Closed Thread
 Old 05-10-2010, 10:26 AM   #1
Speedie6's Avatar
Posts: 1,838   (View Stats)
Default Big Turb, CPE XcelXL MAF housing, CPE inlet pipe
Quick question. Going big turbo, I know that CPE makes an inlet pipe and a 3.25" MAF housing. But, the inlet pipe, while offerring a 4" turbo end, seems to only be 3" on the other end. At least that is what it seems from the product description on the CP-E site. I'm just wondering why it isn't 3.25" to match the XcelXL MAF housing?
I know that there are some guidelines as to how much power you can make based on the diameter of the MAF housing. Though, I don't happen to remember what those are. So, what are the stats of 3" vs. 3.25"?
I happen to have a currently unused ATP 3" MAF. I was thinking I might just use that and CPE's 4" to 3" inlet pipe if the XcelXL won't really do me much difference.
I am now built with new rods/pistons, I just haven't yet decided what turbo to go with.
P.S. What is the AFE filter part number that the XcelXL comes with? I might try to find a 3" version of it to use with my ATP MAF.
Speedie6 is offline
 Old 05-10-2010, 11:24 AM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
The 3.25" MAF and flash is necessary tlo stop you from pegging the OEM MAF at higher boost levels...
SSinstaller is offline
 Old 05-10-2010, 11:33 AM   #3
Speedie6's Avatar
Yeah, I got that. The questions I had were, what's the power difference between 3" and 3.25"? I've got the ATP 3", and wondered what the difference in power limits between the two. Secondly, if 3.25" is necessary, shouldn't their inlet pipe for big turbos be 3.25" also? It doesn't seem to make sense to me to have a 3.25" MAF, to squeze it down to 3" and then balloon back to 4".
Speedie6 is offline
 Old 05-10-2010, 12:02 PM   #4
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Default Re: Big Turb, CPE XcelXL MAF housing, CPE inlet pipe
Just do it right the first time and get the stuff you need. 3.25 maf and flash.
2012 WRX HB w/mudflaps yo!
spnkr21 is offline
11cruzito11 (05-10-2010)
 Old 05-10-2010, 01:38 PM   #5
Speedie6's Avatar
Oh, and, by the way, the stock MAF housing is something like 2.62 or 2.65, I believe. The ATP according to my calipers is about 2.9" ID. So, the ATP is in the .25 to .3" bigger than stock. The CPE is, presumably something less than 3.25" ID, in order to use 3.25" hose, so, I presume about 3.15" ID or so.
AUTOMERGED FOLLOW-UP POST:
Well, I'm going to have it Cobb tuned.
My basic question here is, it doesn't seem to make sense to me that they made their BT inlet pipe 3" if their MAF housing is 3.25". So, if I use the CPE MAF, with their inlet pipe, then I'd need a 3.25" to 3" reducer which doesn't make sense to me.
Last edited by Speedie6; 05-10-2010 at 01:39 PM. Reason: MSF Database - Automerged Doublepost
Speedie6 is offline
 Old 05-11-2010, 08:08 AM   #6
Groans: 60
The CP-E big MAF is 3.5" OD and tapers to exactly 3.25" at the MAF...
The TIP is only 3" because it was made before the MAFXL, there is hardly enough room for the 3", going to 3.5" would necessitate moving the battery/ECM on the MS3, and not many are going to do that just for a big TIP...
xcoldricex (05-11-2010)
 Old 05-11-2010, 10:33 AM   #7
Speedie6's Avatar
Ah, thanks for the clarification. ATP rates theirs as 3" but that's OD, so, I was thinking that CPE's 3.25" figure was also OD. I presume that CPE's has an air straightener while the ATP does not. So, CPE's product is probably superior.
Yes, 3.5" would be tight. But, you could go with a smaller battery instead of a battery relocate. And, I would think that at least some people, if they are already going to the trouble of going big turbo, and possibly also being built, if they've gone to that much trouble, would also do what is necessary to make the 3.5" intake fit. I guess I'm just saying that if they made the MAF that big, I'd think they'd make a TIP to match it.
But, I guess not. So, I guess that's that.
