> MazdaSpeed 3 - How-To's
Like Tree15Likes
 Old 09-02-2014, 10:11 AM   #81
Posts: 2,237   (View Stats)
ok and after connecting it, you can go into some Torque menu about the obd device and you can check it's status to know how much pids/sec you can get.
The 15$ one usually give 15-20 and yours state 5 times faster so i would expect 75-100pids/sec
 Old 09-08-2014, 10:30 AM   #82
speedaholic's Avatar
Posts: 154   (View Stats)
speedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the world
Originally Posted by DevinTheDood View Post
Will report back with results.
So mano, did you get a chance to try it out? I'm getting random disconnects with my eBay adapter when hitting hard bumps so if that OBD link is significantly quicker, I might splurge and get one.
2015 Black Mustang GT
RIP 2015-06-27
2013 Liquid Silver MS3
speedaholic is offline   Reply With Quote
The Following User Says Thank You to speedaholic For This Useful Post:
DevinTheDood (09-08-2014)
 Old 09-08-2014, 10:46 AM   #83
I got similar issues, i tried tu bend copper terminal bus on the adapter itself and it helped a little but it looks like the MAzda connector seem to get loose over time.
speedaholic (09-08-2014)
 Old 09-08-2014, 12:12 PM   #84
DevinTheDood's Avatar
Posts: 118   (View Stats)
DevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the world
I'm happy to report that I havn't had one drop since switching to the obd link adapter... And boy is it fast! Getting 75 PID/s consistently and I love the auto sleep mode so you can leave it plugged in without batt drain
I did experience a little quirkiness with the genpu specific plug in PIDs vanishing after changing the adapter but uninstalling and reinstalling the plugin fixed it.
CS SRI+TI+Racepipe+SSP+anchors+TMIC / CPE "stage 2" RMM / HKS SSQV recirc / Autotech internals / AP Stage 2 91 OTS / NGK's 1 step cold/ Knob
DevinTheDood is offline   Reply With Quote
The Following User Says Thank You to DevinTheDood For This Useful Post:
 Old 09-08-2014, 12:25 PM   #85
Sweet, thanks for the report! Did you notice any improvement latency wise? I have a 300-400ms lag and don't know if it's because of bluetooth or the adapter.
RIP 2015-06-27
 Old 09-08-2014, 12:31 PM   #86
A_tired_goose's Avatar
Posts: 66   (View Stats)
A_tired_goose has much to be proud ofA_tired_goose has much to be proud ofA_tired_goose has much to be proud ofA_tired_goose has much to be proud ofA_tired_goose has much to be proud ofA_tired_goose has much to be proud ofA_tired_goose has much to be proud ofA_tired_goose has much to be proud ofA_tired_goose has much to be proud of
Just downloaded this at work today since I was bored and trying to remove the default displays that come up in realtime mode. I don't have my OBD yet but how do I remove all those 1/4 mile time things etc and replace them with KR, Boost (I think is already there), fuel rail pressure, etc ?
EDIT: Im dumb and didn't long press the different displays themselves..figured it out
SMH
A_tired_goose is offline   Reply With Quote
The Following User Says Thank You to A_tired_goose For This Useful Post:
 Old 09-08-2014, 12:40 PM   #87
I haven't been able to precisely analyse it yet, but for me there was a noticeable increase in speed with my MANY PIDs as well as a reduction in lag. The RPM is now in tandem with the stock gauge cluster. Most if not all the perceivable lag is gone. It's really fast and I'm really happy with it compared to my results with the cheapie.
Is there place where you can check the latency just like the PID speed? I'll have to check again cause I don't remember seeing that.
 Old 09-08-2014, 02:10 PM   #88
No there isn't, only by eyeballing. But if you can't really notice any lag, then it's definitly quicker as with mine it's really obvious. Looks like I'll be placing an order for one of these tonight!
Thanks for the info!
RIP 2015-06-27
 Old 09-08-2014, 03:20 PM   #89
Good news! but since you have a gen pu, i wish to get same on my gen one.
It is time to order one! i may choose the LX green one that is cheaper but claim same speed...
 Old 09-08-2014, 04:36 PM   #90
Ozynigma's Avatar
Posts: 743   (View Stats)
I just ordered green. The more expensive one has access to GM and Ford codes that is don't need and don't want to pay extra for.
The Following User Says Thank You to Ozynigma For This Useful Post:
 Old 09-08-2014, 04:40 PM   #91
Ya the lx will be a great option - I only sprung for the mx because I do intend to also use it as a diagnostic tool on other vehicles
 Old 09-12-2014, 07:04 PM   #92
Ozynigma's Avatar
I have encountered a problem using Torque on my CX7. This is early days so I don't have all the error codes etc.
The story so far:
Bought a used Kiwi bluetooth adaptor and installed Torque on an Android tablet.
