  • 2 Post By Grumpyjap
 Old 06-13-2011, 09:23 AM   #1
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
Default cp-e motor mount long term review
For those of you that still have their cp-e mounts or are considering buying them I'm posting this and will be updating this on a fairly regular basis, at least every other month. Just to give piece of mind and some insight on these mounts.
First off regardless of my affiliation with cp-e, if these mounts were crap and would harm myself or my car in anyway I would NOT keep them on my car.
I have all cp-e mounts installed on my car.
Stage 2 Rear Motor Mount:
Installed 3/10/2012
Review coming soon.
Rear motor Mount:
Installed May 2009
7 Track days all at Monticello Motor Club as of 6/13/11 - Most recent Track Day 6/12/11
Visual inspection on 6/12/11 while still installed - no visible cracks, cannot feel any cracks either. I will uninstall and do a full visual inspection with pictures sometime this week. Normal and spirited driving has been the same since install(or after break in)
Passenger mount:
Installed January 2011
5 Track Days all at Monticello Motor Club as of 6/13/2011 - Most recent Track Day 6/12/11
Visual inspection on 6/12/11 while still installed - no visual cracks cannot feel any cracks either. Bolts still tights and holding strong.
Driver side mount:
Visual inspection on 6/12/11 while still installed - all bolts still tight.
Uninstalled for inspection. No visible cracks - 8 allen bolts still holding with original locktite. It actually took a great deal of force to unscrew one of the bolts. I only took 1 bolt out and checked with a fair amount of force how the others were holding up. Obviously, I reinstalled with the same locktite.
This is the Locktite I used
08.5MS3 and Monotonous ONE like this.
The Following 14 Users Say Thank You to Grumpyjap For This Useful Post:
08.5MS3 (07-08-2011), Adam is so pro (02-08-2012), ak_spray (03-14-2012), AZSPEED3 (03-11-2012), CWP_MS3 (04-23-2012), Easter Bunny (06-13-2011), helmetface (03-12-2012), JP@edgeautosport.com (06-13-2011), Monotonous ONE (06-13-2011), Nataphen (03-11-2012), pebenito (06-13-2011), Raider (06-13-2011), ruthless013 (08-06-2011), SgtP (06-19-2011)
 Old 03-11-2012, 10:04 AM   #2
Grumpyjap's Avatar
Update 3/11/12: (I promise this season I will update regularly)
RMM - I uninstalled this as I am upgrading to the stage 2 RMM. On visual inspection there are no cracks or tears in the bushing. RMM is still holing strong. Only a slight difference in stiffness since they were installed, but this is to be expected with any aftermarket RMM. After just shy of 3 years of hard driving I think its safe to say that this product held up. The bushings are the original bushings I got back in May 2009. I figured I'd wait until after the winter to do this update. Here are the pictures of it uninstalled.
I will be uninstalling the side motor mounts later and post pictures of those.
Edit: I will also be posting a step by step/review of the stage 2 RMM soon. Cliffnotes: AWESOME!!!!
The Following 4 Users Say Thank You to Grumpyjap For This Useful Post:
2008speed3 (03-12-2012), ak_spray (03-14-2012), AZSPEED3 (03-11-2012), Nataphen (03-11-2012)
 Old 03-11-2012, 10:48 AM   #3
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
As many already know, I think the Stage 2 Rear Mount is the Cat's Pajamas:
http://www.mazdaspeedforum.org/forum/foru...r-mount-98167/
I look forward to hearing your impressions as well.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
86AmishMs3 (04-02-2013)
 Old 03-11-2012, 09:12 PM   #4
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
I have it and the car feels more "stable" i guess is the best word. Its easier to control the chassis with the throttle near the apex then with the stage 1 mount. I also have both side cpe mounts at 70D.
Fueled by the haters.
Celestspeed3 is offline   Reply With Quote
 Old 03-12-2012, 06:45 PM   #5
Grumpyjap's Avatar
Install and review for cp-e stage 2 RMM
cp-e stage 2 RMM Review/walkthrough
 Old 03-14-2012, 11:12 AM   #6
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
What Duro side mounts do you have?
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
 Old 03-24-2012, 10:06 AM   #7
Grumpyjap's Avatar
75
The Following User Says Thank You to Grumpyjap For This Useful Post:
ak_spray (03-24-2012)
 Old 03-24-2012, 10:11 AM   #8
Grumpyjap's Avatar
Update on Driver side mount.
Visual inspection looks fine. 3/24/12
With the red locktite and no backing plate the screws are holding up good. All screws intact and tested 2 scews it took a great deal of force to get them out.
mounts feel the same since after break in. Coupled with the stage 2 mounts this is an awesome set.
Again, regardless of my affiliation with cp-e, if these mounts were crap and would harm myself or my car in anyway I would NOT keep them on my car nor would I post false information about these. I would not want to damage or injure any of my friends on this forum.
08.5MS3 (03-26-2012), ak_spray (03-24-2012), cld12pk2go (03-24-2012), Nliiitend1 (03-24-2012)
 Old 04-26-2013, 11:36 AM   #9
Grumpyjap's Avatar
over 2 years into the driver side mount and it's still performing like new, well from after the break in period. Just took the mount out to inspect.
I do NOT have the backing plate installed, it's going in when I reinstall now. Red Locktite held up perfect. Bolts did not back out even a millimeter. Bushing is still good, no cracks.
I will be doing the passanger side and stage 2 rmm in the near future.
The Following 6 Users Say Thank You to Grumpyjap For This Useful Post:
08.5MS3 (04-29-2013), cld12pk2go (04-26-2013), Code Monkey (04-26-2013), El_Diablo (04-26-2013), Erich (04-26-2013), Nliiitend1 (04-26-2013)
 Old 04-26-2013, 12:52 PM   #10
708
Erich's Avatar
Posts: 4,274   (View Stats)
Excellent. Between these reviews and the CS I am receiving from CP-e, I have a lot of confidence in having these mounts on my car.
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
The Following User Says Thank You to Erich For This Useful Post:
super_pablo_ (04-26-2013)
 Old 04-29-2013, 05:15 PM   #11
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
You don't have the CPE tranny mount fix?
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 04-30-2013, 07:06 AM   #12
Grumpyjap's Avatar
The backing plate? Yes I've had it for a while, I just haven;t gotten around to installing it, but I really didn't need it. Since january 2011, with just red loctite, It's held up just fine. Backing plate is on now so It's a nice peace of mind. I'll be taking out the passanger side mount and stage 2 rmm within the next few weeks for review. Visual inspection of both mounts look good.
 Old 04-30-2013, 12:46 PM   #13
86AmishMs3's Avatar
Groans: 338
i just wasn't sure if a lot of people knew about it...i found out about it from a friend who got a new one...
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Long Term: 2011 Volkswagen Jetta TDI joins Autoblog's Long-Term Garage Haltech Automotive News 0 05-31-2011 01:40 PM
CP-E motor mount review and analysis. Sacrilicious MazdaSpeed 3 - Engine, Transmission & Driveline 63 07-08-2008 09:52 PM
Page generated in 0.35633 seconds with 25 queries