Speedie6 is offline
 Old 05-11-2010, 10:55 AM   #8
Groans: 60
There is no air straightener in the CP-E MAF, but it was designed to be used with their flash and filter--most report fuel trims that are dead on or very close running the CP-E setup..
 Old 05-12-2010, 09:33 PM   #9
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
yeah there filter has a built in velocity stack so no need for a straightener.
xcoldricex is offline
 Old 05-10-2010, 01:58 PM   #10
ILL3ST
xcoldricex's Avatar
Groans: 105
just get the 3.25 maf and call it a day.
hahaha, people just skim and don't read the question - i don't know the power limits of 3" vs. 3.25" - but if you're getting it cobb tuned you can't get the flash... but i'm pretty sure you can just calibrate your maf tables?
i'd just keep the atp if it's already 3in. because yeah, you'll have the 3" restriction anyway if you go with the cp-e combo.
alternatively you could make a new 3.25" inlet and slap on a 4" to 3.25" coupler, coupled with the XL intake- you were the one that made inlets before right?
 Old 05-10-2010, 02:04 PM   #11
JumpingJackson's Avatar
Posts: 967   (View Stats)
If your going cobb just stick with the 3" ATP.
JumpingJackson is offline
 Old 05-10-2010, 03:39 PM   #12
Speedie6's Avatar
Yeah, I used to make inlets. Once Cobb and CPE started making silicone ones, I stopped making my aluminum ones.
And, yeah, I could make a 3.25" if I wanted to. But it would be aluminum and I'm thinking I might as well just get CPE's silicone one. I'm just kinda baffled at why CPE made the inlet 3" and their MAF 3.25".
I've already got an AP, and Cobb Tuning built my engine. So, yeah, I sticking with Cobb I think for the tuning. I know that CPE has had some breakthru that they are getting more power out of our cars than anybody else, but, I'm just not in the mood to switch teams. I do have a lot of CPE stuff, like towplate, DP, gaugepod, etc. And will get their inlet. But, I don't feel like switching to them for tuning at this point.
Speedie6 is offline
 Old 05-10-2010, 07:38 PM   #13
ILL3ST
xcoldricex's Avatar
Groans: 105
i for one prefer aluminum TIPs... just because of the sound
 Old 05-12-2010, 06:10 PM   #14
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Good luck making power with that tune
Off to my wedding
www.cp-e.com is offline
 Old 05-12-2010, 07:14 PM   #15
Groans: 60
Off to my wedding
Congrats!!! Er, I'm sorry???
However you want to take it...LOL
Wish you the best..
 Old 05-13-2010, 05:19 PM   #16
Speedie6's Avatar
Off to my wedding
Well, like I said, I've already kinda picked the Cobb horse for tuning. I understand you guys have found some stuff they haven't. But, I'm just not, at least for now, changing horses. I do have a lot of your stuff. I have the DP, tow plate and gauge pod.
Well, not sure about that. The Cobb SRI has a velocity stack and air straighter.
Last edited by Speedie6; 05-13-2010 at 05:19 PM. Reason: MSF Database - Automerged Doublepost
Speedie6 is offline
 Old 05-14-2010, 07:44 AM   #17
No worries - you'll make the switch if your turbo is of a decent size and then you don't make power. Cobb is a great company. They just haven't found the issue on this platform.
 Old 05-17-2010, 03:35 PM   #18
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
That's because the best person, IMO, that can tune a MS3/6 has yet to tune a BT car.
Speedie, I'm really looking forward to seeing what your car can do with a proper turbo. I was at Cobb when your car was on the dyno. There is a lot of potential there.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline
The Following User Says Thank You to senor blanco ms3 For This Useful Post:
zx2man (06-15-2010)
Closed Thread
PG Inlet Pipe Install manofhonor24 MazdaSpeed 6 - Engine, Transmission & Driveline 5 06-17-2009 10:55 PM
Stage 2 with an inlet pipe Stan-O
Cobb Access Port/Maps
13 03-19-2009 02:54 PM
ATP turbo inlet pipe? JimmyMac Mazdaspeed3/6 General Discussion 3 05-30-2008 12:02 AM
Page generated in 0.38940 seconds with 26 queries