This created network comms errors, typically on restart and reported 11 adaptor errors.
It would set all the dash warning lights off and required a fault code reset. Car ran fine regardless.
Thought I might have a dud adaptor so I ordered an LX.
Installed LX yesterday and it tested fine.
Same thing happened when I restarted the car this morning.
My question is has anyone else had the adapter cause network comm errors on their Mazda?
I will try and recreate the error and collect the error codes when I get a chance this weekend.
 Old 02-01-2015, 12:48 PM   #93
@DevinTheDood can you tell us more about what you can read under the adaptater status when using torque. I will appreciate.
Is there showing ''obdlink'' under device name with a special version? I ask because i bough an obdlink that seem to ba a scam, as it isn't faster and still show ELM327 V1.5 there when connected to it. The speed is even slower than my first ELM327. The plastic case it identical but seem to have chineese stuff inside...
DevinTheDood (02-01-2015)
 Old 02-01-2015, 12:59 PM   #94
The story so far:
That's really weird. With my first adapter, 10$ ebay long format, I would get random disconnects when hitting large bumps on the road but nothing like what you describe.
@Jeff23spl; I'm quoting @DevinTheDood; for your question man.
RIP 2015-06-27
 Old 02-01-2015, 02:58 PM   #95
Default RAISE THE ALARM!
Great........ yeah it definitely sounds like you have a counterfeit adapter. Under "adapter status" my adapter is clearly identified as "ObdLink MX" with a mac address-like number following. I am also able to enable the "faster communication" setting without issues. Also the speed itself is telltale. The ODBLink MX/LX is so much faster that when I load an RPM gauge it's nearly perfectly synched to my stock RPM gauge. Night and day compared to the cheap adapter. I also had random disconnect issues that became CONSTANT with my first cheapie adapter just like @speedaholic; has.
Where did you purchase this adapter? Can you post some pics? We need to raise the alarm if someone is now hocking counterfeit OBDLinks!
I purchased mine directly from amazon right around the time they first starting selling the OBDLinks as stated earlier in the thread. I would hope that this is still a safe way to go besides ordering directly from scantool.net (for a bit more $$$).
 Old 02-01-2015, 03:01 PM   #96
The stupid thing with Amazon is they won't sell a product on the Canadian site if it doesn't have bilingual packing and instructions. Thanks to our pathetic French Quebec government!
RIP 2015-06-27
 Old 02-01-2015, 03:12 PM   #97
That is pretty silly...
I noticed that the regular price for both the LX and MX has gone down on the scantool.net site and isn't too far from amazon's price now. I double checked and they ship to secessionist french-Canada
speedaholic (02-01-2015)
 Old 02-01-2015, 06:30 PM   #98
Thanks, that's good news! I'll finally pull the trigger on one that wont cost 150$ haha.
RIP 2015-06-27
 Old 02-02-2015, 02:26 PM   #99
the bad copy i just received was this one. They already modified the text of the ad since i bough it. I remember about reading a copy of the description found on scantool.net about the LX or MX reading speed and other sentences. This make me decide to try it , i knew it gonna be a chineese copy but it could have been a new design working better but it isn't. It isn't a complete lost since it works fine for what it is but this would be my third BT dongle....I should re-sell them and buy a good one...
The only confusing part remaining from the add is that one:
''Greatly increased data throughput delivers faster screen updates and more graph points''
or
''Advanced commands to perform enhanced diagnostics not possible with older ELM327-based scan tools''
Obdlink SX Bluetooth Scan Tool USB OBD2 II Module Scantool With OBD Software SC | eBay
 Old 02-02-2015, 04:05 PM   #100
Well that's a little less counterfeit and a little more obvious knock off. The old saying now goes: If it looks like a duck and it sounds like a duck it's still NOT a duck cause you bought it on fracking Ebay.
I commend you for testing the waters on a new product and I'm glad you're not out much $$
 Old 03-09-2015, 09:40 PM   #101
aackthpt's Avatar
Posts: 1,450   (View Stats)
I wanted to get this set up, but when I looked in play store the Mazdaspeed plugins for Torque don't seem to be present. Anyone know WTF??
According to google search they should be at:
gen1: https://play.google.com/store/apps/d...eed.gen1&hl=de
gen2: https://play.google.com/store/apps/d...eed.gen2&hl=fr
My understanding was that the plugin checked for licensing or whatever fairly often. Is torque+plugin still working properly for everyone?
 Old 03-11-2015, 10:39 AM   #102
mine still works...Just don't rely on just the knock retard reading from this app. when using a cheap elm327 as you may miss some data.
aackthpt (03-13-2015)
 Old 03-13-2015, 07:16 AM   #103
ElectroShock's Avatar
Posts: 46   (View Stats)
ElectroShock is a splendid one to beholdElectroShock is a splendid one to beholdElectroShock is a splendid one to beholdElectroShock is a splendid one to beholdElectroShock is a splendid one to beholdElectroShock is a splendid one to beholdElectroShock is a splendid one to behold
For me, the newest version of torque doesn't want to register the PID's from the addon. The addon shows under the plugins menu, but when I go to add the custom PID's the Mazdaspeed option doesn't exist.
