 Old 12-22-2015, 07:41 PM   #41
xorphanx's Avatar
Posts: 386   (View Stats)
xorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond repute
Here you go gentz. without further ado
2013 MS3 Velocity Red with Techpackage
xorphanx is offline   Reply With Quote
The Following 4 Users Say Thank You to xorphanx For This Useful Post:
bennyzoom (12-23-2015), her2013speed3 (02-21-2016), MD1032 (12-23-2015), Shwa (12-23-2015)
 Old 12-23-2015, 03:16 PM   #42
bennyzoom's Avatar
Posts: 20   (View Stats)
bennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of light
http://youtu.be/OEZ9XYxrg8A
Sounds sick, thanks for the clip!
bennyzoom is offline   Reply With Quote
 Old 12-23-2015, 03:22 PM   #43
xorphanx's Avatar
No problem, I'm going to throw a catless downpipe on hopefully in jan-feb timeframe. Should make a world of difference, especially with everything else i'm doing at that time. After february i'll be done with performance at least for awhile until I can get my financials under control again lol!!
 Old 12-23-2015, 03:31 PM   #44
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Crazy, that sounds really similar to stock (I like it). Did you look inside the pipe to see what the design of the muffler was? Was it straight through like a resonator or baffled like the stock one?
2007 Mazdaspeed3 GT
 Old 12-23-2015, 04:23 PM   #45
Finchee's Avatar
Posts: 306   (View Stats)
Finchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond repute
How is the volume inside the cabin? Can you hear it with the windows up even with just regular shifting/downshifting?
2013 Mazdaspeed3 with Tech Package
Autotech Fuel Pump Internals
Cobb Accessport V3
Continental ExtremeContact DWS06
CorkSport SRI, TIP
CP-E xFlex Stage 1 65A Rear Motor Mount
Damond Motorsports Short Shift Plate
ETS TMIC
James Barone Racing Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit
Magnaflow CBE
NGK Iridium IX Step Colder Plugs
Dizzy Tune in progress...
Finchee is offline   Reply With Quote
 Old 12-23-2015, 04:27 PM   #46
xorphanx's Avatar
I actually didn't look... I can message CP-E though and ask them if you'd like.
Yes, its quite louder than the stock inside the cab, but that could also be from all the suspension mods i've done causing more cabin noise than usual... I love the way it sounds when I open her up on the freeway though! especially with the combination of the CS TIP creating the whoooosh sound lol
Last edited by xorphanx; 12-23-2015 at 04:27 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-23-2015, 04:46 PM   #47
Finchee's Avatar
That's what annoys me right now. When I go WOT, I can barely hear my CBE, most of all I hear is my Corksport SRI + TIP. I'm getting a racepipe installed in the future to possibly remedy that. If that doesn't work, then I'm getting a new CBE, which is either going to be a Cobb, Corksport or this Triton CBE.
Cobb Accessport V3
CorkSport SRI, TIP
ETS TMIC
Magnaflow CBE
 Old 12-23-2015, 04:48 PM   #48
xorphanx's Avatar
Yeah, that CS Stage 2 intake is pretty loud because of the aluminum, I can only imagine it being worse once I go 3-3.5" intake, but can't have amazing power without sacrificing a little bit...
 Old 12-23-2015, 07:27 PM   #49
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
You can always delete your resonator(s) and do a test pipe it has a nice sound to it... Had my resonator deleted on my stock cbe everyone thought I had exhaust
 Old 12-23-2015, 08:31 PM   #50
xorphanx's Avatar
i did the UR TP with high flow res, if i'm going to replace that with anything i'm going with a long catless dp
 Old 02-20-2016, 12:53 PM   #51
mceatalot's Avatar
Posts: 34   (View Stats)
mceatalot has a spectacular aura aboutmceatalot has a spectacular aura about
Groaned at 8 Times in 3 Posts
Will you need a tune if you go with the cp-e cbe? I've only got stage 1 CS intake with TIP, but will be getting a used cpe cbe in the next few days. Thanks in advance!
mceatalot is offline   Reply With Quote
 Old 02-21-2016, 11:32 AM   #52
xorphanx's Avatar
No, good luck with the install, it took me 6 hours to do my testpipe and exhaust without a lift.... But I was also by myself
cp-e Triton Cat Back Exhaust EdgeAutosport.com EdgeAutosport.com 14 11-25-2015 02:24 PM
GEN2 CP-E Triton exhaust review rfinkle2 2010 MS3 - Engine, Transmission & Driveline 53 05-09-2013 10:02 AM
CP-E triton exhaust bryansawiseone 2010 MS3 - Engine, Transmission & Driveline 9 07-11-2012 07:01 AM
MazdaSPEED3 Gen2 Triton™ 3" SS Cat Back Exhaust System www.cp-e.com Custom Performance Engineering (cp-e.com) 4 05-09-2012 06:01 AM
Page generated in 0.32260 seconds with 26 queries
