Closed Thread
 Old 05-09-2009, 09:49 AM   #1
ms3boost's Avatar
Posts: 400   (View Stats)
ms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to behold
Default cp-e big maf
how much is a cp-e big maf and is there any pictures
2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot
Future Mods[/B]auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal!
ms3boost is offline
 Old 05-09-2009, 10:28 AM   #2
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
i don't know how much it is, but it comes with an ECU flash. i do know that they are in stock so randy should be able to get it to you quickly.
i'll try to find some pics, but it is nothing special really. it's a tube with a MAF adapter on it. it is designed to be able to be used as is, or you can cut it up and weld it to some piping for a totally custom application. crazyitalian used some silicone to mate it up to the cp-e TIP.
killa cam is offline
 Old 05-18-2009, 12:30 PM   #3
johnac08's Avatar
Posts: 141   (View Stats)
johnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud of
jordan sent this pic to me. i believe its robbies car. i paid $250( i think this is the intro price) for the big maf and the flash is seperate. another $35.
johnac08 is offline
The Following User Says Thank You to johnac08 For This Useful Post:
phailerider (05-18-2009)
Closed Thread
Page generated in 0.23746 seconds with 22 queries