2009 MS3 - True Red
CS HPFP - HTP 3" Intake - CS TIP - CS Race RMM - M2 TP - GFB VTA BPV - Cobb APv2
Torque Pro + MS3 Gen 1 Addon
Fathead Tuned
ElectroShock is offline   Reply With Quote
The Following User Says Thank You to ElectroShock For This Useful Post:
 Old 03-13-2015, 07:59 AM   #104
aackthpt's Avatar
Sounds like maybe the plugin didn't grab licenses and the system went kaput. That sucks!
 Old 03-13-2015, 08:06 AM   #105
You have to be connected the interwebz to load the plugin for the first time and for random liscence checks. It sucks and I mentionned the problem to Matt Jackson but I don't think he'll update anytime soon.
Try to uninstall/reinstall both app and plugin and connect to wifi/data when loading it.
RIP 2015-06-27
 Old 03-13-2015, 08:17 AM   #106
not sure if you need to un-install re-install but for sure, you need to be connected to a wifi or internet for a while before being able to run the add on.
When i occasionnaly lose the WG duty and KR reading, i have to bring me phone home to be connected to a wifi for a while, and then, open torque, and wait again to let the add check into it's web data if i have a paid licence, and then, try to load the pluging for the speed with configuraiton menu from torque. Sometimes i have to close and re-open the torque app and wait longer to see the speed plugin availaible. It sucks when you are in a hurry...
Curiously, i also experienced some issues if i shut off the car when torque continue running. If i restart it without restarting torque, only the basic data works and i have to reboot torque to get specific speed pids to work again.
MattJackson86 (03-13-2015)
 Old 03-13-2015, 08:57 AM   #107
aackthpt's Avatar
Uninstall/reinstall? Heh, at this point I can't even get it working in the first place.
 Old 03-13-2015, 09:14 AM   #108
Yep the plugins aren't on Google Play anymore... Seems you are shit out of luck. Maybe @MattJackson86; can help you out?
RIP 2015-06-27
 Old 03-13-2015, 02:55 PM   #109
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Im trying to figure out why they got removed from Google Play...
EDIT: Sorry guys, google removed me for not accepting some new license. It should be back up on the store in a few hours.
As others have said, yes you need to be on the internet every now and then for it to validate your purchase. That being said, it seems to be a major headache for some people recently and I do plan on removing that. I hope to get to it very soon (said that before I know). Had some personal issues last few months but should be good to get that done asap. I will keep you updated.
Sorry again for the issues.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline   Reply With Quote
The Following 4 Users Say Thank You to MattJackson86 For This Useful Post:
aackthpt (09-11-2018), ElectroShock (03-14-2015), JSmith (03-14-2015), speedaholic (03-14-2015)
 Old 03-14-2015, 10:19 AM   #110
It is working now! Thanks
2009 MS3 - True Red
Fathead Tuned
 Old 03-14-2015, 07:22 PM   #111
okspeed's Avatar
Posts: 127   (View Stats)
okspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond repute
How do you get it to clear codes?
okspeed is offline   Reply With Quote
 Old 03-16-2015, 08:43 AM   #112
you have to return to Torque menu and choose the ''Fault codes'' application, and then, read all codes. Then, use the cellphone ''option'' button to open the menu giving access to clear it and use it.
Maybe the ''fault codes'' add on need to be downloaded separately, i don't remember...
 Old 03-17-2015, 02:42 PM   #113
aackthpt's Avatar
Thanks for getting it back up, I got it set up. Have monitoring, will travel.
2013 'speed3, silver
Stage Bro
 Old 03-22-2015, 07:45 AM   #114
localnj's Avatar
Posts: 6   (View Stats)
localnj will become famous soon enough
But is that half a second really a big deal? Torque is not really for logging, but rather live monitoring. If I was datalogging, the lag would be an issue, but for live monitoring it should be sufficient. I guess I'll see when I get my adapter.
I have some PIDs that might work.
Knock retard:
PID - 1746
Equation - (A*90)/256
WGDC:
PID - 16E1
Equation - (A*100)/256
BAT:
PID - 1723
Equation - (A-64)*625/1000
VVT Advance:
PID - 1724
Equation - (A*35)/255
These may or may not work, but they are worth a shot.
