| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
(Thread Starter) | Not Ranked : 0 score First you want to drain your oil. After that remove the canister and as well as the let all the oil sensor pressure so you have greater access to the 4 bolts you have to remove. This picture shows the oil pressure sensor removed. After that remove the 4 bolts that hold the oil cooler on they are 10mm iirc The biggest challenge you will have is getting off the drivers side top bolt but if you use a wobble extension on a 1/4 inch drive it will get to it will ease. Once you have those out pull the the oil cooler down and take off the bolt that holds it in place. That will be a 15mm on the top of the cooler, here is a picture. Once you take that out the cooler will be able to come off. Next we got out sammich plate and spin on conversion ready with all the plugs. Leave the sensors off till last so they dont get in the way of putting everything back on. Make sure and use thread sealant liquid and not teflon tape on these fittings ![]() After all that re-install in reverse order and this is what the final product should look like. |
| The Following 13 Users Say Thank You to EdgeAutosport.com For This Useful Post: | breakfstincluded (07-09-2012), Code Monkey (07-09-2012), Dahouse702 (07-09-2012), flappypaddles (09-05-2015), GAMISTAD (07-09-2012), Gibbo (11-03-2013), mazdafreak (07-30-2013), ms3blackmica (07-10-2012), Ms3_Miami (11-17-2012), Raider (07-09-2012), redmnsterut (07-09-2012), SKiZ0TT (07-09-2012), TiGraySpeed6 (07-09-2012) |
| Not Ranked : 0 score Thanks!
| The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | codykemmet (07-09-2012), EdgeAutosport.com (07-09-2012) |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score I think I might be blind but... I didn't see it, do you guys sell the spin on oil conversion? I definitely saw the sammich plate.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| The Following User Says Thank You to breakfstincluded For This Useful Post: | EdgeAutosport.com (07-09-2012) |
![]() Join Date: Nov 2009 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,342
Groans: 33
| Not Ranked : 0 score Very cool and definitely on my shopping list to get.
__________________ 2008.5 MAZDASPEED3 GT - SOLD 2004 MAZDASPEED Miata |
| The Following User Says Thank You to SKiZ0TT For This Useful Post: | EdgeAutosport.com (07-09-2012) |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | breakfstincluded (07-09-2012) |
| Not Ranked : 0 score eric, what gauge is that?
| The Following User Says Thank You to superskaterxes For This Useful Post: | EdgeAutosport.com (07-10-2012) |
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | EdgeAutosport.com (07-09-2012) |
(Thread Starter) | Not Ranked : 0 score They are stack gauges and iirc they are found in the lotus's of le world |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | TiGraySpeed6 (07-09-2012) |
| Not Ranked : 0 score fml teh $$$$$
| The Following User Says Thank You to superskaterxes For This Useful Post: | EdgeAutosport.com (07-09-2012) |
![]() Join Date: Mar 2012 Location: Colorado Springs, CO
Rep Power: 831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 727
| Not Ranked : 0 score very nice, thank you for this. the one i ordered from you guys is sitting in my garage till the next oil change.
__________________ 2013 Mitsubishi Lancer Evolution GSR ![]() BT & All Eth Mix - 460hp/429tq Pump - 411hp/403tq **SOLD** [02:58 PM] dturboman: and ZZB will happen one day, its just how long you can avoid it for [09:15 PM] Erich: if you aren't notching your block, your turbo isn't big enough |
| The Following User Says Thank You to sassyspeed3 For This Useful Post: | EdgeAutosport.com (07-09-2012) |
![]() Join Date: Mar 2012 Location: Portland, Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score The only thing i would add, and this was only my personal experience with the MS6. when removing the oil cooling module on top the oil dongle, you can reach it from the top of the engine very front in between the block and radiator. just look for that 15mm bolt on top, it is VERY easily accessible this way and a extension on your socket wrench, loosen it before you take the bolts off the original oil "dongle". it was a PITA to try to loosen it after the original dongle was off, just couldn't get enough Torque to break it loose. Also the Gasket that goes from the cooling system to the new spin on, make sure your gasket is seeded right, it has dots on it for the cooling system, if you dont get those lined up you will have a very very slow yet annoying leak between the spin on and cooling system.
