quote
 Old 03-09-2011, 10:25 AM   #6
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
What year did you take them off of?
ak_spray is offline   Reply With Quote
 Old 03-09-2011, 10:43 AM   #7
How much larger is the surface area of the Mazda5 pad?
SC08Speed3 likes this.
SC08Speed3 (01-27-2013)
 Old 03-09-2011, 11:27 AM   #8
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I wonder if there is a similar swap for the ms6, I need to change my rear brakes pretty soon.
2006 Mazdaspeed 6
 Old 03-09-2011, 11:29 AM   #9
I'm a caveman
gtlaw's Avatar
Groans: 68
it should be exactly the same. this will just give it more leverage moving it farther out from the center of the rotor
2015 MUSTANG GTPP
The Following User Says Thank You to gtlaw For This Useful Post:
Tomas (03-10-2011)
 Old 03-09-2011, 11:53 AM   #10
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
IIRC Our rear rotors are already larger than the CX-7 Parts.. The only mazda vehicle with larger rear brakes is the CX-9..
06Speed6 (03-10-2011)
 Old 03-09-2011, 12:21 PM   #11
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
Someone needs to make a bracket! I've looked and haven't found too man 5s in the junkyards. I wanted to do this too when I changed my brakes!
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 03-10-2011, 09:46 AM   #12
Speeeeeed
06Speed6's Avatar
I got some cx-9 rear brake specs off of ebay (lol) and they do seem pretty large. I wonder if they swap to either the ms3 or ms6.
Sorry for the slight thread jack, but I figure you might as well get the biggest ones you can find.
File Type: jpg $(KGrHqF,!gsE0vv1DUM+BN(JkGLtpQ~~0_1.jpg (21.2 KB, 89 views)
File Type: jpg $(KGrHqQOKnME1UQ,Ln7WBN(LC0fSqw~~0_1.jpg (34.8 KB, 91 views)
2006 Mazdaspeed 6
Tomas (03-10-2011)
 Old 03-10-2011, 10:03 AM   #13
Speeeeeed
06Speed6's Avatar
Mazdaspeed 3 rear brakes, Mazdaspeed 6 rear brakes, Mazda 5 rear brakes...
brenson likes this.
2006 Mazdaspeed 6
The Following 9 Users Say Thank You to 06Speed6 For This Useful Post:
ak_spray (03-27-2012), Awal (06-17-2015), Easter Bunny (03-13-2014), jdcms6 (03-27-2011), Lex (03-10-2011), SLOWHATCH (06-26-2013), super_pablo_ (01-09-2013), Tomas (01-25-2013), xcoldricex (03-11-2011)
 Old 03-10-2011, 11:43 AM   #14
ak_spray's Avatar
Parts.com has these brackets for $72. That's not too bad considering the list from the dealer is $104.
The Following User Says Thank You to ak_spray For This Useful Post:
 Old 03-10-2011, 02:16 PM   #15
Bob Ross Fanclub
Tomas's Avatar
These are pretty massive.
Not sure if this big would be really needed on an MS3. May be on a MS6 due to more rear weight but for an MS3 is prob a little too big. The rears don't get that much action on the MS3. The rotor is also 6 lbs heavier.
Great find. Hope someone tries it out.
The Mazda5 pad is smaller than the MS3. If you look at the pic above the shorter pad is the MAzda5 pad.
Correct about the leverage.
Incorrect about the pad.
See above brake pad surface to brake pad surface pic.
Last edited by Tomas; 03-10-2011 at 02:38 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-10-2011, 02:24 PM   #16
The Angry Goose
Hectik1's Avatar
Seems like there is a lot of weight lost by having smaller rotors. Less rotor weight is less rotational weight.
Hector
2014 Mazda 3
1979 Mazda Rx7
The Following User Says Thank You to Hectik1 For This Useful Post:
PhorB13 (08-01-2019)
 Old 03-10-2011, 02:25 PM   #17
Bob Ross Fanclub
Tomas's Avatar
Fuck. Great question. Forgot to add that you need 2008.5 or earlier brackets.
