| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: May 2010 Location: Guelph, Ontario
Rep Power: 182 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
(Thread Starter) | Neutral : +1 score Step-by-Step Brake Tech for Our Mazdaspeed3: 2008 Mazda Mazdaspeed3 Project Car: Grassroots Motorsports Magazine Last edited by Haltech; 08-04-2012 at 10:27 PM. Reason: Updated link by haltech |
| The Following 25 Users Say Thank You to FUB4R3D For This Useful Post: | 2007speed3 (11-06-2010), 2008speed3 (11-08-2010), Addikted To Boost (12-09-2010), Arnie1229 (01-13-2015), AZSPEED3 (03-23-2012), breakfstincluded (10-04-2011), chomorro (10-25-2013), dsb_chicago (01-15-2013), I Love Brownies (11-05-2010), J-villa (02-07-2011), JacksonMS30 (11-05-2010), jack_hammer (01-14-2012), JohnMS3 (12-20-2010), kabobulate (11-07-2010), kgb (12-21-2010), labikesrcool (11-09-2010), madjon (11-08-2010), Mortose (04-11-2012), MS3 Ventura (11-06-2010), Night Wolf (12-14-2010), Notorious AMA (02-25-2014), novice_01 (11-08-2010), roguemazda (12-11-2015), SIXual Panda (12-10-2010), zpele (07-11-2011) |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
| Not Ranked : 0 score Thanks for reposting this. I subscribed to it and then it disapeared along with a lot of other useful stuff I had recently subscribed too.
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - |
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score ha guess we should make this a sticky again...
![]() Join Date: Jul 2010 Location: Maryland
Rep Power: 188 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score bookmarked the link thanks.
__________________ 09 TR MS3 Cp-e Nano SRI | Cp-e TIP | Cp-e RMM 75d | Cobb catted 3" DP | Cobb AP - Jorge Carrillo protune NGK Iridium IX 6510 plus | PTP HPFP upgrade (internals) TrMotorsprt MT1 18x8.5 +48 | Dunlop Direzza Sport Z1 Star Spec 235/40/18 | Mutegi Black Lug nuts Hawk HPS Pads | Ate Super Blue | Techna-Fit SS lines Hella Supertones | JBR Heavy Shift Knob |
Groans: 356
| Not Ranked : 0 score why does he have 2 sets of gloves??? and matt dammond had done one also
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 952
Groans: 70
| Not Ranked : 0 score so as a ratard how much more work is involved in removing the rotors? the pads themselves seems like a simple task! |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
Once you have removed the caliper the rotor comes right off, you may need rubber mallet or similar the first time. On a 6 there is a screw to remove I believe (can be a bitch if it is rusted)
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. | |
| The Following User Says Thank You to FreeFlyFreak For This Useful Post: | 2007speed3 (11-06-2010) |
![]() Join Date: Mar 2010 Location: Fremont OH
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 281
| Not Ranked : 0 score ^if there is a screw and it's rusted, apply PB blaster. then get a screwdriver that fits tight and you can beat on... apply turning force and hit the screwdriver at the same time to attempt to jar it loose... or get an impact driver so the hammer hit applies the twist for you, those things are great for rotors secured by screws. Note. if just changing pads was all you wanted, then you can skip on removing the caliper bracket with the caliper like he did in the back... just need a 7mm allen, pop the little covers off and remove just the caliper. I've always at least machined the rotors when changing pads though.
__________________ A BMW owner amongst Mazda owners. |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score same procedure for every car |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | rossisboss07 (11-06-2010) |
Groans: 70
| Not Ranked : 0 score Thanks, i think i need to do a brake job soon. 60k miles on the original pads and rotors i assume at least the pads need to be replaced. how does one tell if the rotors need to be replaced too. There is at least a penny sized lip on the edge of the rotors so i could they still be turned instead of getting new pads or what? |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score i need to change mine today
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
other things that would make me want to replace them are, excessive warpage, rotor thickness getting close to min. (thinner rotor warps easier again) or if the pads cut grooves into the rotor, grooves can take a lot to machine out, so sometimes it's easier to just replace them. as an example, I did 2 pad changes on my MS3 (within 23k miles from new) first from stock to HPS pads up front, turned front rotors, rears were OK still. second pad change I put Carbotech bobcats on all 4 corners, rears were excessively warped but had good thickness, so I turned them (warped from setting parking brake tooo soon after heavy braking), the HPS was easier on the front rotors than stock and I only had to turn off a few thousandths. of all the average cars brake jobs that I do, I'd say I replace rotors due to rusting, warping, and grooves from running out of pad more than anything else. I only turn rotors every once in a while, because most people don't seem to pay attention to the squeaker on the pads to tell them when it's time to check pad thickness... so I end up replacing the rotors 'cuz they ground the hell out of them with the pad backing.
