| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
(Thread Starter) | Not Ranked : 0 score Where is it?
| The Following 7 Users Say Thank You to 06Speed6 For This Useful Post: | 802MS3 (06-18-2010), Blackspeed (06-18-2010), madvillain (06-19-2010), phillyb (06-18-2010), SilverDemon (06-18-2010), triplejumper18 (06-18-2010), xcoldricex (06-23-2010) |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score also wouldn't mind seeing pics of the ex mani they had at occ. |
| The Following User Says Thank You to phillyb For This Useful Post: | Alpha (06-18-2010) |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score Definitely.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score I had both prototypes in my hands at the dyno day they put on back in march.....Deff nice stuff...
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score they looked purrdy at occ |
| Not Ranked : 0 score Damn, so they ARE coming out with an intake manifold?
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
| Not Ranked : 0 score I would guess that the gen 2s IM is the same. Is that correct?
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
Groans: 326
| Not Ranked : 0 score wait for it fuck genpu yes i believe they are the same |
| The Following 3 Users Say Thank You to 8.5MS3 For This Useful Post: |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score Shouldn't they finish the side mounts first?
__________________ 2009 MS3 sport MGM |
| Not Ranked : 0 score Forget the side mounts! Haha! EVERYONE wants an aftermarket IM!
| Not Ranked : 0 score It would be smart to corner 100% of the market.
| Not Ranked : 0 score I need to do some more research to see if the SB has enough flexibility on the gen 2 to support all of these parts. I will build a motor again one day, I can't stand just doing bolt-on shit. It's been too long since I really got my hands dirty. Apparently though, all that I need to be duped is a glove box light. Still reeling over that mistake. |
![]() Join Date: Jun 2008 Location: Atlanta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score ^^^ ??? ^^^
__________________ I BUSTED SOCKS CHERRY AND IT WAS GOOOOD![]() I'VE BEEN PLAYING DUMB FOR SO LONG ITS NOT A GAME ANYMORE IF IT WAS WORTH THE TIME IT TOOK YOU TO GET EVEN THAN WHY DIDNT YOU TAKE A LITTLE MORE AND GET AHEAD? |
| Not Ranked : 0 score I've worked on cars all of my life, but I was obviously wearing my fail hat yesterday... Link: http://www.mazdaspeedforum.org/forum/foru...working-59339/
| Not Ranked : 0 score They want to wait until they use up all those glossy, postcard advertisements with the IM drawing. Do you know how much it costs to print those things?
| The Following User Says Thank You to wankular For This Useful Post: | madvillain (06-19-2010) |
Groans: 78
| Not Ranked : 0 score Yes pwease |
![]() Join Date: Jul 2008 Location: Canton, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,233
| Not Ranked : 0 score can haz picturz?
__________________ cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC |
Groans: 78
| Not Ranked : 0 score We have any info yet?
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score PICTURE |
Groans: 326
| Not Ranked : 0 score for the guys that never saw it, old pic from a couple months ago of the 3D rapid prototype |
| The Following 4 Users Say Thank You to 8.5MS3 For This Useful Post: |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score A couple months? Wasn't that taken like almost a year ago? You think they could move a little faster with this. What good is a rapid prototype if it takes years (exaggerated) to get it into production. Rapid implies some sense of urgency and speed. |
Groans: 105
| Not Ranked : 0 score yes, to make the prototype, not the actual product. hopefully that will accommodate larger tb's |
![]() | | #24 | ![]() |
| Not Ranked : 0 score +1. Does anyone even make an option for a larger TB for the MS3, or do you just have to port the OEM one?
![]() | | #25 | ![]() |
Groans: 105
| Not Ranked : 0 score port or maxbore. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Porting is our only option as of now, but there are far better options than Maxbore just FYI.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 07-02-2010 at 09:03 AM. |
![]() | | #27 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score like?
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following User Says Thank You to socks For This Useful Post: | xcoldricex (07-05-2010) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Muah ah ahhh!!! Every car I've owned or touched has had Mark Shaner's portwork done to the TB. (02 SS, 03 Z06, 2010 Maxima, 06 MS6, 02 Formula WS6...) He's hands down the best I've ever seen or used. Porting is an art, like headwork, and Mark has it DOWN for whatever you need.
