Closed Thread
 Old 02-23-2010, 10:38 PM   #1
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
Default E-Tune with CP-E
Hello all -
I just wanted to take a moment and share some details of how my E-Tune is going with CP-E (Jake). As I am from the West Coast, California, and CP-E is almost 2000 miles away I cannot get a custom dyno tune from them. I have a built block, gt3076r, CP-E XcelXL Big Maf Intake, all CP-E flashes and looking forward to 400whp!!
Running the car untuned felt somewhat weak and sluggish. Once Jake started making adjustments to my tune the car started to feel better and carried the power to redline. At the first couple adjustments, Jake had the car at 12psi and to be honest I felt the car more powerful than before having my car fully-bolted at 20psi with the stock k04 turbo!
After several adjustments and now at around 17.5 psi at 3500rps going WOT in 3rd gear I get alot of torque steer!
Everyone running the Standback should consider getting an E-Tune or even getting dyno tuned at CP-E, Jake has been great to work with and I appreciate all the time he has put in my tuning.
Thanks CP-E!!
11cruzito11 is offline
The Following 5 Users Say Thank You to 11cruzito11 For This Useful Post:
bioevolve (02-24-2010), gsrtype1 (02-28-2010), madvillain (02-27-2010), MPSdriver (05-06-2010), tozfeekum (02-23-2010)
 Old 02-23-2010, 10:49 PM   #2
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
dyno dyno dyno it.
felt is offline
The Following User Says Thank You to felt For This Useful Post:
SpeedNess (02-23-2010)
The Following 2 Users Say NO Thank You to felt For This Un-useful Post:
 Old 02-23-2010, 10:52 PM   #3
SpeedNess's Avatar
Posts: 207   (View Stats)
SpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the world
^+1, i want to start seeing more 400whp ms3 and 6's, hopefully 2010 will be the Speed's YEAR!!!!
SpeedNess is offline
 Old 02-23-2010, 11:00 PM   #4
Originally Posted by felt View Post
dyno dyno dyno it.
I will once the E-Tune is done and tuned at 22psi!
The Following 2 Users Say Thank You to 11cruzito11 For This Useful Post:
802MS3 (02-24-2010), xcoldricex (05-05-2010)
 Old 02-24-2010, 02:37 PM   #5
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
What turbine housing do you have? Other mods? Good luck with your tuning and is it absolutely awesome to drive?
spnkr21 is offline
 Old 02-24-2010, 02:55 PM   #6
22psi? r u kidding? how bout 26? you have a built block what r u afraid of!!!
superskaterxes is offline
The Following 3 Users Say Thank You to superskaterxes For This Useful Post:
11cruzito11 (02-24-2010), djuosnteisn (02-24-2010), phillyb (05-05-2010)
 Old 02-24-2010, 03:01 PM   #7
stock housing not the T3 one : ( mods are fully-bolted.
Its fun to drive, I can't go WOT in 1st nor 2nd it just spins the tires like crazy.
 Old 02-24-2010, 03:02 PM   #8
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Post some pics and vids. We need media
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 02-24-2010, 03:33 PM   #9
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
what tires are you rocking and what size?
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
 Old 02-24-2010, 08:03 PM   #10
the tires are the stock ones.
 Old 02-24-2010, 08:55 PM   #11
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
if your using the ATP stock housing turbo you cant boost more than 21psi??
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline
 Old 02-24-2010, 09:02 PM   #12
I'm pretty sure you can, "Yoichi" i belive runs like 22 - 23psi on his gt2871r. I am running over 20psi on my gt3076r without any flow issues.
 Old 02-27-2010, 08:31 PM   #13
yoichi's Avatar
Posts: 557   (View Stats)
yoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the world
22lbs dry
24lbs meth
2003 E39 ///M5
yoichi is offline
 Old 02-27-2010, 08:42 PM   #14
bf360's Avatar
Posts: 2,069   (View Stats)
1. Get some videos and dynos.
2. dont be afraid run at least 24psi
3. Race some people on video
Originally Posted by DCLXVI View Post
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
bf360 is offline
 Old 02-27-2010, 09:19 PM   #15
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
Yea carlos, i was going 30 psi and 110 octane after 2000 miles. and that was without the new power flash. dont be skurred.
MarkyMark is offline
The Following 2 Users Say Thank You to MarkyMark For This Useful Post:
djuosnteisn (02-28-2010), NJSPEED3 (03-30-2010)
 Old 02-27-2010, 09:24 PM   #16
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
I can't wait to see what you can come up with on this car man.
madvillain is offline
 Old 02-27-2010, 11:17 PM   #17
I am running 20psi right now and 3rd - 5th gear pulls feel awesome, i imagine how 24 - 26psi would feel
 Old 02-28-2010, 07:47 AM   #18
slo4now's Avatar
Posts: 382   (View Stats)
slo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond repute
Groaned at 24 Times in 6 Posts
Do yourself a favor and dont go to the track on stock tires, get yourself some drag radials.
cant wait to see some #'s.
slo4now is offline
 Old 02-28-2010, 07:51 AM   #19
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Badass!!! cant wait to see dyno! ))
gsrtype1 is offline
 Old 03-15-2010, 04:56 PM   #20
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
Groaned at 16 Times in 14 Posts
updates???
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline
 Old 03-15-2010, 05:17 PM   #21
Dookie's Avatar
Posts: 91   (View Stats)
Dookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud ofDookie has much to be proud of
Carlos - glad to see the Standback tune is going well. 400 hp is in your future. Making me want to take the next step and go big turbo. Looks like i'm going to just end up e-tuning with cobb and maybe pick up a PTP SST though, the wife is cool with all the car stuff and I promised her I wouldn't take it too far with this car.
Now every time I try to schedule some time for a dynotune up in Plano I end up having work related travel get in the way.
Again, thanks for the great deal on your AP and meth kit!
New Car: Evo X/MR, COBB AP Stg-II, COBB TBE, HKS PF, COBB Springs
Old Car: '06 MS6, AP, GT3076R, CS FMIC, CP-E CDFP, Etc....
Dookie is offline
 Old 05-05-2010, 07:51 AM   #22
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
im so wet.
vbt101 is offline
The Following User Says Thank You to vbt101 For This Useful Post:
 Old 05-05-2010, 03:45 PM   #23
prenedo's Avatar
Posts: 423   (View Stats)
prenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the world
Originally Posted by vbt101 View Post
im so wet.
Cruzito, can you please satisfy this man with a dyno. He's gonna go to BUNGGEEEEZZZZ to satisfy him if not..
prenedo is offline
 Old 05-05-2010, 05:41 PM   #24
haha, give me one more week to head over to the dyno. i'm ordered my Meth kit and should install it early next week, then i will Dyno for sure.
The Following User Says Thank You to 11cruzito11 For This Useful Post:
Closed Thread
MS3 tune Asse MazdaSpeed 3 - Engine, Transmission & Driveline 2 05-04-2009 08:45 AM
Tune for 91 or 93? GongShow MazdaSpeed 3/6 - ECU Computer Tuning 2 02-12-2009 09:22 AM
help me tune please etant333 MazdaSpeed 3/6 - ECU Computer Tuning 7 01-05-2009 05:12 PM
Page generated in 0.42619 seconds with 37 queries
