> MazdaSpeed 3 - How-To's
Like Tree3Likes
 Old 09-03-2011, 04:11 PM   #1
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Default SWAS - How to disable
So we’ve been seeing a lot more cars experiencing erratic rich conditions which are typically in the lower gears and at throttle tip in or between gear changes. This CAN be caused by enabling LC/FFS but it can also be caused by the SWAS [Steering Wheel Angle Sensor] kicking in and switching the logic to alternate tables which causes the car to fall flat on its face. You don’t even need to be turning the wheel for this to happen or perhaps a very slight turn induced by TQ steer will trigger the SWAS.
Disabling TCS/DSC does not disable SWAS unfortunately so the only way to disable it is to unplug it. A very easy task I’ll outline now. No pics cuz its just too easy
Edit: 09/09/11 DISCLAIMER ::: DISABLE THE SWAS AT YOUR OWN RISK
so I had a lil fun the other day on a freeway exit ramp that was due to disabling the SWAS and thought it worth mentioning. So without the SWAS enabled DSC is truly blind/deactivated unlike just pushing the DSC switch which actually just disables traction control and does nothing to disable stability control. on to the story.
a curved exit ramp [actually a partial clover leaf] I routinely exit at higher than posted speeds I typically run that ramp to the edge of control...just before tire squeal...well this time...way before any hint of squeal the car decided to rotate the ass end around a la @FreeFlyFreak video from years ago. I didn't go quite that far but suffice to say I was drifting in a FWD car LOL. Power application was needed to straighten her up and by the time I got to the light at the bottom of the ramp I had barely got her straight and skidded to a stop...ROFL...it was funny to see the looks on the peoples faces waiting at the light
anyway point is, in the past DSC was apparently kicking in on that ramp and applying brake pressure to control the car and without SWAS is was not. For the road racers/ autox guys out there with difficulty getting the car to rotate, i wonder if they are disconnecting the SWAS.
Doing this from memory so here goes.
Gen 2 version can be found here: Thanks @Monotonous ONE for the writeup
SWAS - DISCONNECT ON A GEN2
Step 1: Disconnect your battery and drain all fluids [ just kidding about the fluids but DO DISCONNECT THE BATTERY!!!] Then wait for 15 minutes to ensure there is no power left in the system. We will be working around the air bag connector which could cause the air bag to deploy and we don’t want that.
Step 2: remove the lower portion of the dash by pulling kinda out and down at the top seem right under the instrument cluster. It will pop lose fairly easily. Next remove the hood release cable mount from the bottom, a Phillips screw holds it in. Now the lower dash panel will be out of your way.
Step 3: You can now reach the 3rd of all 3 screws for the lower steering column cover. Once the screws are out you can pop the cover down and disconnect it from the top half. You will need to pull it to the passenger side to clear the ignition switch then is comes completely off. You will see a bright yellow wiring harness [Air bag] and just underneath that one is the SWAS connector. Don’t disconnect the yellow harness. Pull the connector down to unplug it then tuck the harness back up into the column and put everything back in reverse order.
No more car falling on its face now.
The little car squiggly will always be on now in the dash...a small price to pay for power.
I still always disable TSC/DCS when I get in the car.
Up next, I’ll try to figure out a way to auto disable TCS/DSC. I have seen it done somewhere on here with some sort of relay. If you know how please PM me.
what happens when air bag goes off
speeding3 (08-12-2013)
 Old 09-03-2011, 04:22 PM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Thanks.
In for reading in detail later while not drinking.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-03-2011, 04:25 PM   #3
Metal409's Avatar
Posts: 316   (View Stats)
Metal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the world
I've honestly never unhooked the battery on the couple cars we've done this to, but safety first. For what it's worth, could have been a fluke, but over this last winter I had the sensor still disabled. Coming home one night, the roads were freezing over and coming down a side street there was a slight arc in the road (center was higher). The car started to slide a little and from what I could tell the DSC freaked out not knowing where the wheel was pointed. The back end kept forcing itself to come around and no matter what I tried to do I could feel the car fighting me. Ended up turning DSC off, letting the tires hit the gravel/dirt/snow on the side of the road and forcing it to straighten out the car. Drove the rest of the way home with DSC off with no problems. I never had that problem before. So for winter I hook the bitch back up. lol.
