Closed Thread
 Old 02-07-2009, 11:00 AM   #1
Moonpie.Express's Avatar
Posts: 68   (View Stats)
Moonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the worldMoonpie.Express is the leader of the world
Default Heads up on CP-e TowPlate
Just to let the CP-e guy's know, the shaft for mounting the plate is over powdercoated.
I received mine and was very impressed with the bulletproof construction.
I attempted install Sat. and ran into an issue. The shaft did not want to go thru the sheetmetal towards the towhook connection. I stuck the towhook in car and threaded it, no problem. Attempted the mounting shaft once more and it did not want to go in, so I forced it thru the sheetmetal and pulled it out again. I put it back in and attempted to thread, no joy, it just would not start.
I took a step back for a moment and looked at the shaft. The PC was scraped away from the rotation of trying to thread it. I realized then that the threads on the shaft were also PC'd. I took a small triangular file and commenced removing powdercoating. I did not have a die of that size to clean the threads.
I did about half the shaft to see if I could get it started. Bingo, started threading like a champ.
Problem came up when I started getting some resistance. I immediately reversed rotation and towhook loosened up. Also, not enough shaft to put some visegrips on.
Soooo, I went back to screwing the shaft in as best I could. It is in, but there is about a 3/4" gap between bumper and plate.
I will be able to get it out when I pull the bumper off.
After reviewing Haltech's install photo's, I spotted the shaft delivered to him and there it was, no PC on the shaft threads.
This is just a heads up to CP-e folk's and anyone that intends on getting one of these TowPlate's. There is a run out there that has powdercoated threads.
Oh, I would highly recommend buying one of these. Very well constructed.
Moonpie.Express is offline
 Old 02-07-2009, 11:22 AM   #2
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
Powder coated the threads.
That's brilliant.
In reality I love lenny
kingpin748 is offline
The Following User Says Thank You to kingpin748 For This Useful Post:
phillyb (03-12-2009)
 Old 02-07-2009, 11:31 AM   #3
atomicms3's Avatar
Posts: 459   (View Stats)
atomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the world
Have you contacted CP-e about this?
2007 MS3 GT - 25k+ miles a year... what's a warranty?
atomicms3 is offline
 Old 02-07-2009, 11:37 AM   #4
My day's are mixed up, thought it was Sunday. Will try here in a minute as soon as I get the number.
 Old 02-07-2009, 01:22 PM   #5
xandrake's Avatar
Posts: 575   (View Stats)
xandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the world
Hmm. this sounds exactly like what happened to me. After looking a bit closer I noticed that some of the threading was a bit off as well. Randy and the guys @ CPe were amazing hand got everything taken care ASAP though. EXCELLENT customer service.
xandrake is offline
 Old 02-07-2009, 09:26 PM   #6
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
nice thanks for the heads up. I am waiting for my towplate patiently..apparently they are on backorder right now.
bykeryder4life is offline
 Old 02-08-2009, 05:46 AM   #7
I think you will be happy with it. Damn thing looks as though it was made from a body armor breast plate!
The Following User Says Thank You to Moonpie.Express For This Useful Post:
bykeryder4life (02-08-2009)
 Old 02-08-2009, 01:47 PM   #8
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
xandrake: threading was off? please explain...
pc on the threads is a fuck up. excess pc on main body is a fuckup. i'll see what can be done about that.
killa cam is offline
The Following User Says Thank You to killa cam For This Useful Post:
Moonpie.Express (02-08-2009)
 Old 02-08-2009, 11:02 PM   #9
Groans: 38
do you work for cpe? sorry for the noob question
 Old 02-08-2009, 11:15 PM   #10
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
^^^ yup; sure does.
y2kc0wb0y is offline
The Following User Says Thank You to y2kc0wb0y For This Useful Post:
bykeryder4life (02-09-2009)
 Old 02-15-2009, 01:44 PM   #11
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
I need a towplate.
Beanfab / Tuned by Nishan
doubleflusher is offline
 Old 03-11-2009, 11:41 PM   #12
blackcherryspd6's Avatar
Posts: 35   (View Stats)
blackcherryspd6 is a jewel in the roughblackcherryspd6 is a jewel in the roughblackcherryspd6 is a jewel in the roughblackcherryspd6 is a jewel in the rough
BUMP for one for a MS6
blackcherryspd6 is offline
 Old 03-12-2009, 12:16 AM   #13
Driverman5777's Avatar
Posts: 685   (View Stats)
Driverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the world
Groans: 76
they should be out by the end of march if I remember them correctly
Driverman5777 is offline
 Old 03-12-2009, 09:25 AM   #14
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
If you had looked...
http://www.mazdaspeedforum.org/forum/foru...tml#post166885
L76-powered
mdogg is offline
Closed Thread
CP-e TowPlate Haltech Review Discussion 46 04-15-2009 04:12 AM
Off with their heads! (But whose?) Haltech Automotive News 0 11-23-2008 10:10 PM
CP-e TowPlate Mazdaspeed 3 Review Haltech Mazdaspeed Forums Performance Parts Reviews 0 11-23-2008 08:08 PM
Off with their heads! (But whose?) Haltech Automotive News 0 11-18-2008 01:40 PM
Page generated in 0.33648 seconds with 30 queries
