Closed Thread
 Old 01-06-2011, 01:55 PM   #1
Adam is so pro's Avatar
Posts: 410   (View Stats)
Adam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the world
Default cp-e Sneak Peek- Big Turbo Upgrade
We are proud to give you guys a “sneak peek” into our new big turbo upgrade for the MazdaSPEED3 chassis. This release shows our new downpipe / dumptube (exit pipe) designed around our 2010 MazdaSPEED3 test vehicle that was recently displayed at PRI (Performance Racing Industry) Trade Show recently held in Orlando, Florida.
This downpipe has some key elements that really add to its design merit, re-circulated wastegate dumptube, 304 Stainless Steel construction, TIG welded (not completed in picture, as this is our prototype), extra available wideband lambda sensor bung, and integrated flex piping for both the main exhaust exit and the dumptube exit.
The re-circulating wastegate dumptube is just an example of how cp-e™ really goes the extra mile with design and engineering. Some other aftermarket manufacturers sell downpipes with separate wastegate dumptubes that just exit to atmosphere; we see this as a lazy method of design. With a re-circulating wastegate dumptube, you do not have the danger of extremely hot exhaust gases exiting within the engine bay, potentially causing engine heat soak and putting any sensitive parts (electrical or otherwise) in danger of overheating or melting. The exhaust from the wastegate will exit out the rear of the car, just like the rest of the engines exhaust output.
With the construction done in 304 Stainless Steel, you will never need to worry about rust or any other type of detrimental corrosive damage. TIG welded junctions mean strong, lasting welds, completed by our talented in house welding staff.
The extra lambda sensor bung at the elbow of the outlet is critical for easy installation of an aftermarket wideband lambda sensor to aid in precision tuning of the fueling requirements of the engine.
The flex joints in both the wastegate dumptube, and the main downpipe are critical for longevity of the entire assembly. If you have stock engine mounts or solid aluminum engine mounts, the engine still has vibrations and movement that the downpipe and exhaust assembly is subject to. The flex joints in our downpipe are a way to relieve the stress caused by normal engine movement to prevent the possibility of a broken weld or cracked downpipe assembly.
Stay tuned for further releases on our MazdaSPEED3 big turbo upgrade!
Adam is so pro is offline
The Following 31 Users Say Thank You to Adam is so pro For This Useful Post:
acidbbg (01-07-2011), AJ713 (01-06-2011), Alpha (01-07-2011), Ckmazdaspeed3 (01-06-2011), clowncar (01-06-2011), djuosnteisn (01-06-2011), doubleflusher (01-07-2011), EwMPS (01-07-2011), fishin53 (01-06-2011), jax ms3gt (01-06-2011), jracer (01-13-2011), KeysMS3 (01-06-2011), kgb (01-09-2011), mason (01-11-2011), MPSdriver (01-08-2011), mr_mazda329 (01-06-2011), MS3-a(sore)ASS-rex (01-06-2011), ms3=evokilla (01-07-2011), PapaSmurf (01-06-2011), phillyb (01-06-2011), rfinkle2 (01-06-2011), Speed3eak (01-14-2011), Speedn3 (01-06-2011), spnkr21 (01-17-2011), stefan (01-06-2011), super_pablo_ (01-14-2011), taf0422 (01-06-2011), wankular (01-06-2011), wolly6973 (01-07-2011), www.cp-e.com (01-06-2011), xcoldricex (01-07-2011)
 Old 01-06-2011, 01:58 PM   #2
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Very nice. Glad to see a comapny like cp-e making big moves for our platform!
NATOR PA
MS3-a(sore)ASS-rex is offline
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
djuosnteisn (01-06-2011), super_pablo_ (01-14-2011)
 Old 01-06-2011, 06:11 PM   #3
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Good stuff. Will be good for those of us who do not want to venture into the whole BT thing ourselves. Having a kit will be perfect, especially from a top notch company such as cp-e. No thank you RR. Keep up the stellar work!
08.5MS3 is offline
 Old 01-06-2011, 06:16 PM   #4
inseong's Avatar
Posts: 43   (View Stats)
inseong will become famous soon enoughinseong will become famous soon enough
this is stupid question i think since theyre both the same motors..... BUT, will this also bolt on flawlessly to the 1st gen ms3? btw dp looks NIIIIICE
inseong is offline
 Old 01-06-2011, 06:18 PM   #5
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
who the fuck are you???