I think it's more of an "Every little bit adds up" type mods. Like reducing rotating weight, underdrive pullies, etc.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 07-06-2010 at 09:14 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #29 | ![]() |
Groans: 105
![]() | | #30 | ![]() |
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 07-08-2010 at 08:26 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Alpha For This Useful Post: | 06Speed6 (07-08-2010) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Does anyone know how much of flow improvement Maxbore porting offers compared to stock? That's the last OT question I'll ask. Or I can just search it if you guys know of one on here. |
![]() | | #32 | ![]() |
Groans: 105
| Not Ranked : 0 score search - it's 63mm vs. 60mm. significant improvement. |
| The Following User Says Thank You to xcoldricex For This Useful Post: | Nataphen (07-01-2010) |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score adding .118" to a 2.362" tb to make it 2.48" is really a joke, we really need a 80mm+ tb. You cant even do flow numbers on that full 2.48" because you have to subtract the blade and shaft from the area and add in additional turbulance. About a year ago I calculated that the stock tb without the blade and shaft could flow 427hp @ 25psi before it was saturated. 0.278716sq" is the approximate area of the blade and shaft. 4.381770911113554sq" is the area of the TB bore. 4.1030549111sq" is the net available area that we can flow air. The blade and shaft equal ~6% of the total available area, so if we take 427hp * .94 = 401.38hp before saturation at 25psi. For the Maxbore tb, which is 63mm or 2.48" 0.292888sq" is the approximate area of the blade and shaft. 4.830512864159666sq" is the area of the TB bore. 4.537624864159666sq" is the net available area that we can flow air. The blade and shaft still equal ~6% of the total available area. The net increase in blade and shaft area is ~5% The net increase in bore size is about 10.2% The net increase in air flow area is ~9.8% 401.38hp for the stock TB 440.71hp for the Maxbore TB So why did I say it was laughable? Because I calculated that based on compounding uncertainty. In a perfect world it would actually flow that much more, but in this world it doesnt flow more than probably 20hp more air.
| The Following 4 Users Say Thank You to 06Speed6 For This Useful Post: |
![]() | | #34 | ![]() |
| Not Ranked : 0 score 20hp gain for a throttle body is pretty respectable for any car. I really wouldn't expect it to gain THAT much, more like 10-15hp, which is still worth it IMO. When you're talking about an engine with 300-400hp, 20 extra hp is a noticeable difference. When you start getting to the point that traction is a bigger issue than the power that you're putting down, 20hp isn't a big deal. I obviously wouldn't do this before all the typical bolt-ons, but if I was going to change intake manifolds, I'd probably go ahead and do the TB too. |
![]() | | #35 | ![]() |
Either way, I had mine done and matched to my MAP manifold. Should be nice!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 07-06-2010 at 10:34 AM. | |
| The Following User Says Thank You to Alpha For This Useful Post: | Nataphen (07-06-2010) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Ah, I see. So, if you're at 400hp, then you may see the gains because the TB could be totally maxed out, got it. Oops |
![]() | | #37 | ![]() |
Groans: 78
| Not Ranked : 0 score I can has a cp-e IM with an 80mm TB option?
| The Following User Says Thank You to madvillain For This Useful Post: | 06Speed6 (07-08-2010) |
![]() | | #38 | ![]() |
Groans: 105
| Not Ranked : 0 score probably... in 2012 |
| The Following User Says Thank You to xcoldricex For This Useful Post: | 06Speed6 (07-08-2010) |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score Considering they dont even read threads in their own forum, maybe never. I got my hands on a copy of solid works 2010 and I have been playing around with it, worst case ill have a IM designed before 2012 lol.
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have tought myself to use alot of software, but never anything as complicated as solid works, it should be fun =)
| Intake manifold?? | steedspeed | MazdaSpeed 3/6 - Turbo Induction | 40 | 03-18-2010 03:01 AM |
| Intake manifold | QuickSpool | 2010 MS3 - Engine, Transmission & Driveline | 0 | 11-18-2009 06:19 PM |
| **WTB** MS6 intake manifold | Deadman | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 12-27-2008 06:24 PM |