__________________ A BMW owner amongst Mazda owners. | |
Groans: 754
Minimum front disc plate thickness 23 mm {0.91 in} Minimum front disc plate thickness after machining 23.8 mm {0.94 in} Minimum read disc plate thickness 9 mm {0.35 in} Minimum rear disc plate thickness after machining 9.8 mm {0.39 in}
| The Following User Says Thank You to FreeFlyFreak For This Useful Post: | rossisboss07 (11-07-2010) |
![]() Join Date: Mar 2010 Location: Indy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
| Not Ranked : 0 score Panning on this soon, thanks for the post.
__________________ 2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate 2008 Silver MS3: Sold |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score This is a great guide, but having done this a few times on the Speed3, what seems to be missing is applying brake grease to the back of the pads. I find that I get squealing from the pads without some sort of brake grease. |
| Not Ranked : 0 score anybody use the EBC yellow or any other color pads, impressions?
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following User Says Thank You to FUB4R3D For This Useful Post: | Dano (11-08-2010) |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score Subbing for a good write up. Gonna have to do brakes eventually. |
| Not Ranked : 0 score Are the Reds more of a track compound?
(Thread Starter) | Not Ranked : 0 score From what I have read, the Reds are a street compound. First time installing brakes on the speed, and with my old car I never ran anything special, so this should be interesting. I'm all for the lower dust levels compared to stocks. To get track/street compound, you'll need yellows or blues. |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 1415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,027
Groans: 155
Groaned at 44 Times in 37 Posts
| Not Ranked : 0 score I've had the EBC Red's for over 1k miles now and I like them. Plenty of bite and there is less dust - not no dust but less. |
| Not Ranked : 0 score Street compound should suffice for me as well. Thanks
Groans: 70
| Not Ranked : 0 score anyone running hawk hps ? |
![]() | | #24 | ![]() |
![]() Join Date: May 2008 Location: New orleans, la
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 294
| Not Ranked : 0 score I am on hawk hps. They work well and are a killer price but they tend to have quite a bit of a soft spot at the start of the pedal travel. They are comparable to stock pads without the initial bite. If you're not worried about losing that initial bite the hawk hps are a killer deal. I'll be going to something new next change. |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2010 Location: MO, KC area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score Very nice post, tyvm.
__________________ [SIGPIC][/SIGPIC] JBR SRI+TIH JBR SSP+Shift Knob CP-E 60D RMM Autotech HPFP AP V3 S-OTS 2 map |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, after having done my brakes last night, I can easily say that those rears have the most asinine bolts that I have ever had to remove... Bottom one was OK, just took a little while to come out after I broke it loose, but the top one hiding behind the e-brake cable and brake line ![]() +1 from the review for there being sharp bits and flying anti-rattle springs. One tool I might add to a list would be a 1.5 ft/2 ft breaker bar to get the bolts loose if its the first time since the factory (This tool is completely useless on the rears). A flexible extension might also make life easier, but I have never used one and can't say how good it would be. So far I'm happy enough with the EBC reds, but I am still just breaking them in so I cant give a really accurate description of them yet. |
![]() | | #27 | ![]() |
![]() Join Date: Jun 2009 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Thanks for the post...gonna be doing this at some point in the next few weeks! |
![]() | | #28 | ![]() |
Groans: 155
![]() | | #29 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,488
Groans: 35
| Not Ranked : 0 score Subbing for when I need to do mine. Thanks for posting.