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
The Following User Says NO Thank You to 802MS3 For This Un-useful Post:
Boostaholic (01-07-2011)
 Old 01-06-2011, 06:19 PM   #6
Boostaholic's Avatar
Posts: 203   (View Stats)
Boostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond reputeBoostaholic has a reputation beyond repute
Groans: 53
Groaned at 150 Times in 24 Posts
When and where in Orlando was this pri tradeshow?
Boostaholic is offline
 Old 01-06-2011, 06:28 PM   #7
inseong's Avatar
Neutral  :  -1 score
<-- my name. yea, i dont come online too much since i work all the time. just started getting into the car modding again. i was just curious is all since i know cp-e is the good stuff and they only mentioned 2010 and not prev. gen.
inseong is offline
The Following User Says Thank You to inseong For This Useful Post:
The Following User Says NO Thank You to inseong For This Un-useful Post:
 Old 01-06-2011, 06:29 PM   #8
R.MS3's Avatar
Posts: 987   (View Stats)
R.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the world
Neutral  :  -1 score
Prices soon or ban.
R.MS3 is offline
The Following User Says Thank You to R.MS3 For This Useful Post:
The Following User Says NO Thank You to R.MS3 For This Un-useful Post:
 Old 01-06-2011, 07:01 PM   #9
Jessman's Avatar
Posts: 232   (View Stats)
Jessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond reputeJessman has a reputation beyond repute
Thats a thing of beauty
Me Loves Me Speed
Jessman is offline
 Old 01-06-2011, 07:12 PM   #10
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
This is very nice, but we really need an exhaust manifold to go along with it...
Oh, and a big turbo too
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
Cataphract_40 is offline
 Old 01-06-2011, 08:32 PM   #11
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
This is just part one, but have no fear, there is an exhaust manifold and a turbo (as we designed this DP with the manifold and turbo installed). Stay tuned for releases.
-Sander
Website: www.cp-e.com
www.cp-e.com is offline
The Following 10 Users Say Thank You to www.cp-e.com For This Useful Post:
AJ713 (01-08-2011), Alpha (01-07-2011), AZRushki (01-14-2011), banditscout (01-06-2011), Cataphract_40 (01-06-2011), djuosnteisn (01-07-2011), KeysMS3 (01-06-2011), MPSdriver (01-08-2011), MS3-a(sore)ASS-rex (01-07-2011), taf0422 (01-20-2011)
 Old 01-06-2011, 08:43 PM   #12
harryclay's Avatar
Posts: 685   (View Stats)
harryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the world
Nice I bet this will be out just in time for when my 2010 KO4 gets KOed.
2010 super smiley Red MS3
- Corksport SRI/TIP
- ETS TMIC
- CNT hiflow catted long DP
- Sure boost tubes
- SURE motorsports anchors
- SU RMM
- Greddy Type S BPV
- KMD HPFP Internals
- harryclay tune
- Semi-flat black wheels (painted stockers)
- Eibach pro springs ftw
- Michelin Pilot Super Sports 235/40/18
- Yellow 55v fogs
13.69 @ 106 (4g eth mix, intake/tune)
13.67 @106 (intake,dp,tmic, 50/50 eth)
harryclay is offline
 Old 01-06-2011, 08:48 PM   #13
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
MSRP: eleventy billion dollars...
Time frame: 2 weeks ^3 months
Sent from my iPhone using lame ass Tapatalk
hnda etr is offline
The Following 12 Users Say Thank You to hnda etr For This Useful Post:
AZRushki (01-08-2011), banditscout (01-06-2011), Ckmazdaspeed3 (01-06-2011), fishin53 (01-08-2011), kgb (01-09-2011), manelscout4life (01-06-2011), MS3-a(sore)ASS-rex (01-07-2011), stefan (01-06-2011), super_pablo_ (01-14-2011), turd burglar (01-07-2011), wankular (01-07-2011), xcoldricex (01-07-2011)
 Old 01-06-2011, 08:53 PM   #14
my fav part was when you said VTA WG was for lazy people,
recirced EWG is for PUSSYS!!!!!
and my dump tube exits below the subframe so nothing is getting burnt........
superskaterxes is offline
The Following 6 Users Say Thank You to superskaterxes For This Useful Post:
11cruzito11 (01-07-2011), harryclay (01-06-2011), madvillain (01-07-2011), manelscout4life (01-06-2011), super_pablo_ (01-14-2011), turd burglar (01-07-2011)
 Old 01-06-2011, 09:30 PM   #15
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I guess this will give me an excuse to dump my current downpipe/k04...hmm
I like this very much!! Subbed for more details! I wants it all
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
taf0422 is offline
 Old 01-06-2011, 09:34 PM   #16
I was hoping someone would like it! Haha
 Old 01-06-2011, 09:59 PM   #17
hnda etr's Avatar
Groans: 90
Sander, any "hints" as to cost for this complete kit?