__________________ 2007 MS6 - CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP 2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD SOLD 1992 Corrado VR6 268 Cams, air intake, cat back, upgrade plugs and wires, coilovers. SOLD 2001 Audi Allroad SOLD 2006 MS6 - CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%, 19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA, TUNED BY LEX FOR 330 AWHP / 380 TQ Custom tune by The habits we form today are the ones that Define us tomorrow |
| The Following 2 Users Say Thank You to Speeden6 For This Useful Post: | EdgeAutosport.com (07-09-2012), GAMISTAD (07-09-2012) |
(Thread Starter) | Not Ranked : 0 score JP just told me ordered 20 units so let me know who wants spin on love |
| Not Ranked : 0 score I assume its still 6qts with spin on filter? Or is it still 6qts but theres even lesss risk of overfilling now
| The Following User Says Thank You to breakfstincluded For This Useful Post: | EdgeAutosport.com (07-10-2012) |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score I just want to clear a couple things up because I'm fucked up that way. The aluminum part that bolts to the block is the housing. The black part attached to the top of the housing is the oil cooler. Try to loosen that 15mm oil cooler bolt before you remove the housing. It's a bitch when it's off due to lack of leverage. Plus, it's on there pretty tight. Also, if you are using teflon tape on the sandwich plate fittings, be sure to set it back about 3 or 4 threads from the tip to ensure it doesn't get into your oil. |
| The Following 2 Users Say Thank You to Dash08 For This Useful Post: | EdgeAutosport.com (07-10-2012), memin (08-26-2012) |
| Not Ranked : 0 score i like the word "Dongle" better than "housing" but that is just me. J/K! thanks for correcting my horrible part descriptions!
| The Following 2 Users Say Thank You to Speeden6 For This Useful Post: | Dash08 (07-09-2012), EdgeAutosport.com (07-10-2012) |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score Hmmmmm,.... Kostet Das ??
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
![]() Join Date: Jul 2009 Location: Sulphur, LA
Rep Power: 173 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 116
| Not Ranked : 0 score Anybody do this and have their oil cooler gasket look like this??? If so, did ya reuse it and was it OK? I got into an accident and oil was leaking from my oil cooler, but I'm curious if it was just knocked loose as the bolt holding it on was not hard to get off at all, or if this is a no go and I need a new oil cooler http://www.mazdaspeedforum.org/forum/foru...mg_7201-1-.jpg
__________________ '09 MS3 Sport, cp-e Xcel™ CAI w/Hydroshield, Cobb TIP, Forge BPV, TRZ RMM, JBaron SSP, MSD DH w/cp-e mount, Koni FSD's, Viper 5701 Remote Start/Alarm, AVIC-F700BT & JL 8W7 in Modified Stealthbox Last edited by free_refil; 08-26-2012 at 11:55 AM. Reason: Pic damn big |
| Not Ranked : 0 score There's a thread you can find by searching "spin on" i saw here. A guy did his spin on and was leaking after, he took it off and looked at it and found the O-ring was severed in the outer right, it lookede like it fit just right otherwise. But that tiny little thing caused the leak.
| The Following 2 Users Say Thank You to breakfstincluded For This Useful Post: | free_refil (08-26-2012), TiGraySpeed6 (08-26-2012) |
![]() Join Date: Feb 2014 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Necro Posting here, but could you possibly refresh this post so the pictures are viewable again. I bought this spin-on kit a month ago and about to attempt the install and would love to see the pics. "off to youtube for a video"
__________________ |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Neutral : +1 score @APEXistud; Try this. The pics in this thread works for me. Someone else posted the link info on here, not my find https://addons.mozilla.org/en-US/fir...d-fix/?src=api |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/oil-spin-sammich-plate-how-118433/ | ||||
| Change oil filter - Page 3 | This thread | Refback | 11-23-2012 08:00 AM | |
| How to do a spin on and sandwich plate conversion | rodrigo | MazdaSpeed 3 - How-To's | 102 | 09-15-2011 09:58 PM |
| prosport sammich plate | phillyb | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 05-18-2009 11:21 AM |