__________________ 2008.5 Black Mica MS3 Cobb AP and 30% E85 Dizzy Tune - Cobb SRI - CP-e RMM - JBR SSP & Solid Shifter Bushings - E4 heavy shift knob - Denso ITV22 plugs - 6000K HID lows - 3500k HID fogs - Ford XT-M5-QS Tranny fluid - RX8's (PC'd Anthracite) - Rubber hatch tray It's not my fault I'm this way, I was homeschooled. |
![]() | | #30 | ![]() |
![]() Join Date: May 2009 Location: Duarte, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 472
| Not Ranked : 0 score Thanks for the link. will be using it in a few days
__________________ -John ![]() | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | |
![]() | | #31 | ![]() |
![]() Join Date: Apr 2011
| Not Ranked : 0 score Hi everyone... Just stumbled across this thread. Thanks for the link! To answer a couple of questions in some of the replies... I've been running the yellows as my only pads since I installed them. Good street pad, good track pad. They don't take much heat to work just fine, and they don't make any noise on the street. Only downside is they're dusty, but that' s the price for most good pads. Grey wheels hide that nicely. And as for changing gloves mid-shoot, that's mostly because the numerous razor-like edges on this car make latex gloves worthless. I simply can not overstate the amount of sharp edges and point on the undersides of these cars. My wife and I have five parrots, and between their boxcutter beaks and the MS3, my hands constantly look like I'm involved in some adult knife-fighting league at the post-apocalyptic community center. Again, thanks for the plug. I need to go browse the rest of the forum now. Cool stuff here... jg pasterjak Grassroots Motorsports magazine grassrootsmotorsports.com |
| The Following 3 Users Say Thank You to jpasterjak For This Useful Post: |
![]() | | #32 | ![]() |
![]() Join Date: May 2010 Location: Biloxi, MS
| Not Ranked : 0 score 221702_220642701285702_100000199217775_997795_207227_s.jpgMy new rotors and brakes. Just put them on today. Last edited by Soriku1489; 05-06-2011 at 04:39 PM. Reason: Picture didn't show |
![]() | | #33 | ![]() |
![]() Join Date: Sep 2011
Rep Power: 0 ![]() Thanks: 1
![]() | | #34 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
__________________ 2010 Mazdaspeed3 |
![]() | | #35 | ![]() |
| I updated the link. Thanks
| The Following User Says Thank You to Haltech For This Useful Post: | dar_vedar (03-06-2013) |
![]() | | #36 | ![]() |
![]() Join Date: Mar 2013 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 281
| Not Ranked : 0 score I just did this last night. Replaced front and back rotors and pads. Forget about using the needle nose pliers for the rear caliper, its a huge pain in the ass!! Took almost 30-45 min to get one piston pushed in and it keeps popping out of the holes........ Hands hurt so i went to local auto store and rented the disc brake caliper tool, they put $55 bucks on hold on your card but the rental is FREE for two day, you get your money back when you return it. The other caliper took less then two min to push in using this tool. Also makes the front pistons cake! On the peske rear caliper bolts I just used a 14mm wrench and a 15mm wrench on the end as an extension and they broke loose easily. I know its not "safe" but i do it all the time with gloves and make sure nothing is in the way of any body parts when the wrench makes a full turn. I used to have a metal tube that fit over the wrench shaft to use but i couldnt find it....
__________________ 2009 Subaru WRX STI Hatchback 2007 GTI - Package 2 w/ Nav - Dieselgeek Short Shifter / TWM Weighted Etched Shift Knob / AWE 2.5" Turbo Back Exhaust w/Metal Cat / APR Stage 2+ Tune / APR Flapper Delete / APR HPFP / Vogtland 2" Springs / R8 Coils / NGK Iridium / P3Cars Digital Vent Gauge / 18" OEM Detroit Rims (SOLD) 2007 Speed 3 - Stratified Tuned with bolts ons (SOLD) |
![]() | | #37 | ![]() |
![]() Join Date: Jan 2014 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Used this how to for my front brakes and rotors the other day. Easy peasy, hardest thing was breaking the bolts loose that were holding the calipers on. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/step-step-brake-job-grassroots-motorsports-63702/ | ||||
| I don't remember Pokemon looking like this (14 Photos) : theCHIVE | This thread | Refback | 01-21-2011 03:06 AM | |
| my cx-7 tuning step buy step | ro-bi | CX-7 > Turbo Induction & ECU Tuning | 84 | 04-25-2017 12:21 PM |
| Cut It Out: Toyota's recalled pedal modification remedy detailed step-by-step | Haltech | Automotive News | 0 | 12-18-2009 12:10 PM |
| Grassroots Motorsports $2008 Challenge is in the books | Haltech | Automotive News | 0 | 10-10-2008 07:50 AM |
| Grassroots Motorsports $2008 Challenge headed to Florida | Haltech | Automotive News | 0 | 09-23-2008 02:20 PM |