2016 Ford Focus ST
2013 Ford Fusion Titanium AWD - Sold
2009 Mazdaspeed 3 GT - Sold
Metal409 is offline   Reply With Quote
 Old 09-03-2011, 04:25 PM   #4
Titanknight's Avatar
Posts: 69   (View Stats)
Titanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond repute
Good to know cause this has happened to me b4 and i had no clue... thx for write up but some pics would be nice for us who are not very auto savy
Titanknight is offline   Reply With Quote
 Old 09-03-2011, 04:37 PM   #5
Trail of Fail
Dano's Avatar
I was told to disco the battery and so I did LOL
I don't want a face full of air bag. When you are RIGHT there...it would prab take you head off
have you seen the video where some russians set off a bag under a guy sitting on some tires???? holy shit!!! It launched his ass 5 feet into the air...I need to look that up and put in OP for a safety video.
edit: OP updated with said vid.
 Old 09-03-2011, 04:48 PM   #6
Post pwned's Avatar
Posts: 799   (View Stats)
Post pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the world
In-
2010 Mica Black
RMM/RSB/SRI+TIP
Post pwned is offline   Reply With Quote
 Old 09-03-2011, 06:18 PM   #7
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
I've seen that video it was lols then and its lols now
thanks for the post
 Old 09-05-2011, 09:51 AM   #8
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
This thread should have been made a long time ago! great write up Dano
Keep up the good fight Perm squad!!
 Old 09-05-2011, 10:50 AM   #9
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
I just did this to mah gen2
Thanks to dano
Imma make a gen2 how to shortly. I took a couple pics but it really is self explanatory.
 Old 09-05-2011, 11:46 AM   #10
Groans: 819
heres mah gen2 thread with pictures
dunno how similar the gen1 and 2 are...maybe it could help others...i dunno
 Old 09-06-2011, 02:12 PM   #11
redbathtub's Avatar
Posts: 224   (View Stats)
redbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the worldredbathtub is the leader of the world
Pictures of a 1st gen from another thread:
08' TR - COBB AP FSB RSB - CPE SRI TIP TMIC DP RMM - KMD V2 - FORGE BPV - HKS HI POWER - PORTED IM - SNOW METH
SURE TIGS BOOST TUBES - ACT CLUTCH - JBR SSP - TWM PHANTOM - KONI FSD - BBS STI - ROTA SLIPSTREAM
SPLOTCHY PAINT - DOOR DINGS - BUMPER SCRAPE - SWIRL MARKS - CURB RASH
redbathtub is offline   Reply With Quote
 Old 09-07-2011, 09:50 AM   #12
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Is it just 3 wires? If so, i wonder if the sensor wire could be extended to a switch mounted elsewhere.... that'll make it easy to connect / disconnect in the future.
Oh and i made an auto DSC off circuit for jmhinkle a long time ago. I could always make more if people wanted them.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 09-07-2011, 10:06 AM   #13
Groans: 819
interesting how gen1 and 2 are so completely different
but you can see why i made the mistake i did based on the description w/o pictures
 Old 09-07-2011, 10:42 AM   #14
Trail of Fail
Dano's Avatar
I honestly don't remember for sure how many wires there were but for some reason i wanna think 6. I'll take another look and confirm.
oh and I do want the DSC circuit....yes it will be 47576857394575948373 on your list but it would be cool to have.
 Old 09-07-2011, 10:58 AM   #15
Captain
I can build some up. If i'm gonna do a bunch i'll actually order boards. The circuit i made would essentially "single press" the dsc for you a couple seconds after start up. But still allowed for the driver to press it later to enable / disable at their leisure. So it kinda just changed the functionality to a "press if you want DSC", instead of "press if you don't".
www.permtuning.com
 Old 09-07-2011, 10:59 AM   #16
Trail of Fail
Dano's Avatar
exactly!!!
