Like Tree9Likes
 Old 02-20-2012, 11:14 AM   #121
paveltol's Avatar
Posts: 520   (View Stats)
Ah, I will attach the pictures.
What about the intake manifold?
paveltol is offline   Reply With Quote
The Following 2 Users Say Thank You to paveltol For This Useful Post:
Celestspeed3 (02-23-2012), drummermike58 (02-21-2012)
 Old 02-20-2012, 11:57 AM   #122
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
This!
Sent from my DROID2 GLOBAL using Tapatalk
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following User Says Thank You to TRSpeed For This Useful Post:
 Old 02-20-2012, 12:25 PM   #123
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
Could you give me a little more info on how his car runs? I really like the ewg+ cpe mani setup.
I too still have the stock tmic but am lucky to have e85 nearby, I guess what im trying to say is would it be worth it to get this before a fmic because I'd really like to get this first. Thanks.
Originally Posted by drummermike58 View Post
This is my buddy jonathan. @jbirriel69 he never comes on here.
Anyhow that car spools in like .001 seconds. Its stupid how fast it occurs. We were neck and neck last night with me at 22psi at 8* advance. And no KR btw....
Sent from my SGH-T959 using Tapatalk
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
 Old 02-20-2012, 03:22 PM   #124
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Looks like another top notch CP-E product.
I love seeing quality American made products like these...of course, since I work in manufacturing, I might be biased.
 Old 02-20-2012, 04:22 PM   #125
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
ewg k04 could certainly hold boost... just load up a very stiff spring. @bewsted is gonna be trying something very similar soon.
Whether or not it actually makes more power however..... TBD lol.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Last edited by djuosnteisn; 02-20-2012 at 04:22 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-20-2012, 04:24 PM   #126
Eth/Meth Junkie
cld12pk2go's Avatar
My K04 pegged out at 28 PSI (at 2300 RPM!!!) when I lost the bottom nipple on my WGA.
djuosnteisn (02-20-2012)
 Old 02-20-2012, 04:25 PM   #127
Captain
The exh mani pressure was opening the IWG at that point. But if you had put a stiffer spring in there, you could have forced it to hold much more i bet.
www.permtuning.com
 Old 02-20-2012, 06:09 PM   #128
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
If you were running ewg wouldn't it be wise to just tack the iwg shut?
"Exclusivity" - CP-enis
Demodded.
The Seals
djuosnteisn (02-21-2012)
 Old 02-21-2012, 12:04 AM   #129
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
My ko4 pegged my 3bar map around 3500rpm when I was dicking with some different wgdc values (which I screwed up) and it was showing no signs of slowing down. I had the ptp 18lb wga, gs ebc in interrupt, ets tmic, and a 3" turbo back at the time.
No knock either
2006 Mazdaspeed 6
 Old 02-21-2012, 10:20 AM   #130
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
I plan to be running a PG v3 38mm EWG. Looking to push 23-24 psi and hold it. DURR i forgot i will be running a MBC...so fuck WGDC and let that bitch run. Oh and i do plan to weld the flapper shut!
I will go back to my stock gutted downpipe and testpipe and run stock turboback straight pipe with a muffler single exit (All in the sake of having a little bit of back pressure.)
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
The Following User Says Thank You to bewsted For This Useful Post:
 Old 02-21-2012, 10:29 AM   #131
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
I'm sure you know this but the turbo is enough back pressure so no need for extra back pressure.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
The Following 2 Users Say Thank You to Boosted Beluga For This Useful Post:
bewsted (02-21-2012), djuosnteisn (02-21-2012)
 Old 02-21-2012, 10:34 AM   #132
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
FWIW here is a log of said 26 (now 30 initial) psi k04 EWG...
He is sorting out afrs next revision as you see they go well into the 13s... but no knock, car pulls hard as shit... no e85, no meth, stock topmount, UR turboback exhaust, inj seals, mbc, cpe mani, tial 44mm ewg, 3bar map sensor, hpfp, step colder plugs... VD says 319/451 4th gear log.
meh 60-100 is still .5 slower than me at 20 psi stock turbo and less mods. 30 psi is pointless. needs corn not boost.
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 02-21-2012, 12:00 PM   #133
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
just got off the phone with cp-e, they will NOT be selling this mani t3'd only flangeless if you wanted to go that route. the explanation they gave me was very reasonable.
 Old 02-21-2012, 03:58 PM   #134
drummermike58's Avatar
Posts: 376   (View Stats)
drummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the world
yea, e85 station is 40 miles away through 3 major cities across northern VA and Washington DC... Fuck that.
Now, good job on .5 faster 0-100 on e85, do it on 93...
runs good, see log...