Thanks for these! I was able to get readings off all these PIDs. In order to get them to work correctly, I needed to add the mode to the PID (22). So PID 1723 is entered as 221723, etc. I also needed to type in "auto" on the obdheader line, then they all seemed to read fine. The only equation I haven't tested is for the BATs, as I had used a different equation to set up in Celsius, and then had convoluted that one to create a Fahrenheit one. Just haven't had a chance to run this equation yet and compare. It's hard to tell on the BATS imo, because even with no equation entered (just "A" on the equation line) the PID reads a reasonable number typically for my test around 110. However as temperatures were below 50 during my test and I was highway cruising mostly, this BAT seemed inaccurately high (+60). Using the other formula I plugged in got me BATS in the 30-40 F (20ish C) ranges, which seemed more normal. Thanks for posting these Sidekick!
sidekick likes this.
localnj is offline   Reply With Quote
The Following User Says Thank You to localnj For This Useful Post:
sidekick (03-29-2015)
 Old 03-24-2015, 11:21 AM   #115
crutch77's Avatar
Posts: 493   (View Stats)
crutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the world
Any progress on the 3 bar MAP sensor issue? I've got an LX adapter arriving today, and I've been playing with the app a bit. Are you only able to manipulate the formulas for custom PIDs?
2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it)
crutch77 is offline   Reply With Quote
 Old 03-24-2015, 05:23 PM   #116
crutch77's Avatar
I just tried everything out for the first time, and contrary to what I expected from reading this thread, having a 3 bar MAP sensor doesn't seem to be an issue for me. I haven't gone for a drive yet, but at least the vacuum level is what I am accustomed to while idling (AC on and AC off). I'll report back after I drive to work tomorrow.
 Old 03-24-2015, 07:37 PM   #117
sjdannen's Avatar
Posts: 42   (View Stats)
sjdannen is just really nicesjdannen is just really nicesjdannen is just really nicesjdannen is just really nice
Default Losing Mazdaspeed PIDs everytime phone goes to sleep
Does anyone else have the problem where you have to re-add the Mazdaspeed plugins every time the phone goes to sleep?
I will add the plugins and go back to the gauge display and everything is happy. Shut the car off, which puts Torque to sleep and eventually turns off the display. Turn the car back a little while later, swipe to unlock the phone and the PIDs on the gauge display that came from the Mazdaspeed plugin no longer refresh. Go back to the manage PIDs area and the list is empty until I re-add the plugins, then they work again... until I turn off the car.
sjdannen is offline   Reply With Quote
 Old 03-24-2015, 08:45 PM   #118
frothy's Avatar
Posts: 1,067   (View Stats)
See post #109 above...
The issue stems from the app wanting to check-in and validate that it's legit every so often. I had a similar experience to your own and became annoyed enough that I rooted my phone and patched the addon with Lucky Patcher. That did the trick.
Matt states above that he's looking into removing the check-in feature, but it's been a well known problem for YEARS and I don't think i've ever seen the Mazdaspeed PID Addon altered or improved in any fashion since its release.
sjdannen (03-25-2015)
 Old 03-24-2015, 09:11 PM   #119
I'm going to assume your device is wi-fi only and Wi-Fi is being disabled when in sleep due to your device settings. This means that when the device comes out of sleep with torque running it fails an authentication check for the plugin.
Unless I'm mistaken, the author has said above that he will be removing this as many of us have had this problem.
The only way I could avoid this on my wifi only tablet is by exiting torque every time I turn off my car. For some reason it doesn't try to authenticate if your wifi is enabled but not connected. Therefore, the other option is to set your tablet to leave wifi on when asleep which is far from ideal for most.
Having wifi turned off when starting/resuming torque seems to bork the plugin instantly. Basically when you are putting your tablet to sleep, wifi is getting turned off and isn't back on in time to prevent the plugin's authentication failure when you come out of sleep with torque running.... hope that makes some kind of stoner sense.
Here's to hoping all of this is removed soon as it's the only serious bug I've encountered.
Thanks to everyone involved for all your hard work!
 Old 03-25-2015, 06:13 AM   #120
crutch77's Avatar
I can confirm that boost displays accurately with a 3 bar MAP sensor on my Gen 1. I didn't have to do anything special with the Torque app.
COMPLETE HOW TO GUIDE MS3Axela703 MazdaSpeed 3 - How-To's 28 11-05-2014 03:47 PM
Abilor Guide Help for VT SpeedRebirth MazdaSpeed 3/6 - ECU Computer Tuning 10 04-08-2013 02:50 PM
My maintenance guide cham87 Gen2 MS3 General Discussion 8 10-31-2012 07:30 PM
Torque Wars: 2011 Ford Super Duty Now Tops GMC Sierra 2500 with 400 hp and 800 lb-ft of Torque Haltech Automotive News 0 08-03-2010 07:30 AM
FFS and LC in the new tuning guide twisted99
Cobb ATR Support
4 07-23-2009 12:25 AM
Page generated in 0.62254 seconds with 33 queries
