Like Tree9Likes
  • 1 Post By Raider
  • 5 Post By www.cp-e.com
  • 1 Post By lilred
  • 2 Post By sidekick
 Old 03-24-2013, 06:17 PM   #1
grantmm's Avatar
Posts: 826   (View Stats)
Groaned at 8 Times in 5 Posts
Default Drivers side transmission mount QC - Terrible!
Notice how one half of the holes will not line up with the bushing part of the mount.
You can clearly see that the manufacturing process was off by 2 or 3 mm.
This shows that the other side lines up perfectly
@801MS3 suggested trying to see if the plate is the problem and using the plate from my trans mount that failed. A few of the bolts on the old mount snapped off or stripped which caused the holes on the plate to become ovals instead of circles. Surprise, surprise, this gave enough room for the bolts to go in. Only problem is that the bolts are completely rubbing against the side of the inset part of the plate.
I refuse to use the damaged mount's plate, so the only thing I can do is post up and bring the terrible quality control to CP-Es attention.
Edit: I had already read @Erich's thread and took the bushing side apart/cleaned and reassembled... it was still the same distance apart.
 Old 03-24-2013, 07:26 PM   #2
Have you made effort to contact them before posting?
kritz likes this.
alex_speed13 (03-25-2013), kritz (03-24-2013), MazdaBoy2.3 (03-25-2013)
 Old 03-24-2013, 07:29 PM   #3
grantmm's Avatar
Emailed and called, but it's the weekend and I need a new part ASAP. I didn't post my other part failure up here out of respect, but they haven't responded to any of my contact about that part after a week of waiting. If Erich hadn't had the same problem with his mount, I would have stayed quite about this. Seeing as how it appears to be NOT a unique situation, I believe this thread is justified.
 Old 03-24-2013, 09:44 PM   #4
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
CP-e has been closed for most of the week and weekend for inventory and other things give them until Monday evening before spazing please I know they will be willing to help solve this issue.
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
 Old 03-24-2013, 07:32 PM   #5
Boom's Avatar
Posts: 64   (View Stats)
Boom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond reputeBoom has a reputation beyond repute
why not show us, if they dont qc each part other customers deserve to know that their parts may not fit and cpe is unreliable
Boom is offline   Reply With Quote
 Old 03-25-2013, 10:12 AM   #6
lilred's Avatar
Posts: 5,792   (View Stats)
While I agree msf should be made aware of these sort of things I would be more happy with a post about how the issue was handled given a reasonable amount of time to respond.
"Hey I had this issue and cp-e did this about it..."
Or
"Hey I had this issue and cp-e has not even acknowledged my complaint after a week"
Either way glad OP is getting handled.
tapafuck
kritz likes this.
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
kritz (03-25-2013)
 Old 03-24-2013, 07:31 PM   #7
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Bash first and call after is not the best way to get things done. I have mentioned this before give them a chance to respond.
@Grumpyjap;
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
Dmurray06 (03-24-2013), that1rowdyracer (03-25-2013)
 Old 03-24-2013, 08:37 PM   #8
708
Erich's Avatar
Posts: 4,274   (View Stats)
I still don't understand why they don't just assemble these two pieces as part of manufacturing. It would avoid both this problem and the possibility of a customer not using threadloc and creating a potentially dangerous situation.
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
The Following 12 Users Say Thank You to Erich For This Useful Post:
Boom (03-25-2013), El_Diablo (03-25-2013), Etipp98 (03-24-2013), kritz (03-25-2013), Kyle Undefined (03-25-2013), lilred (03-25-2013), Nliiitend1 (03-25-2013), Pendarus (03-25-2013), rfinkle2 (03-25-2013), sidekick (03-25-2013), theurgy (03-24-2013), Tokay444 (03-25-2013)
 Old 03-25-2013, 09:42 AM   #9
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
@grantmm; please contact us directly and we will be MORE than happy to take care of you.
http://www.cp-e.com/contact
grantmm, rfinkle2, kritz and 2 others like this.
Website: www.cp-e.com
The Following 6 Users Say Thank You to www.cp-e.com For This Useful Post:
DaDoctor (03-28-2013), El_Diablo (03-25-2013), grantmm (03-25-2013), kritz (03-25-2013), rfinkle2 (03-25-2013), Sum1UDidntC (03-25-2013)
 Old 03-25-2013, 10:05 AM   #10
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
again.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 03-25-2013, 10:05 AM   #11
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
So is the "new thing" to just bitch on msf about our vendors?
This is getting a little out of hand...
Matt
The Following 2 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
El_Diablo (03-25-2013), Kyle Undefined (03-25-2013)
 Old 03-25-2013, 10:09 AM   #12
Tokay444's Avatar
Groans: 793
meh, i think it's justified.
this part has failed more than the oem mount ever did, has been documented like crazy and this was already a replacement for a broken part, and they still couldn't get it right.
anyone else would be being lynched to take the product off the market, with good reason.
Demodded.
The Seals
2k4_8 (03-25-2013), sidekick (03-25-2013)
 Old 03-25-2013, 10:12 AM   #13
Groans: 51
Im not arguing that this particular case isn't justified, however, these threads seem to be popping up every day now.
 Old 03-25-2013, 10:40 AM   #14
grantmm's Avatar
I completely agree with what you're saying about making a thread about every little thing that goes wrong which is why I did not make a big deal about my previous failure (expensive failure). If the problem appears to be widespread, I feel like a warning to other potential purchasers is due. I have a great deal of respect for CP-E and I want them to continue to manufacture high quality parts. They have a reputation for making some of the best Mazda aftermarket pieces, so something like this shouldn't be acceptable.
