 Old 12-02-2015, 08:51 PM   #1
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
I have a cpe catted downpipe which is a long downpipe so there is no race/test pipe to speak of.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
The Following User Says Thank You to nekret For This Useful Post:
xorphanx (12-02-2015)
 Old 12-03-2015, 11:52 AM   #2
xorphanx's Avatar
Posts: 386   (View Stats)
xorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond repute
Does that DP pass smog? I know it won't pass visual but i'm not worried about that.
xorphanx is offline   Reply With Quote
cp-e Triton Cat Back Exhaust EdgeAutosport.com EdgeAutosport.com 14 11-25-2015 02:24 PM
GEN2 CP-E Triton exhaust review rfinkle2 2010 MS3 - Engine, Transmission & Driveline 53 05-09-2013 10:02 AM
CP-E triton exhaust bryansawiseone 2010 MS3 - Engine, Transmission & Driveline 9 07-11-2012 07:01 AM
MazdaSPEED3 Gen2 Triton™ 3" SS Cat Back Exhaust System www.cp-e.com Custom Performance Engineering (cp-e.com) 4 05-09-2012 06:01 AM
Page generated in 0.25493 seconds with 23 queries
