Closed Thread
 Old 02-22-2009, 08:48 PM   #1
udontknowjack's Avatar
Posts: 201   (View Stats)
udontknowjack has a spectacular aura aboutudontknowjack has a spectacular aura about
Default cpe fmic question
will that plastic piece bottom of the engine fit with the cpe fmic??
udontknowjack is offline
 Old 02-22-2009, 09:00 PM   #2
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
si
killa cam is offline
 Old 02-22-2009, 09:16 PM   #3
Originally Posted by killa cam View Post
si
thanx
 Old 02-22-2009, 09:30 PM   #4
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
ya everything stock goes right back on no problems at all. The undertray bolts up fine, on my car I put the tbolt clamps facing downward so the long exposed bolt part touches the undertray but it still fits like stock. I just need to rotate the clamps a little. only real mod needed is bend the ambient air temp sensor out so it dont touch the core at all
bykeryder4life is offline
 Old 02-23-2009, 01:06 AM   #5
Aussie Mod
MattMPS3's Avatar
Posts: 98   (View Stats)
MattMPS3 is a splendid one to beholdMattMPS3 is a splendid one to beholdMattMPS3 is a splendid one to beholdMattMPS3 is a splendid one to beholdMattMPS3 is a splendid one to beholdMattMPS3 is a splendid one to beholdMattMPS3 is a splendid one to beholdMattMPS3 is a splendid one to behold
Good to know Im not the only one who has done this, I felt like an idiot when I went to refit the undertray.
MattMPS3 is offline
 Old 02-22-2009, 10:01 PM   #6
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
just to clarify. by si cam meant yes.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
Originally Posted by rodrigo View Post
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
 Old 02-23-2009, 08:33 AM   #7
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
hahaha, i need to refit the undertray as well. i actually need to adjust some of that piping.
i moved my temp sensor cause i didn't want it blocking the ic...i know it's st00pid, i but i hated the look of that black thing in front of the ic
phillyb is offline
 Old 02-23-2009, 10:23 AM   #8
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
lol- I thought it looked like it was missing a tooth, and being from NC, people could relate better to that...
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline
The Following User Says Thank You to Derek88 For This Useful Post:
miguelbates (03-03-2009)
 Old 02-23-2009, 01:47 PM   #9
phillyb's Avatar
Groans: 1,940
wow...with the pirate eye intercooler and a missing tooth, the cpe fmic is the most bad ass kit...
i would groan that post if i were me...i am me, but you know what i mean
phillyb is offline
 Old 02-23-2009, 07:24 PM   #10
SpyNaldo's Avatar
Posts: 21   (View Stats)
SpyNaldo is an unknown quantity at this point
why the CPE front mount doesnt look centered?
SpyNaldo is offline
 Old 02-23-2009, 07:54 PM   #11
Derek88's Avatar
^ dont quote me on this, but I think they wanted it to be possible to go 100% back to stock. If it's centered, you would have to cut off some plastic tabs in the front bumper.
-Derek
Derek88 is offline
 Old 02-23-2009, 11:45 PM   #12
phillyb's Avatar
Groans: 1,940
i quoted you
phillyb is offline
Derek88 (02-24-2009)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f330/cpe-front-mount-intercooler-question-21852/
Day of 2/23/2009: Top 50 of 204 Referring Pages This thread Refback 02-24-2009 07:56 AM
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
CorkSport FMIC Question...(Heat-soak could still be an issue?) Teacher MazdaSpeed 3/6 - Turbo Induction 3 12-31-2008 12:43 AM
FMIC Core Sizing question bykeryder4life MazdaSpeed 3/6 - Turbo Induction 2 09-17-2008 12:36 PM
FMIC and license plate question Unoriginalusername MazdaSpeed 3/6 - ECU Computer Tuning 34 07-27-2008 02:08 PM
Question about TXS FMIC Derek88 MazdaSpeed 3/6 - Turbo Induction 12 04-10-2008 08:24 PM
Page generated in 0.32335 seconds with 27 queries
