 Old 08-08-2017, 02:00 PM   #1
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Default CP-E Stage 2 RMM significantly damaging the transmission case?
Found this posted on CP-E's website under reviews. It is from the beginning of this month. It is NOT my review --
"Just be careful with this mount it made my shifts feel so much better. You will be moving the stress in a different location of the car. A section of my transmission housing broke off after a couple of months on my car sad to say I’ve had to take this mount off my car so that further damage is not done. Going to be looking at other options. It may have just been my transmission was weak in that section from the factory. If you want to see here’s a link to the photos taken.
(image links) "
I'm concerned for my own trans. Was this a random failure or the product of running this mount for an extended period of time?
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 08-08-2017, 02:26 PM   #2
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
Looks more like something bounced up from under the car and hit it to me
Sent from my SM-G920V using Tapatalk
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
The Following User Says Thank You to nekret For This Useful Post:
cyclist20 (08-10-2017)
 Old 08-08-2017, 03:13 PM   #3
Shwa's Avatar
Posts: 322   (View Stats)
Have to agree with road debris, there are no signs of wear on the mount or chipping in the finish.
I have had this mount for 3 years and at 400hp/tq it has been a champ nad vibs are minimal. I am happy with it at least.
 Old 08-08-2017, 03:31 PM   #4
aackthpt's Avatar
Posts: 1,450   (View Stats)
Still keeping mine, not worried. This guy had it a couple months - that's nothing. Many people have had it much longer and not had a problem, except the early adopters for whom the bushing retainer screws were vibrating loose which cpe fixed with threadlocker.
LOL. Nad vibes are minimal with mine, too.
2013 'speed3, silver
Stage Bro
Last edited by aackthpt; 08-08-2017 at 03:31 PM. Reason: MSF Database - Automerged Doublepost
Shwa (08-09-2017)
 Old 08-09-2017, 02:12 AM   #5
Shwa's Avatar
It's disappointing, my nads want the vibs
 Old 08-09-2017, 09:57 AM   #6
Bexar's Avatar
Well good to know there are plenty of people running it over a few months. Just locktited them last evening
JBR:
 Old 08-10-2017, 10:24 AM   #7
Bexar's Avatar
Update from CP-E:
"You don’t need to worry about the RMM causing any harm to other parts of your vehicle.
Our mount was designed to perfectly align with both the front-sub frame mounting points as well as the mounting locations on the transmission itself, thereby not creating any additional stress points on either the sub-frame itself or the transmission housing. While the bushing we use is stiffer than the factory compound, this does not increase or “transfer” stress to the mounting points.
Sounds good to me I guess
JBR:
 Old 08-10-2017, 11:02 AM   #8
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Say Chi Sin Lo has disabled reputation
Had a 2x4 lodged near the side jack point of the car, need CP-E complaint line, and ask for a reimbursement in the form of their Stage 2 RMM.
Thanks!
2009 Mazdaspeed 3 GT
CWP
Mazdaspeed Coilovers // BMW E46 M3 Front Endlinks (works perfectly) // SPC Rear Camber Arms // Mazdaspeed CAI // CP-E Turbo Inlet // TurboXS BPV // CP-E 60 Duro RMM // Damond PMM // TWM Short Shifter // JBR Shifter Bushings // JBR Heavy Shift Knob
I have an Autotech HPFP laying around, just too lazy to install it.
Say Chi Sin Lo is offline   Reply With Quote
The Following User Says Thank You to Say Chi Sin Lo For This Useful Post:
dagrimey1 (11-03-2017)
 Old 08-11-2017, 08:35 AM   #9
Bexar's Avatar
Thanks!
10/10 would compensate you with the stage 2 rmm and pmm/tmm
JBR:
How optimizing aerodynamics significantly increases EV range Haltech Automotive News 0 02-20-2017 12:10 PM
Leaking something out of the transmission/transfer case I think. scnewt MazdaSpeed 6 - Engine, Transmission & Driveline 25 03-19-2013 06:46 AM
Transmission, Transfer Case, Rear Diff Oil arnobg MazdaSpeed 3 - Engine, Transmission & Driveline 1 08-30-2012 10:10 AM
Page generated in 0.29050 seconds with 25 queries
