 Old 06-07-2015, 11:43 AM   #1
Last_Loser's Avatar
Posts: 739   (View Stats)
Last_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the world
Default Slight problem
So I can't seem to get my wastegate to tighten I have the Precision vband manifold with a TiAL 44 flange. I put the TiAL Wastegate on and tighten the hinge clamp all the way down but I can still move the wastegate and its causing my dump tube to move and lay on the steering rack. Anyone else have this problem? Know how to fix it?
Under Construction
Last_Loser is offline   Reply With Quote
 Old 06-07-2015, 08:54 PM   #2
NCspecV81's Avatar
Posts: 2,867   (View Stats)
did you use the fire ring?
2013 CWP and Stock
 Old 06-08-2015, 07:47 AM   #3
Last_Loser's Avatar
Yep everything is in it. It's definitely snug but not tight. I know everytime I hot a bump it shifts because I push the dumptube back constantly. I also replaced the clamp with a new one and still does it, not sure what is going on unless you're just able to do that and I didn't notice before on my last setup
Under Construction
 Old 06-08-2015, 04:25 PM   #4
NCspecV81's Avatar
well mine doesn't budge.
2013 CWP and Stock
 Old 06-10-2015, 05:34 AM   #5
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
2 weeks
 Old 06-10-2015, 08:36 AM   #6
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Shoot us an email: support@cp-e.com or give us a call and we can try to help you out.
301.576.6142
Website: www.cp-e.com
 Old 06-10-2015, 08:54 AM   #7
Last_Loser's Avatar
301.576.6142
I'll shoot you guys an email after I get back from running errands
Under Construction
Problem after problem: Running rich & Fuel cuts wherewuat 2010 MS3 - Troubleshoot/Diagnostics 30 01-30-2014 02:13 PM
Few Logs with Slight KR BT2010speed 2010 MS3 - ECU Computer Tuning 13 05-02-2012 03:59 PM
For Sale: Fourth-generation Honda Civic hatchback. Slight pest problem. Haltech Automotive News 2 05-28-2009 04:13 PM
slight hesitation 06speed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 12-26-2008 11:15 PM
Page generated in 0.27106 seconds with 23 queries
