Closed Thread
 Old 09-26-2008, 07:26 AM   #1
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
You would have to cut off most if not all of the cast piece and replace it with straight 3" tube for the v band. The bolts are not symetrical so I don't think you can bolt the atp piecs up backwards (to the dp). If you could you would also be adding a lot of lenght in between the turbo so the pipe would not have the correct bends. If you wanted a v band you would be better off buying an atp pipe than ruining a perfectly good cp-e dp.
CraigHJr is offline
Closed Thread
Modded stock turbo options, yes that is a 3" bellmouth.... ptperformance Mazdaspeed3/6 General Discussion 128 05-09-2009 04:53 PM
Ford posts $8.7B Q2 loss, will convert three truck factories to car production Haltech Automotive News 0 07-24-2008 08:10 AM
Paper Towel + Rubber Band = More Horsepower Crossbow MazdaSpeed 3 - Engine, Transmission & Driveline 11 06-10-2008 02:12 PM
Rock Band GAME ONLY (PS3) $29.90 Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Rock Band to Hit Wii on June 22 Haltech Computers & Technology News 0 03-26-2008 01:20 AM
Page generated in 0.23395 seconds with 21 queries