OP updated.
 Old 03-10-2011, 02:27 PM   #18
You have the same pad for the Mazda5 and Speed3 in the diagrams.
May be I didn't explain it right.
Incorrect.
See above break pad surface to brake pad surface pic.
So did you use speed3 pads or Mazda5 pads? Would speed3 pads fit?
 Old 03-10-2011, 02:41 PM   #19
Bob Ross Fanclub
Tomas's Avatar
the diagram is only for the thickness of the pad and height of the backing plate. Not the surface area of the pad.
speed3 pads.
I didn't change the caliper. Just the bracket. Pic #2. I am using the MS3 caliper with the MAzda5 bracket holding the caliper.
Wakarimaska?
06Speed6 (03-10-2011), ak_spray (03-27-2012), Easter Bunny (03-13-2014), Lex (03-10-2011), xcoldricex (03-11-2011)
 Old 03-27-2011, 06:48 PM   #20
nosaccordh22's Avatar
Posts: 30   (View Stats)
nosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the rough
Groaned at 7 Times in 4 Posts
I understand the reason for larger rotors etc. but larger rotors don't always add up to better performance. if you're using the same caliper and pad size, you're not gaining any more friction surface area, so if anything you just added weight and more rotational mass...
for those considering this upgrade, why not just invest in a better performance rotor and pad?
nosaccordh22 is offline   Reply With Quote
 Old 03-27-2011, 10:00 PM   #21
Bob Ross Fanclub
Tomas's Avatar
It depends how you look at it.
A brake rotor is really just a heat sink. Any BBK you buy will get you a larger and/or thicker rotor. If you follow your logic than a BBK would really not be of any benefit.
The reason for using a larger rotor is to increase the ability of the brake system to increase its heat absorption capability where the brakes do not get so hot you start getting brake fade or other symptoms associated with overheating of the brake system. For DD this is certainly not needed. But when you do track work it is quite possible your rotors will get so hot the heat seeps into the caliper and your fluid starts boiling = brake fade or worse no brakes at all. A high heat pad is obviously the first thing you should do before upping up rotor size, but if the pad gets too hot because the rotor is too hot, the pad will start to lose its ability to bite into the rotor to slow it down.
ak_spray (03-28-2011), xcoldricex (03-28-2011)
 Old 01-09-2013, 12:01 PM   #22
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
old thread is old... but I just wanted to follow up on something, as well as comment on your last post @Tomas
... I feel that, while your statement is true (about larger size, heat absorption and shit)... thats really irrelevant for the rear rotors, at least in our platform...
so really, it comes down to, is the increase in torque worth the 70-100 buck bracket?
Did anyone else did any more testing on track?
Im changing my rear pads for more rear bias, but also was considering this... whats the concluding point on it? Worth it or not?
 Old 01-09-2013, 02:17 PM   #23
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
also interested in hearing. @tomas im assuming you have tracked the car since, was the shift in bias due to the greater torque noticable?
breakfasteatre is offline   Reply With Quote
 Old 01-09-2013, 02:41 PM   #24
Bob Ross Fanclub
Tomas's Avatar
Was the rear brake torque on the rotors higher with the bigger rotors / sort of more rear bias? Yes.
Was the difference eye popping huge? No
Could it be placebo effect? May be.
I would only recommend the upgrade if your rear rotors need to be replaced. Then, you might as well get the Mazda 5 ones and the bracket. IMO there is nothing like simple bolt on OEM upgrades such as this one. Much simpler and cheaper than multi piston calipers and hydraulic e brakes. There is actually a name for this type of upgrade I just don't remember what it is.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
breakfasteatre (01-09-2013), Easter Bunny (01-10-2013), Fobio (01-09-2013), super_pablo_ (01-10-2013)
 Old 01-09-2013, 06:12 PM   #25
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
OEM+?
