Closed Thread
 Old 01-11-2010, 09:35 AM   #81
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
bioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the world
G'Damnit, You guys are going to get me into a divorce with my wife over this shit. I'm just sitting happily around the 300whp for daily driving and you had to go a do this. Power Mod bug has filled my veins now, thanks.
I'll de-mod some first and change the car modding direction again. %$&@*#!@#!@##@
BTW: Great Job!!!
bioevolve is offline
The Following User Says Thank You to bioevolve For This Useful Post:
SpeedSixxx (01-11-2010)
 Old 01-11-2010, 09:35 AM   #82
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
no, I watched the tuning the whole process... their was no KR, nor any negative timing adjustments on the standback log.
he said there was still about 7-8* of timing play on pump gas but that it likely wouldnt result in enough power difference to be worth it.
socks is offline
 Old 01-11-2010, 09:40 AM   #83
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
ha, Bioevolve I'm in the same boat. My wife freaked out just the other night!
Parting out!
http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/
Spoolme is offline
The Following User Says Thank You to Spoolme For This Useful Post:
bioevolve (01-11-2010)
 Old 01-11-2010, 10:05 AM   #84
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
We have A LOT more big announcements coming. This was just the beginning. I am hoping I can get a few more big turbo built blocks to come up here or send their ecu's in.
We do need to make sure you have certain parts as our flashes are made for a specific combination of some parts. I will be making some writeups on what needs to be purchased and done to allow this type of success. I will stress that I would NOT recommend doing what we did here with Sean on a stock motor.
www.cp-e.com is offline
The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post:
FreeFlyFreak (01-13-2010), SpeedSixxx (01-11-2010)
 Old 01-11-2010, 10:06 AM   #85
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Originally Posted by Steevo View Post
Definetly. Are there any companies that make aftermarket cams for these cars yet?
PTP, I believe.
Frequentflyer is offline
 Old 01-11-2010, 10:13 AM   #86
yoichi's Avatar
Posts: 557   (View Stats)
yoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the world
this has to apply to GT28's.......
2003 E39 ///M5
yoichi is offline
 Old 01-11-2010, 10:21 AM   #87
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Originally Posted by socks View Post
...the first pull on the dynojet the car overboosted, which is odd, i thought dynojets ran less boost because they produced less load. the boost spiked to around 30psi and i got off quick.
Even with a MBC? Very odd that it would over boost period, regardless of loading. Did you guys tap into the boost for the dyno computer? Maybe that line popped off??? I just don't know how you can over boost with mbc.
Im sure 3.25" is fine. im using a 3.5"
i wouldnt worry about it unless you start maxing that out. I havent even looked at my voltages since...
You will max out the g/s before you max out the voltage, even on 3.25" maf.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 01-11-2010, 10:47 AM   #88
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
good job cpe, keep it up. we have a nice start to the new year!
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline
The Following User Says Thank You to clos561 For This Useful Post:
 Old 01-11-2010, 11:07 AM   #89
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
I can't wait until we're at the point we have a set list of known mods that WILL give you 500whp and 20,000 miles of driving to back them up.
Once that is established I'll pour my money in!
A big thanks to the venders and owners that put their shit on the line to make this all happen!!!
Best to date - 13.802@104.16 (I/MP/MM/W)
BlackMS3 is offline
The Following User Says Thank You to BlackMS3 For This Useful Post:
pipe (01-11-2010)
 Old 01-11-2010, 11:08 AM   #90
Alpha's Avatar
Posts: 3,711   (View Stats)
Definitely! I want to see how this affects the stock motor guys.
Alpha is offline
 Old 01-11-2010, 11:16 AM   #91
TunerGuy's Avatar
Posts: 22   (View Stats)
TunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud ofTunerGuy has much to be proud of
Groaned at 4 Times in 1 Post
[/QUOTE]
I won't go into details on RR but the dynos the posted have been manipulated a bit. We have the runfiles for those who want them of our runs. I will let them do their own thing as we don't make the parts they are trying to sell. Their dynos just don't even come close to looking legit.[/QUOTE]
WOW!!! That is not just unprofessional but quite an insult to Race Roots! Since you are the official public spokesman of CP-E and therefore speak for the entire company, tell us, what proof do you have that they manipulated their dyno’s?