[SIGPIC][/SIGPIC]--2010 BM MS3--
Treadstone tr8 fmic core with 2.5" piping ## self made 3.5" MAF ## Gtx3076 .82 a/r t-3/vband hotside ## RaceRoots EWG exh mani/3" vband ## RaceRoots tubular DP ## TIAL MVR EWG ## UR Catback ## Sure shortshifter plate ## Sure R3 rmm ## Eagle Rods ## Custom SP63 10.5:1 .020 over pistons ## balanced rotating assy ## ARP head and main studs ## Autotech internals ## Accessport ## 3bar map sensor ## vtcs delete ## EGR delete ## Balance shaft delete ## Hallman MBC ## HKS SSQV 4 BOV ## NGK iridium spark plugs ## Cusco OCC ## Aquamist HFS-4 Methanol injection with 2 gallon Howerton Engineering tank ## D2 coilovers ## Nextmod lip kit ## SPC rear camber arms ## Wedsport SA-15r 18x9.5 et +23 ## 225/45/18 NITTO Motivo tires ## chinese HIDs ## JB shift knob ## 35% tinted ## still RichTuning...
Last edited by drummermike58; 02-21-2012 at 03:58 PM. Reason: MSF Database - Automerged Doublepost
drummermike58 is offline   Reply With Quote
 Old 02-21-2012, 07:53 PM   #135
bewsted's Avatar
Ya I did.... It may have came slightly wrong lol...
EWG K04...GETSUM!
 Old 02-21-2012, 10:01 PM   #136
Groans: 50
Lol I thought so. I just didn't want other ppl to get confused you know?
08 Mazdaspeed 3
 Old 02-22-2012, 10:27 AM   #137
bewsted's Avatar
Just stay tuned for big numbers.
EWG K04...GETSUM!
Boosted Beluga (02-22-2012)
 Old 02-22-2012, 10:42 AM   #138
Captain
Like on her stomach instead of on her boobs?
www.permtuning.com
Adam is so pro (02-22-2012), Boosted Beluga (02-22-2012), doubleflusher (02-22-2012)
 Old 02-22-2012, 10:49 AM   #139
bewsted's Avatar
Id totally do it wherever she wants.
EWG K04...GETSUM!
 Old 03-06-2012, 07:35 PM   #140
TRSpeed's Avatar
why would you guys make a manifold that DOESNT fit your OWN DOWNPIPE?
Very stupid seriously.
Lex Tuned
manelscout4life (03-06-2012)
 Old 03-06-2012, 07:42 PM   #141
bewsted's Avatar
In before you have to buy our new redesigned dp
EWG K04...GETSUM!
Monotonous ONE (05-13-2012)
 Old 03-06-2012, 08:23 PM   #142
TRSpeed's Avatar
Hahaha seriously
Sent from my DROID4 using Tapatalk
Lex Tuned
 Old 03-07-2012, 08:53 AM   #143
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
To be honest this manifold design is completely wasted with the stock flange.
If you bought it with the stock flange I'm sorry but you wasted your money. You should have gone with Racebuilt.
Think about it, you'll get equal length runner which isn't going to give you any noticeable advantage on the K04 or the ATP turbos compared to another setup.
Since most are likely to be cheap and not run the EWG, why even consider this manifold.
They have a V-band downpipe which hasn't been released yet that is sized to work properly with this manifold for Tial and precision turbines. That's the main advantage here, to rid yourself of the stock flange, and the ATP turbine. I'm having a downpipe custom made for my setup. I want the option to swap between a screamer pipe and plumb back wastegate setups.
The downpipe was released a long time before this manifold was even considered if it doesn't fit who cares. I'm not going to reuse my CPE downpipe with this manifold. Even so if you got the second 02 bung it's not a problem at all, as Eric demonstrated in his build thread.
Fueled by the haters.
Celestspeed3 is offline   Reply With Quote
The Following 4 Users Say Thank You to Celestspeed3 For This Useful Post:
mason (03-21-2012), RaceBuilt (03-12-2012), shadesofgray19 (03-07-2012), Tokay444 (03-07-2012)
 Old 05-09-2012, 05:48 AM   #144
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
This is my alternate route if my other option falls through, i am curious as to whether or not this ACTUALLY does move the turbo and if there are any issues with it mating up to the DP with a GT3076.
700HP CLUB
11.479@124mph
#DIX
 Old 05-12-2012, 08:05 PM   #145
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Want to retract this statement?
Easter Bunny (08-08-2012)
 Old 05-13-2012, 04:56 AM   #146
No, why would I? That's my opinion. If you don't like it groan it.
I have one of these manifolds one of the first ones, so I'm not saying this manifold is bad. I'm saying it's a waste of money used on the stock flange.
If you don't make use of the EWG then whats the piont? If you do use it an EWG with an ATP hotside you are still stuck with a tiny hotside. Install for this manifold is a bitch so why would you subject yourself to that to make the car sound like a Honda with no appreciatable gains.
 Old 05-13-2012, 06:05 AM   #147
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
He wasnt knocking cp-e. He was making a funny about how racetbuilt is fucking people over.
Downmented likes this.
The Following 3 Users Say Thank You to Monotonous ONE For This Useful Post:
08.5MS3 (05-13-2012), breakfstincluded (05-13-2012), caesura (08-14-2012)
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold nobmood Mazdaspeed3/6 General Discussion 18 03-01-2009 08:14 PM
Turbo Manifold..... mrjoshyman MazdaSpeed 3/6 - Turbo Induction 43 02-28-2009 10:29 AM
DNP Turbo Manifold aviator79 Mazdaspeed3/6 General Discussion 24 04-15-2008 01:55 PM
Page generated in 0.46820 seconds with 36 queries