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 01-09-2013, 07:06 PM   #26
Bob Ross Fanclub
Tomas's Avatar
I remember talking to a KNS brakes dude over the phone when I ordered pads once telling him about the conversion and he mentioned they offered the same thing for Subarus. He called it some fucking name but I am senile. Or may be the dude was on crack. Either option is viable.
Easter Bunny (03-13-2014), silvapain (01-10-2013)
 Old 01-10-2013, 09:32 AM   #27
fredricktsang's Avatar
Posts: 459   (View Stats)
fredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the world
a lot of guys with the earlier 1.6 miatas do this and swap the bracket with the later 1.8 rear brakes. I've heard the term "brake conversion" used all the time. But regardless, it works, I might try this when it comes time to do my brakes. First probably get myself a pyrometer to see brake temps after hard driving/tracking to see where temps are at and do a before and after comparison.
fredricktsang is offline   Reply With Quote
The Following User Says Thank You to fredricktsang For This Useful Post:
Tomas (01-25-2013)
 Old 01-10-2013, 09:37 AM   #28
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
When I go my stoptechs I got the mazda5 rear kit as well to keep the balance the same. Even so I think the car has ebfd so I'm not sure how much of a difference it will make.
Fueled by the haters.
Celestspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
super_pablo_ (01-10-2013), Tomas (01-25-2013)
 Old 01-10-2013, 09:56 AM   #29
Nliiitend1's Avatar
Indeed it does.
2008 MS3 GT
2016 MX-5 Club
The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post:
Celestspeed3 (01-10-2013), super_pablo_ (01-10-2013), Tomas (01-25-2013)
 Old 01-10-2013, 02:16 PM   #30
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Hydraulic e-brake FTMFW. I want one so I can do rally-style handbrake turns.
I'm such a fucking ricer.
Tapadatass
The Following 3 Users Say Thank You to silvapain For This Useful Post:
Easter Bunny (03-13-2014), Tomas (01-25-2013), Vader (01-10-2013)
 Old 01-25-2013, 04:44 PM   #31
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
sorry to bring back from the dead...
has anyone measured whether the ms6 rear bracket can be used with the ms3 rear calipers? Might as well go with the bigger rear ms6 rotors...
sil80
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline   Reply With Quote
 Old 01-25-2013, 10:41 PM   #32
Bob Ross Fanclub
Tomas's Avatar
^ No. But post 13 has some info on the MS6 rear brakes.
 Old 01-25-2013, 10:43 PM   #33
BAT-man's Avatar
I saw that but can't really get the bolt offset from it... might have to just order a bracket and see if it fits....
 Old 06-26-2013, 08:16 AM   #34
DuoofDeath1's Avatar
Posts: 393   (View Stats)
DuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the world
I may have missed this but does anybody know the part number for the Mz5 bracket I need?
2014 Snowflake White Pearl Mazda 3 2.0l 6spd Hatchback
2012 Black Mica Mazdaspeed3 - Sold
2004 Strato Blue Mazda 3 2.3L 5spd Hatchback - Sold
DuoofDeath1 is offline   Reply With Quote
 Old 03-13-2014, 01:29 PM   #35
Mr Wilson's Avatar
Posts: 120   (View Stats)
Mr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the world
^^^That.
I've recently tried dealing with some of the local forum's Mazda dealers as we get a discount and have been met with nothing but grief. They want the VIN to make sure the part is correct......apparently without that they cannot confirm it is the correct part. It's the f*cking rear caliper bracket!!! how hard is that. Even when I explain I do not have an Mz5 they still ask for the VIN.
@Celestspeed3; do you remember?