Again, I am not out to crucify CP-E. I am simply giving another example of this part's tolerances/quality control not being tight enough.
BTW, thank you for stepping up CP-E. I do appreciate it. I paid extra to get this part shipped ASAP and as fast as possible, so I hope you understand the frustration when the part couldn't be assembled. Hopefully this turns out to be a testament of great customer service.
The Following 3 Users Say Thank You to grantmm For This Useful Post:
Nliiitend1 (03-25-2013), sidekick (03-25-2013), www.cp-e.com (03-25-2013)
 Old 03-25-2013, 11:11 AM   #15
461_SS's Avatar
Posts: 1,160   (View Stats)
461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world
Almost looks as the part was not sitting properly in the CNC machine. Looks like the holes were drilled/tapped on an angle. To be off 2-3mm is definitely human error or a problem in the cnc code.
Being that QC does not check every part, this one might have just happened to slip by. It happens. You check one out of every 5/10 (where I work). Always a chance of something slipping by. That's the risk the company takes. Although I would have personally contacted them by PM first.
461_SS is offline   Reply With Quote
The Following User Says Thank You to 461_SS For This Useful Post:
kritz (03-25-2013)
 Old 03-25-2013, 11:31 AM   #16
708
Erich's Avatar
Mine had the exact same problem, so there is more than a single part that slipped through.
 Old 03-25-2013, 12:54 PM   #17
Slash's Avatar
Posts: 110   (View Stats)
Slash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the world
I don't see the swarm of qc posts as a bad thing at all, it can either make or break a reputation. If they jump on it and right their wrong then this is a positive post not a negative.
Sent from my SGH-T999 using Tapatalk 2
AT Internals/Cobb AP/NGK LTR7IX/CS SRI/CS TIP/CS TP/CX Racing FMIC/Cobb XLE 50-50/JBR Rmm and Weight/Hankook Ventus v12/18x8.5 Rota Grids
13.39 at 103.35 in the 1320. Allegedly ~290WHP/~370WTQ
Tuned by The FREEK
Slash is offline   Reply With Quote
 Old 03-25-2013, 04:00 PM   #18
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
I agree. These vendor forums are here for a reason. That reason is to reach out to the company. CP-E should have no problem with posts like this. No one is perfect, but as long as they take care of the problem, everyone will see.
You guys wanted transparency from SURE and this is EXACTLY that. Also, everyone says "OMG CALL", but the OP clearly stated he already called and emailed. Emailing should suffice as a form of communication anyways. If you don't want to reply to emails, then don't set up an email account.
I had a similar problem with CP-E's QC on a downpipe recently, so it is not an isolated issue. However, CP-E handled the issue well, so that is what really counts, IMO.
It also took me 4 separate phone calls to CP-E get a hold of someone to ask one question. Most of us have jobs and cannot take the time out of our work day to call a company 4 times for the answer to a simple question. It does not help that they are in a completely different timezone, either. This is why we use e-mail and expect an actual response from said company.
EDIT: Also, a failed motor mount is not exactly a small issue... People's lives could be put at risk by these failing.
Kfunk and kritz like this.
The Following 4 Users Say Thank You to sidekick For This Useful Post:
Kfunk (03-28-2013), kritz (03-25-2013), lilred (03-25-2013), spals (03-25-2013)
 Old 03-25-2013, 10:06 PM   #19
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
Should have gone with eBay :p
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
lilred (03-25-2013)
 Old 03-25-2013, 11:52 PM   #20
sidekick's Avatar
Groans: 47
Lmao I was waiting for someone to that
Kyle Undefined (03-26-2013)
 Old 03-25-2013, 09:13 PM   #21
We have posted a safety recall on some mounts that have recently been purchased. More information can be found here. This should only effect about 10 people that have RECENTLY purchased the mount.
cp-e™ Driver Side Engine Mount Safety Recall
sorry for the inconvenience
The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post:
08.5MS3 (03-25-2013), El_Diablo (03-27-2013), SarcasticOne (03-26-2013)
 Old 03-25-2013, 09:36 PM   #22
grantmm's Avatar
Wow, thank you for noticing that there were further mounts with issues and being able to identify roughly how many were sold with the misalignment problem.
JP @ Edge Autosport has been in contact with me today about getting everything sorted.
 Old 03-25-2013, 09:41 PM   #23
Stingray69's Avatar
Posts: 1,197   (View Stats)
Stingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the world
Groans: 48
Groaned at 49 Times in 30 Posts
Having been in manufacturing for 25 years I have learned everyone makes rejects. Good companies admit when they have and stand behind their product. Sounds like cp-e is stepping up and doing just that.
AP, Corksport SRI/TIP, MD OCC, Autotech internals, CPE stage 2 RMM
Stingray69 is offline   Reply With Quote
The Following 3 Users Say Thank You to Stingray69 For This Useful Post:
El_Diablo (03-27-2013), sidekick (03-25-2013), www.cp-e.com (03-27-2013)
Drivers side mount NoTraction MazdaSpeed 3 - Engine, Transmission & Driveline 13 09-04-2012 01:59 PM
drivers side mount JBR? EvilMonkey 2010 MS3 - Engine, Transmission & Driveline 6 06-14-2011 09:14 AM
Cp-e Side Mount and Transmission Mounts in the Works VTAOE MazdaSpeed 3 - Engine, Transmission & Driveline 5 02-24-2009 01:04 PM
$99 for the drivers side engine mount!!!! ptperformance Mazdaspeed3/6 General Discussion 77 01-04-2009 07:16 AM
Page generated in 0.44958 seconds with 34 queries