To make such a claim surely you have proof? Actual proof, not opinion please.
TunerGuy is offline
The Following 3 Users Say Thank You to TunerGuy For This Useful Post:
ATE BALLER (01-12-2010), BoostIsBetter (01-11-2010), mpsanger6 (02-16-2010)
The Following 4 Users Say NO Thank You to TunerGuy For This Un-useful Post:
 Old 01-11-2010, 11:23 AM   #92
Alpha's Avatar
Rod > Block
Just saying. I wonder if this changes how far we can safely take the SBE?
Alpha is offline
 Old 01-11-2010, 11:24 AM   #93
Well i still believe with additional fuel volume, the Rod wont exit as quickly as a fuel starved engine. Whatever the wall paremeter is, may be a key to higher horsepower stock engines. We will soon see.. I suggest Darky tries it out since he isnt married yet.
Haltech is offline
The Following 5 Users Say Thank You to Haltech For This Useful Post:
djuosnteisn (01-11-2010), FreeFlyFreak (01-13-2010), MarkyMark (01-11-2010), Murse (01-11-2010), SpeedSixxx (01-11-2010)
 Old 01-11-2010, 11:26 AM   #94
Alittle Faster
bioevolve's Avatar
Basic list to obtain 500whp/500wtq eh?
Pistons
Rods
Bearings
APR Studs, Nuts and Bolts
Very Big Turbo
Ex Manifold w/ ext WG
Gasket set
Beefed Injector seals
Head PnP Worked
IM PnP Worked
Port match TB w/ new BF
3.5" MAF
SB
ECU Flash
Tune
 Old 01-11-2010, 11:30 AM   #95
Alpha's Avatar
Haha! Neither am I and I'm in the process of putting together a sly "Stock" 2871 hybrid turbo setup. Should be a fun DD.
Alpha is offline
 Old 01-11-2010, 11:36 AM   #96
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
darkie wont be trying any power mods any time soon...remember his rods didnt exit the block...only his balls.
rodrigo is offline
The Following 8 Users Say Thank You to rodrigo For This Useful Post:
802MS3 (01-11-2010), Darksun280 (01-11-2010), djuosnteisn (01-11-2010), Funky (01-15-2010), MarkyMark (01-11-2010), Murse (01-11-2010), predapio (01-13-2010), SpeedSixxx (01-11-2010)
 Old 01-11-2010, 11:40 AM   #97
Seeing the torque drop in the 24psi dyno I'm not convinced 500whp is a no brainer. Other factors may come into play.
Lex is offline
bioevolve (01-11-2010), djuosnteisn (01-11-2010)
 Old 01-11-2010, 11:41 AM   #98
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Damn Lenny..........Phil you gonna let him talk to you like that??
SneakyP86 is offline
 Old 01-11-2010, 11:49 AM   #99
BlackMS3's Avatar
Pistons
Rods
Bearings
Very Big Turbo
Gasket set
Head PnP Worked
IM PnP Worked
3.5" MAF
SB
ECU Flash
Tune
When there's a dyno at 500whp and another dyno at 20,000 miles, I'll throw money at every one of those mods.
BlackMS3 is offline
 Old 01-11-2010, 11:54 AM   #100
AmillieMS6's Avatar
Posts: 1,700   (View Stats)
AmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the world
Groans: 365
Groaned at 594 Times in 575 Posts
i woud love too see what Marks car can do with Cp-e.
If he can get his car running and over to Cp-e, i think history car be made...
And DAMN 30+ people viewing this thread afternoon on a Monday. Jesus doesn't anyone work around here lol
Mazdaspeed
AmillieMS6 is offline
The Following User Says Thank You to AmillieMS6 For This Useful Post:
Docnox (01-20-2010)
The Following User Says NO Thank You to AmillieMS6 For This Un-useful Post:
 Old 01-11-2010, 12:21 PM   #101
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
At this point it should be common knowledge that I'm a coward and just want to live the rest of my life as a normal law abiding citizen.