 Old 09-07-2011, 11:17 AM   #17
XRJoe's Avatar
Posts: 88   (View Stats)
XRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond reputeXRJoe has a reputation beyond repute
Are there tables in the ECU dedicated to limiting load/boost based on SWAS input or a multiplier table that limits load/boost based on the values pulled from the sensor?
I wonder if they could be tuned with ATR to still have the SWAS work in extreme conditions like @Metal409 mentioned above, but not cause the car to lose power under spirited driving.
Joe
2013 Focus ST
1985 Merkur XR4Ti
XRJoe is offline   Reply With Quote
 Old 09-07-2011, 11:28 AM   #18
Captain
I'm sure the tables are in there, but i'm not sure about the priority it has on Cobb's radar. AFAIK, there are other bigger fish to fry first.
www.permtuning.com
 Old 09-07-2011, 11:35 AM   #19
Trail of Fail
Dano's Avatar
Cobb has tried to remove some of the "nannies" by making all the DBW tables match as well as CL exit tables in the later version of OTS maps but it doesn't effect the SWAS as of yet.
the conditions that occur when the SWAS kicks in would seem to be driven by a multitude of tables. Fuel and timing for sure and I would suspect DBW could be an easy table to control power but IDK for sure.
 Old 09-09-2011, 01:13 PM   #20
Trail of Fail
Dano's Avatar
OP updated with the below DISCLAIMER story
 Old 09-09-2011, 01:19 PM   #21
frivolous_rob's Avatar
Posts: 1,374   (View Stats)
frivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the world
Groaned at 44 Times in 17 Posts
Is there anyway to reroute the button, like put it to one of the radio controls on the steering wheel? so us 3's can launch first and second with trac on and then disable it for 3rd?
Choke me, I like it.
frivolous_rob is offline   Reply With Quote
 Old 09-09-2011, 06:20 PM   #22
Tokay444's Avatar
Groans: 793
So dano, when you say you used to disable traction control, were just pushing the button, or were you doing the hold while starting the car method? Because I've never had a problem with the car rotating before. Meaning, that snap oversteer has tried to kill me more than once.
Could unplugging swas, be the equivalent of holding the button while starting the car?
Demodded.
The Seals
 Old 09-10-2011, 12:50 AM   #23
Trail of Fail
Dano's Avatar
hum...possibly...I heard the "rumor" about holding the DSC button down while starting but never took the time to really test out the theory.
I was only referring to hitting the button after start up.
"snap oversteer" is EXACTLY what happened.
 Old 09-10-2011, 01:36 AM   #24
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
AZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the world
Groans: 65
Perm crew comes through again with yet another MS3 break through. Damn without out you guys the MS3/6 community would not be where we are today. Big thanks.
AZSPEED3 is offline   Reply With Quote
 Old 09-10-2011, 07:16 AM   #25
Tokay444's Avatar
Groans: 793
Yeah. My car has almost killed me a couple times from that. I tested the button pressing options in a snowy parking lot, but it was to slippery to bs conclusive. I will say this definitively though. When you press and hold the button on start up, snap over steer is prevalent in a long highspeed sweeper. I've learned to deal with it now that I'm expecting it. I'm gonna try it out with JUST pushing the button and report back. We may not need to go to all the work of disconnecting the swas all together.
Demodded.
The Seals
 Old 09-11-2011, 10:51 AM   #26
Captain
Good idea. Curious on the results. It would be cool if you could video tape em lol.
www.permtuning.com
 Old 09-11-2011, 10:53 AM   #27
Tokay444's Avatar
Groans: 793
I probably could video tape it. I hais miniDV cam. Just gotta fab a mounting solution.
Demodded.
The Seals
 Old 09-11-2011, 11:37 AM   #28
Captain
V
I
D
E
O
Z
I'll get some if you get some
www.permtuning.com
 Old 09-11-2011, 05:19 PM   #29
Tokay444's Avatar
Groans: 793
Ok. I'll get on this this week. I was really hoping to get these potenzas through till I put my snows on, but I guess that's out of the question.