I'm guessing.... $3400.... How did I do?
hnda etr is offline
 Old 01-06-2011, 10:13 PM   #18
We haven't even discussed a final price yet. So I don't know either.
-Sander
 Old 01-06-2011, 10:38 PM   #19
hnda etr's Avatar
Groans: 90
-Sander
Well no matter what the final price is, I'm guessing I'm pretty close lol...
Please keep in mind though, that this is a budget racer, not a luxury racer, and not a lot of people can afford to fork over $3k (or more knowing cpe prices) for a kit like this, when for $1600-$1800 they could get an ATP turbo that doesn't require a new ex mani and DP...
I'm not saying that $3500 for a drop in turbo kit is bad, shit, my boss' friend just paid something like $12K for a drop in supercharger kit for his Audi S4 (or some Audi like that)... But this is a luxury racer...
Just be sensitive to your market.
hnda etr is offline
AJ713 (01-08-2011), DSIT995 (01-07-2011), kgb (01-09-2011), MPSdriver (01-08-2011), SpeedNess (01-07-2011), super_pablo_ (01-14-2011), taf0422 (01-07-2011), the_caruch (01-07-2011), turd burglar (01-07-2011), wankular (01-07-2011), www.cp-e.com (01-07-2011), ZoomZoomPSSH (01-23-2011)
 Old 01-07-2011, 06:41 AM   #20
Lama's Avatar
Posts: 339   (View Stats)
Lama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond repute
Will it be available for the speed6?
Mazdaspeed 6 2007 GT : Cobb AccessPORT, Cobb Stage 2+SF TIH 91 BT map, Cobb SF SRI, Cobb Turbo Inlet, Cobb shifter weight, Cobb XLE BPV, Cp-e TMIC, SAMCO Xtraflex recirc hose, AutoEXE Boost tubes, CP-e Rear Motor Mount, Cp-e diff mount, SURE juggernaut, Magnaflow Catback , SU Test pipe, TWM Short Shifter Stage 2 & Bushings, DashHawk, Denso ITV-22, RPM sport springs, whiteline RSB, freins Rotora, TSW nurburgring wheels
Lama is offline
The Following 3 Users Say Thank You to Lama For This Useful Post:
Alpha (01-07-2011), amoosenamedhank (01-20-2011), MPSdriver (01-08-2011)
 Old 01-07-2011, 08:01 AM   #21
Alpha's Avatar
Posts: 3,711   (View Stats)
ALAS!!! It's getting close! I want one of the first kits! MS6 ready to go!!!
Will this DP be available catted as well? Looks like that routing would force it to be catless across the board.
Alpha is offline
 Old 01-07-2011, 09:51 AM   #22
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Alpha, so far... this is a speed3 kit. It will require a different down pipe for the speed6.
This platform needs more complete kits. I think this is a big step in the right direction.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
Alpha (01-07-2011), MPSdriver (01-08-2011), MS3-a(sore)ASS-rex (01-07-2011), Speed3eak (01-14-2011), super_pablo_ (01-14-2011)
 Old 01-07-2011, 12:27 PM   #23
Trust me, we are definitely aware of this. We spend a lot of meeting time on determining these types of decisions, and we know it's not a GTR, R8, or whatever. It will be priced accordingly.
The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post:
AJ713 (01-08-2011), MPSdriver (01-08-2011), Speed3eak (01-14-2011), super_pablo_ (01-14-2011)
 Old 01-07-2011, 12:31 PM   #24
Alpha's Avatar
Thumbs up
Good call, and yes... A HUGE step in the right direction!
Alpha is offline
 Old 01-07-2011, 04:49 PM   #25
taf0422's Avatar
Groans: 192
Yayy! For this being thought out already about the price! I like the sound of that. Cp-e is definitely taking the right steps to bump this platform even more. I'm like 2011..