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
The Following 6 Users Say Thank You to Darksun280 For This Useful Post:
AmillieMS6 (01-11-2010), DaleNixon (01-11-2010), MarkyMark (01-11-2010), predapio (01-13-2010), SpeedSixxx (01-11-2010), vbt101 (01-11-2010)
 Old 01-11-2010, 12:23 PM   #102
socks's Avatar
Groans: 125
remember lex, i only have a 3071, and technically 24psi might be out of its efficiency...
just like you run out of efficiency at 20+psi on the stock turbo at higher rpms, any turbo is going to do the same if its too small to do what your asking it to do.
socks is offline
The Following 2 Users Say Thank You to socks For This Useful Post:
MarkyMark (01-11-2010), SpeedSixxx (01-11-2010)
 Old 01-11-2010, 12:24 PM   #103
Fux Wit It
Darksun280's Avatar
Groans: 175
Technically I think when tis out of efficiency TQ would actually go up and HP would level off or drop. Example is like when we spin our baby stock turbos to all hell we still make tq but no power.
 Old 01-11-2010, 12:29 PM   #104
socks's Avatar
Groans: 125
no, when you spool a stock turbo to 24psi, it may be in its efficiency at 3000rpms....
but when you try to keep that boost level up at 6000rpms, its not so easy. torque will drop.
similar effect here. its ok out of its efficiency, makes 400tq at 3800rpms.... but it starts to be out of range and begins to drop off.
socks is offline
bf360 (01-11-2010), Sacrilicious (01-11-2010)
 Old 01-11-2010, 12:34 PM   #105
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
Any videos posted yet? I'm dying to see an in-car video of your beast.....
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline
 Old 01-11-2010, 12:35 PM   #106
RIP May 9th, 2012
sbspeed's Avatar
Posts: 111   (View Stats)
sbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to behold
I'm glad I never sold my SB and PNP - hopefully they'll come out with a 900 rpm idle flash and I'm sold!
sbspeed is offline
 Old 01-11-2010, 12:39 PM   #107
I would venture to say that 500whp is WAY out of a 3071's efficiency. The 3071 is a strong 415-435whp turbo. It can make more but not efficiently. A 3076 is better suited for the mid 400s and a 35r is the 500 territory.
The thing you guys should always remember is bigger isn't always better. You want to properly size a turbo for your vehicle. If you want a solid 360 you want to go with a 2871. If you want a solid 400-425 you want a 3071. If you want 450ish you want a 3076. If you want HUGE power 35r. The 35r will make 550 on this engine. Properly sizing a turbo is the most important thing to remember. For this car I would stay away from a T4 turbo. A T3 35r with a .82 back housing will make tons of power. If you want to make even more you can always put the 1.06 on it for the track just make sure your ready to support what that can make.
 Old 01-11-2010, 12:40 PM   #108
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
ya, that makes sense. the thing that i'm wondering about is whether there's a need for a cam upgrade if you got yourself a GT35R to hold efficiency with 24psi through the rev range. are there cp-e shop cars with gt3076 or gt35r's handy?
Sacrilicious is offline
 Old 01-11-2010, 12:46 PM   #109
socks's Avatar
Groans: 125
Video embedded in first post
Give me some time to hop on a dynojet. I'll try to do it soon. I think you'll be pleasantly suprised.
Last edited by socks; 01-11-2010 at 12:47 PM. Reason: MSF Database - Automerged Doublepost
socks is offline
The Following User Says Thank You to socks For This Useful Post:
 Old 01-11-2010, 12:49 PM   #110
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
I want to see numbers with a 3076 and a 3582
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline
 Old 01-11-2010, 01:02 PM   #111
Fux Wit It
Darksun280's Avatar
Groans: 175
wait I just looked at the dyno where is socks TQ failing off so bad that this is an issue?
 Old 01-11-2010, 01:08 PM   #112
Captain
on the mustang plot
www.permtuning.com
 Old 01-11-2010, 01:08 PM   #113
pewpew
lawl...that run is going to leave a lot of previous work in the dust...yay for progress!