2008.5 CWP SPEED3
MODS TO DATE: KW V3 Cobb AP V3, RSB, STS TWM Shifter Extender Sure Shortcut, Countershift CP-e Tow Plate, FMIC, HPFP, DP, Exhaust Manifold, HeliHose, PMM/TMM, Nexus CBE, Injector Seals TiAL bpv JBR WP, Solid Shifter Bushings, TB/IM Gasket, RMM Celestspeed3 Coolant Bypass DBA 4300 T3 Hawk HP+ Denso itv22 Saikou Michi OCC DGM Lip HTP Slim Battery Tray SilverDemon EGR Block Off Rays Volk TE37 SL 18x9.5 +22, Formula Lugs Bridgestone RE-11 265/35-18 SilverDemon EGR Delete Kit Stratified ECBS, 3-Bar Map Sensor Intake Manifold PnP
Mr Wilson is offline   Reply With Quote
 Old 03-13-2014, 02:20 PM   #36
Crarrs's Avatar
Posts: 1,662   (View Stats)
Originally Posted by Mr Wilson View Post
^^^That.
Where's the ingenuity?
Here's a couple VINs I just got off cars.com by searching for a pre-2009 MZ5.
JM1CR293170144730
JM1CR293270154196
2004 MSM TiGrey
The Following 5 Users Say Thank You to Crarrs For This Useful Post:
802MS3 (03-13-2014), Easter Bunny (03-14-2014), El_Diablo (03-17-2014), Mr Wilson (03-13-2014), Tomas (03-13-2014)
 Old 03-13-2014, 05:59 PM   #37
Mr Wilson's Avatar
Hahaha thanks @Crarrs;
Ended up finding a Parts Manager that just understood what I was looking for. It wasn't so much finding a VIN (+ not sure if it would throw them off even more with a US VIN), more of the fact I don't get how that would confirm anything for them.
He said they have them in stock, so I'll pick them up tomorrow and post some numbers.
2008.5 CWP SPEED3
 Old 03-14-2014, 06:44 AM   #38
Mr Wilson's Avatar
Part # C2Y6-26-28XA they were just over $60 CAN each.
Now mine does not have the sliders in the OP's picture. Assuming I can carryover the stock ones, or should I just get new?
2008.5 CWP SPEED3
The Following 2 Users Say Thank You to Mr Wilson For This Useful Post:
El_Diablo (03-17-2014), Mattyhawk1 (03-18-2014)
 Old 03-14-2014, 01:10 PM   #39
speed3 britz's Avatar
Posts: 1,155   (View Stats)
They unthread from the old brackets and install on the new ones. Ive been running this swap conversion for awhile now
The Following 3 Users Say Thank You to speed3 britz For This Useful Post:
Awal (06-17-2015), Mauro_Penguin (03-15-2014), Mr Wilson (03-14-2014)
 Old 08-25-2014, 07:51 AM   #40
bhigdon101's Avatar
Posts: 37   (View Stats)
bhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nice
Part # C2Y6-26-28XA is for the right side only and dont fit the mz5 pre 08...
doing my brakes soon and would like to add this to the list..
wanted to make sure its the right part number.. looks like it for the 13 touring m3...
any help would be great....or link..
2012 white ms3|G2 caliper paint|jbr shifter bushings|jbr short shift linkage|jbr shifter weight| matt damond 3some\3 bar map\3 port ebcs\3.5 htp intake\egr delete\coolant bypass\ets tmic\small batterybox\yellow top battery\autotech hpfp/accessport v3\corksport bpv\corksport springs\koini yellows\freektuned on 93\ UR race pipe\jbr com rear swaybar\ebc redstuff pads\
bhigdon101 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/mazda-5-rear-brake-conversion-74274/
Rear Brake Conversion ? Mazda MPS Owners Club This thread Refback 07-10-2013 04:55 AM
rear brake calipers qtrmile beast MazdaSpeed 3/6 - Suspension & Brakes 0 02-22-2011 11:56 AM
Right rear brake pad gone HefMS6 MazdaSpeed 3/6 - Suspension & Brakes 9 11-12-2010 04:52 PM
has anyone had rear brake issues? long101 MazdaSpeed 3/6 - Suspension & Brakes 8 05-07-2009 01:52 PM
Page generated in 0.61163 seconds with 42 queries
