Closed Thread
 Old 05-17-2010, 03:35 PM   #1
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
No worries - you'll make the switch if your turbo is of a decent size and then you don't make power. Cobb is a great company. They just haven't found the issue on this platform.
That's because the best person, IMO, that can tune a MS3/6 has yet to tune a BT car.
Speedie, I'm really looking forward to seeing what your car can do with a proper turbo. I was at Cobb when your car was on the dyno. There is a lot of potential there.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline
The Following User Says Thank You to senor blanco ms3 For This Useful Post:
zx2man (06-15-2010)
Closed Thread
PG Inlet Pipe Install manofhonor24 MazdaSpeed 6 - Engine, Transmission & Driveline 5 06-17-2009 10:55 PM
Stage 2 with an inlet pipe Stan-O
Cobb Access Port/Maps
13 03-19-2009 02:54 PM
ATP turbo inlet pipe? JimmyMac Mazdaspeed3/6 General Discussion 3 05-30-2008 12:02 AM
Page generated in 0.22602 seconds with 21 queries