Demodded.
The Seals
 Old 09-11-2011, 07:46 PM   #30
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
i did this a few months ago and was wondering why i waited so long to do this. best free mod ever.
no more trying to pull out onto a busy road quickly only to have the car fall on it's face because the ecu decides to cut boost when you're turning out of a drive
and dustin - would be interested in that board!
 Old 09-12-2011, 12:33 PM   #31
708
Erich's Avatar
Posts: 4,274   (View Stats)
Is unfortunate, because imo this is a pretty big fish.
I would have to think there are single value tables for SWAS 1st and 2nd gear limiting. The way it behaves, this would seem logical... oh wait a second, forgot we were talking about the MS3 ECU here. Never mind.
 Old 09-12-2011, 12:43 PM   #32
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Just FYI, ZZP makes one of those for the TC button on GTPs. It should work on our cars for the DSC.
http://zzperformance.com/grand_prix/...=645&catid=107
I've made it a habit of holding the DSC button when starting the car to illuminate both the DSC and TC warning indicators.
Tapadatass
 Old 09-12-2011, 12:48 PM   #33
Trail of Fail
Dano's Avatar
exactly LOL
I don't think it could be a singled value table b/c it would have to alter normal timing/fuel and I would guess the throttle plate, all at the same time. at least that's my thinking.
IDK maybe just the throttle plate slams shut but IIRC I didn't see anything like that.
 Old 09-12-2011, 01:14 PM   #34
708
Erich's Avatar
I actually meant a single value for at which angle it occurs. Seems to be .000001 for 1st gear.
 Old 09-12-2011, 01:19 PM   #35
Captain
ZZ Performance
Tapadatass
Holy crap, they're charging $34 for that thing lol. Maybe i should put one together then.
www.permtuning.com
 Old 09-12-2011, 01:26 PM   #36
silvapain's Avatar
Groans: 136
My guess is it's simply a 555 timer wired up as a monostable oscillator. A couple bucks for a timer, capacitor, and a couple resistors.
Tapadatass
 Old 09-12-2011, 01:39 PM   #37
Trail of Fail
Dano's Avatar
Hahah. Yes it does.
Tappin
 Old 09-12-2011, 01:41 PM   #38
Captain
Tapadatass
Has to be a one shot. With a long delay on the trigger. I did mine with op amps, but a 555 can easily do the same thing.
But honestly.... for $35, i'd use a $1.00 micro and let the damn thing be configurable hahahaha.
www.permtuning.com
 Old 09-12-2011, 01:46 PM   #39
Trail of Fail
Dano's Avatar
Btw
After 500 miles with SWAS discoed I have had zero stumble. This is now conclusive IMO
SWAS=SUCKS.
Until we can configure either the steering angle trigger or how much power it removes.
Tappin
 Old 09-12-2011, 02:13 PM   #40
708
Erich's Avatar
Btw
SWAS=SUCKS.
Tappin
100% agree. Didn't need 500 miles either. Just twice WOT in 1st gear was enough to convince me.
The Following User Says Thank You to Erich For This Useful Post:
mroclimbr (12-24-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/swas-how-disable-103665/
GenOne SWAS delete This thread Refback 01-24-2015 12:44 PM
Leistung mit eingeschlagenen Rädern...... This thread Refback 09-01-2014 02:43 AM
My GTX28 so far This thread Refback 01-21-2014 12:32 PM
My GTX28 so far ? Mazda MPS Owners Club This thread Refback 12-21-2013 04:57 PM
what have you done to your mazda today? This thread Refback 05-18-2012 07:16 PM
Time To Go Forged - Page 18 This thread Refback 03-30-2012 08:52 PM
How to: Install a switch for SWAS enable/disable Mase 2010 MS3 - How-To's 190 02-27-2018 07:31 AM
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS - How to disable Dano MazdaSpeed 3/6 - ECU Computer Tuning 208 06-09-2016 08:21 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.61480 seconds with 36 queries
