| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
(Thread Starter) | Not Ranked : 0 score Step one pull the valve cover. For those that have a TMIC pull that first. At this point you will see the cams and the timing chain. Also while you are in there take a look on the underside of the valve cover above where the timing chain is to see if the chain has been hitting the valve cover. This is an indication that the chain may have been hitting and that is a sign of your chain or tensioner is going bad. Next step is to pull the high pressure fuel pump housing: Here are the bolts to the fuel pump housing. Removed.... This line goes to the fuel rail.. Fuel pump harness and Feed and Return line: Next install your blind plug. Note i pulled one of the timing cover bolts and installed that in the BLIND PLUG hole. make sure you use the UPPER BLIND PLUG HOLE to do this. Also when installing it there is no need to TORQUE is down just go far enough til you feel a little tension. TIP: It might be best to use a 1/4in ratchet for this... This step is down so that when you loosen the exhaust cam sprocket to get the chain loose you will not loose tension on the tensioner because the timing chain guide will prevent that. Next pull the EXHAUST CAM sprocket. Next step is to pull the cam caps: NOTE on the cam cap you will see numbers on each of them. Pay attention to the letters and the arrow that are inscribed on each of the caps. This pic shows the inscribed letter E 2 and also you see the arrow. The "E" is for exhaust and the "2" is for the second cap and the arrow is the direction the arrows should be pointing. Now just lift your cam out of the head.. This is what it looks like with the cams out..
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 10-18-2012 at 03:08 PM. |
| The Following 8 Users Say Thank You to qtrmile beast For This Useful Post: | aaron_-01 (10-18-2012), Alpha (10-18-2012), BobbleHead (10-18-2012), Neubreed (01-10-2014), Roddiy (10-18-2012), speed14 (10-18-2012), Speed3eak (10-18-2012), TiGraySpeed6 (10-18-2012) |
(Thread Starter) | Not Ranked : 0 score Now putting it back together............ If you didn't already have the pistons at TDC this is how you can find it.... VIDEO (This video is without the timing cover on) This is for those that have the cover still installed and want to see what the crank bolt is doing.. If you done have the proper SST (CRANK ALIGNMENT TOOL) don't worry you can use this.. when you have found TDC install this until you feel a little tension. You dont have to tighten down as there is a flat spot on the crank that this will rest on and will prevent the crank from turning. FYI this will not prevent the crank from turning if you are trying to loosen the CRANK BOLT only when tighting it. No need to do anything with the crank bolt for this how-to FYI... Now that you have found and lock down TDC you can install your cams. Again there is no need to pull the timing cover... Make sure that when you install the cams that the first lobe on the passengerside of the motor(timing chain side) are almost pointing to each other (ie. The exhaust cam lobe is pointing toward the intake cam lobe. This is TDC for the cams. Make sure this is done BEFORE you install the cam caps. Now install your cam caps with the exhaust caps all are pointing in the same direction and in order by number. Do that same for the intake cam caps. FYI on the last cam cap nearest the CDFP make sure you use some permatex in the grooves located on the underside of the cap. If there is already some on there clean it out and install new permetex. Here is the SST( cam alignment tool) Also when tightening the caps you want to do them in sequence like when you do your head. I believe its 12in lbs for each bolt. Once you have done this now you can attach your timing chain to your exhaust sprocket BEFORE YOU BOLT IT YOUR CAM and then while your chain is attached attach the sprocket to the cam. Now with the cover still on the car you will not have a chance to use a torque wrench. Will update more later....
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 10-18-2012 at 04:42 PM. |
| The Following 10 Users Say Thank You to qtrmile beast For This Useful Post: | bcmurphy87 (11-12-2012), BobbleHead (10-18-2012), Kfunk (04-15-2013), Micha (12-15-2013), Neubreed (01-10-2014), rfinkle2 (12-04-2013), Roddiy (10-18-2012), sidekick (02-23-2014), Speed3eak (10-18-2012), TiGraySpeed6 (10-18-2012) |
![]() Join Date: Aug 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,355
Groans: 279
| Not Ranked : 0 score Now we just need a good set of Aftermarket cams...
__________________ 2010 LSM Speed3 Bolted + Corn + Meth + ACT 6-Puck #BakeryTuned |
| The Following User Says Thank You to Roddiy For This Useful Post: | rfinkle2 (12-04-2013) |
![]() Join Date: Nov 2012
Rep Power: 0 ![]() Thanks: 0
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score Thanks for the post. It seems to me that it's easiest to just pull your motor out completely. |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score Thanks for bumping a 2 year old thread for a useless comment, twatknuckle.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
![]() Join Date: Aug 2015 Location: Santiago, Chile
| Not Ranked : 0 score Hi, I was reading your post and i have a question about the bolt of this picture: It say that the bolt has to be 10x1,5 and the size with the measure tape say that has to be Øx2 3/8", whats the real size of the bolt that i have to use? Tnx! |
In all reality, you can use a longer bolt than needed, provided you can maneuver it into the TDC blind plug hole.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
__________________ https://www.youtube.com/user/JustinBieberVEVO | |
| Not Ranked : 0 score ^^^This lol
(Thread Starter) | Not Ranked : 0 score The length of the bolt doesn't really matter because you have to take the half shaft(AXLE) out to get to the hole anyway. You just want it long enough to reach the crank comfortably. I found that this length was ideal and left about 1/4' left once the bolt was flush against the crank. http://vid206.photobucket.com/albums...P1010149-1.mp4 This is NOT the bolt in the picture. I think this a head bolt but i think the reason you see me use the wrench is because it was almost out of thread by the time it got snug enough to the crank. Hence the reason i went with the all thread bolt.
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 09-10-2015 at 03:49 PM. |
| The Following User Says Thank You to qtrmile beast For This Useful Post: | impossible (01-12-2017) |
| PT-P regrind cams story -- need Web weld & regrind cams | MazdaGaragePat | MazdaSpeed 6 - Engine, Transmission & Driveline | 30 | 08-10-2016 03:46 PM |
| Cams Cams Cams.... | blkspeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 11 | 12-17-2010 08:10 PM |
| PTP or other CAMS | SpeedSixxx | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 11-27-2009 05:52 PM |
| PTP Cams does anybody have them? | RacingToaster | MazdaSpeed 6 - Engine, Transmission & Driveline | 12 | 10-10-2009 11:26 AM |
| ptp cams? | Buildabong | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 06-14-2009 11:02 PM |