 Old 01-11-2010, 01:51 PM   #114
bf360's Avatar
Posts: 2,069   (View Stats)
To make such a claim surely you have proof? Actual proof, not opinion please.[/QUOTE]
I am not from cpe, and im the one who brought it into play that it may have been altered then people got suspicious and rr had their thread closed, so you make your own assumptions about what went down.
Look at rr's graph, their lack of info, and tell me you wouldnt think the same.
Congrats on the numbers, and making dam good power especially for this turbo, maybe even better than comparable platforms, 428whp on 19psi on a 3071 which is pretty small in terms of big turbos is a great accomplishment.
Originally Posted by DCLXVI View Post
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
bf360 is offline
The Following 2 Users Say Thank You to bf360 For This Useful Post:
E4Performance (01-11-2010), SpeedSixxx (01-11-2010)
 Old 01-11-2010, 01:52 PM   #115
Click Here's Avatar
Posts: 202   (View Stats)
Click Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the world
What do you mean by that? So long as you don't exceed 5-volts, why would the mass of air matter?
Click Here is offline
 Old 01-11-2010, 01:55 PM   #116
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
sounds like its track time? Cpe, do you have any cars doing some hpde's? I would like to see some ms3's hitting up some time trials.
kilik2 is offline
 Old 01-11-2010, 01:57 PM   #117
Captain
Perhaps i'm referencing an atr limitation or an ecu limitation... I'm not sure
...but after i calibrate for a 3.25" maf housing, i end up with a plateau near the upper voltage range of fixed 500 g/s, cause that's the highest value ATR will let you enter into that table.
If (big if) it's an ecu limitation, then you'll max out the g/s before you reach 5v on the sensor.
www.permtuning.com
 Old 01-11-2010, 02:15 PM   #118
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
Groans: 70
nice to see the wall is finally broken for this car.I expect a lot of high hp MS3's for 2010.
Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW!
Grim is offline
 Old 01-11-2010, 02:21 PM   #119
BoostIsBetter's Avatar
Posts: 582   (View Stats)
BoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the world
Groans: 32
Groaned at 31 Times in 18 Posts
I want to know what CPE can do for me power wise with the standback, if I just go intake, exhaust, manifold and bigger turbo, and keep the engine stock. Essentially bolt ons + bigger turbo and CPE fueling magic tuning solutions.
BoostIsBetter is offline
 Old 01-11-2010, 02:23 PM   #120
bf360's Avatar
It can do the samething as socks car as long as it doesnt pop, built motor doesnt mean more hp just protection
bf360 is offline
The Following User Says Thank You to bf360 For This Useful Post:
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f330/big-power-finally-here-46183/
YOU GUYS FINALLY GET THE POWER YOU DESERVE!!! This thread Refback 03-23-2010 04:42 PM
Who's is bigger? This thread Pingback 02-15-2010 08:16 PM
CP-e and big power This thread Pingback 01-22-2010 12:24 AM
YOU GUYS FINALLY GET THE POWER YOU DESERVE!!! - MN Mazda Forums This thread Refback 01-11-2010 10:06 AM
Day of 1/10/2010: Top 50 of 202 Referring Pages This thread Refback 01-11-2010 08:58 AM
Rhys Millen's drift car finally ready to run with Hyundai Power Haltech Automotive News 0 05-05-2009 10:20 AM
VIDEO: Bugatti Veyron finally does Power Lap on Top Gear, is it the fastest? Haltech Automotive News 1 11-24-2008 02:12 PM
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails $49.99 at newegg Haltech Hot Deals Section 0 04-16-2008 09:40 AM
COOLER MASTER Real Power Pro 750W Power Supply $59.99AR at ZipZoomfly Haltech Hot Deals Section 0 04-14-2008 05:00 PM
Antec Neo Power 500 ATX12V 500W Power Supply 100Vac to 240Vac $69.99 Free Shipping Haltech Hot Deals Section 0 04-01-2008 09:41 PM
Page generated in 0.61334 seconds with 45 queries