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
taf0422 is offline
The Following 2 Users Say Thank You to taf0422 For This Useful Post:
AJ713 (01-08-2011), djuosnteisn (01-07-2011)
 Old 01-07-2011, 05:01 PM   #26
Captain
Originally Posted by taf0422 View Post
...I'm like 2011..
I'm like 2047
www.permtuning.com
taf0422 (01-08-2011)
 Old 01-07-2011, 10:31 PM   #27
taf0422's Avatar
Groans: 192
hahaha...I can wish can't I.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
taf0422 is offline
 Old 01-07-2011, 11:56 PM   #28
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
ugh recirced wastegates are total bonerkills.
madvillain is offline
The Following User Says Thank You to madvillain For This Useful Post:
 Old 01-08-2011, 12:09 AM   #29
cageyvet's Avatar
Posts: 715   (View Stats)
I think it will be priced fairly but not cheap. I really hope the kit comes with something along the lines of a gt35r instead of 3076. The downpipe does looks like its coming together nicely.
cageyvet is offline
The Following 2 Users Say Thank You to cageyvet For This Useful Post:
Alpha (01-14-2011), djuosnteisn (01-11-2011)
 Old 01-08-2011, 01:35 AM   #30
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
recirced EWG is for PUSSIES!!!!!
FIXED
rodrigo is offline
Cataphract_40 (01-08-2011)
 Old 01-08-2011, 12:41 PM   #31
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
A 35r? What's wrong with you cagey.
2012 WRX HB w/mudflaps yo!
spnkr21 is offline
 Old 01-08-2011, 02:15 PM   #32
Alpha's Avatar
I love the prefabbed recirc tube, that's the only way I'd go EWG with a car like this.
Alpha is offline
spnkr21 (01-10-2011)
 Old 01-08-2011, 02:54 PM   #33
spnkr21's Avatar
Groans: 105
I have a screamer pipe now but will change to recirc next month. Way too loud. Can't be in boost without everyone within 2mi knowing. Smart choice cp-e. Plus it keeps it legal.
spnkr21 is offline
11cruzito11 (01-08-2011)
 Old 01-14-2011, 06:38 PM   #34
Mistersix's Avatar
Posts: 2,585   (View Stats)
Nice to see cp-e steppin up. Now, just make a kit for the speed 6. PLEEEEZZZ!
Mistersix is offline
The Following 2 Users Say Thank You to Mistersix For This Useful Post:
Alpha (01-14-2011), MPSdriver (01-16-2011)
 Old 01-14-2011, 06:49 PM   #35
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
hmmm... subbed for interest (ill check back in a couple years to see if this kit is out yet)
super_pablo_ is offline
 Old 01-14-2011, 09:13 PM   #36
Alpha's Avatar
Thumbs up
+100!!!
Alpha is offline
 Old 01-20-2011, 02:02 PM   #37
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
Agreed, this isn't a SRT-4... some of us would still like to maintain the DD appeal of the car.
You know.... Moose stuff
amoosenamedhank is offline
 Old 01-20-2011, 06:20 PM   #38
07ms3obrien's Avatar
Posts: 157   (View Stats)
07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold
Can't wait to see the final package!
Gunna wait to go bt to see what turbo yins use.
2006 Evolution 9 SE- ported and polished 16g, ported manifold, buschur icp, buschur 3" tbe, buschur MBC (23lbs), buschur mini battery, NGK 1 step colder plugs, custom intake with blox filter, and some appearence shiiiat.
2007 Mazda Speed3 cosmic blue-Stock for now..
07ms3obrien is offline
Closed Thread
Nissan provides a sneak peek of the Juke Haltech Automotive News 0 02-10-2010 11:50 AM
Smoker6 Turbo Sneak Peek Smoker6 MazdaSpeed 6 - Engine, Transmission & Driveline 84 06-05-2009 05:33 PM
Sneak peek - 3" reinforced silicone turbo inlet! www.cp-e.com Custom Performance Engineering (cp-e.com) 102 01-13-2009 05:57 PM
Take a sneak peek at Top Gear Australia Haltech Automotive News 0 09-13-2008 09:10 AM
GM gives very early sneak peek at next-gen Astra Haltech Automotive News 0 09-08-2008 10:00 AM
Page generated in 0.59562 seconds with 44 queries
