Closed Thread
 Old 02-27-2010, 06:07 PM   #1
FearUndersteer's Avatar
Posts: 189   (View Stats)
FearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the world
Default Full Control Flash - Review
First, I want to thank everyone at the shop for coordinating this so quickly. I placed my order Friday afternoon and was able to stop by the shop that evening to get this done.
The entire mid range and top end now seem much stronger. Leaving the shop I was able to get wheelspin in the upper RPMs of 2nd going in a straight line(dry pavement). The turbo is no longer falling on it's face (as bad) past 5500 rpm. The throttle seems much more predictable in all situations making it much more effortless to shift smoothly.
Lou is still the man but I have one more idea for a flash. Many people are using the SB in combination with the DH. It is frustrating not to be able to read boost with the DH. If you could achieve this it would be a truly complete package.
One question: what's with the alarms going off constantly in the shop?
-Matt
2009 MazdaSpeed3 | True Red
35% Tint
CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC
FearUndersteer is offline
The Following 2 Users Say Thank You to FearUndersteer For This Useful Post:
NJSPEED3 (02-27-2010), tozfeekum (02-27-2010)
 Old 02-27-2010, 07:49 PM   #2
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Where are the BT guys at Cpe? we would like to hear about those guys doing big numbers like socks did!
NJSPEED3 is offline
nighthawk358 (02-27-2010)
 Old 02-27-2010, 07:53 PM   #3
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Silver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the world
Groaned at 81 Times in 33 Posts
So you cant use the Dashhawk after getting flashed?
Mike
2008.5 CWP Mazda CX-7 Sport FWD - hers
2008.5 CWP Mazdaspeed 3 GT - traded
2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold
Silver Ecstasy is offline
 Old 02-27-2010, 08:09 PM   #4
The SB caps the MAP sensor to prevent cuts so you can't see actual boost past 10psi or so on the DH when using a SB because the car has no idea what it is in the first place.
Lex is offline
 Old 02-27-2010, 08:16 PM   #5
PaPaSpeed's Avatar
Posts: 602   (View Stats)
PaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the world
I use mine after the flash.
CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic.
PaPaSpeed is offline
 Old 02-27-2010, 08:18 PM   #6
speed23's Avatar
Posts: 1,480   (View Stats)
You should be able to use the dashhawk post flash, but not if you are using the standback also.
speed23 is offline
 Old 02-27-2010, 08:57 PM   #7
Ahh..gotcha.
Weird, I had no idea that it did that.
I've heard that full throttle flash isn't worth anything as opposed to an actual tune (via SB or AP). True or false?
Mike
 Old 02-27-2010, 09:07 PM   #8
The SB has not control over throttle. So the FT flash gives you full throttle.
Lex is offline
 Old 02-27-2010, 09:08 PM   #9
And I thought according to COBB, there was no real gain of power at 50% WOT vs 100% WOT?
Mike
 Old 02-28-2010, 10:10 AM   #10
You can use the Dashhawk still but as Lex mentioned because of the MAP clamp the factory ecu has no idea what the real boost is(only the SB does).
As far as I am concerned the car feels much stronger from the midrange to redline with all else equal. Certainty not as much bang for your buck as a downpipe or FMIC upgrade but I am enjoying it.
35% Tint
 Old 02-28-2010, 10:17 AM   #11
PaPaSpeed's Avatar
The thing that I like about the flash is that the driver controls the throttle, not the ECU. When you floor the pedal you get WOT (87%), not what the ECU determines it wants to give you.
I'm enjoying it.
 Old 02-28-2010, 12:44 PM   #12
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
fuck..why cant we open the throttle 100%?
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline
 Old 02-28-2010, 04:17 PM   #13
barcainho's Avatar
Posts: 97   (View Stats)
barcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant futurebarcainho has a brilliant future
i had it before i got my ap and the car did feel alot stronger after the flash
Current Mods: MS CAI, CPE DP, Corksport CBE, HKS SSQ BPV, SU MM, SU Bushings, Dashawk, CPE Full Control Flash, CPE Nviscid Turbo Inlet, Cobb AP
Future Mods:BC coils, CPE FMIC, HPFP
266whp & 282tq
going for 300whp summer of 09
barcainho is offline
 Old 02-28-2010, 04:26 PM   #14
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
87% is full throttle its just how its perceived by the dash hawk.
you can get a dash hawk to show the boost you want with the standback. It just depends where you set the map clamp.
www.cp-e.com is offline
 Old 02-28-2010, 06:10 PM   #15
BoOdOg's Avatar
Posts: 96   (View Stats)
BoOdOg is a splendid one to beholdBoOdOg is a splendid one to beholdBoOdOg is a splendid one to beholdBoOdOg is a splendid one to beholdBoOdOg is a splendid one to beholdBoOdOg is a splendid one to beholdBoOdOg is a splendid one to behold
full control flash was one of my favorite mods, my only thing is I wish I had of got it done sooner
BoOdOg is offline
 Old 02-28-2010, 06:12 PM   #16
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
their boost cut flash is my favorite I don't know how any modded mazda drives with out ti during the winter.
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 02-28-2010, 07:05 PM   #17
Great but will the stock ECU give me trouble if I allow it to see I am targeting 17 psi?
35% Tint
 Old 03-05-2010, 12:25 PM   #18
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
damn man, what temps are we talking about?
i've driven in mid to upper 20's with the mods in my sig (stock fuel pump) and dont have any fuel or boost cut at WOT. unless people are in even colder weather with more mods.
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline
Closed Thread
Cp-e Full Control and Fuel Cut Flash Review BoOdOg Custom Performance Engineering (cp-e.com) 5 03-24-2010 07:47 PM
Question about full control flash Ipwnheaton MazdaSpeed 3/6 - ECU Computer Tuning 9 12-28-2009 05:04 PM
Cp-e Full Control Flash w/o standback & tune? steven88 MazdaSpeed 3/6 - ECU Computer Tuning 57 07-09-2009 11:53 PM
those with CP-E Full Control flash... builthatch MazdaSpeed 3/6 - ECU Computer Tuning 11 11-13-2008 02:26 PM
About the Full Control Flash 7mileshome MazdaSpeed 3/6 - ECU Computer Tuning 13 11-05-2008 11:14 AM
Page generated in 0.36596 seconds with 31 queries
