Like Tree30Likes
 Old 02-27-2014, 07:41 PM   #41
The Nut's Avatar
Posts: 1,571   (View Stats)
I think removal and inspection is the next step, especially if everything looks OK... When you say it "got threaded," are you saying it may be cross-threaded/stripped?
Yes. Possibly over torqued.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 02-27-2014, 07:53 PM   #42
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
If you can try to back it out slowly I thought one of my bolts to my PMM was cross threaded as fuck but I was able to thread it again and clear up the threads
Sent from my phone whilst bojanglen.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 02-27-2014, 07:54 PM   #43
The Nut's Avatar
God I hope your right. Now if i could just find someone with a hydraulic jack and stands to help me out...
 Old 02-27-2014, 08:04 PM   #44
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
If you aren't fat you can drive up one side on the curb and wiggle under there.
Sent from the lead
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
 Old 02-27-2014, 08:08 PM   #45
macdiesel's Avatar
Posts: 825   (View Stats)
Was torque wrench used?
 Old 02-27-2014, 08:14 PM   #46
The Nut's Avatar
Sent from the lead
I'm fat.
Yes, but I wasn't able to get it to torque down all the way due to laying on my back with the car up on Jack stands. It was good and tight, but I never got it to 85ft lbs. it was fine for 4 days till I put it under heavy load on the Dyno.
Last edited by The Nut; 02-27-2014 at 08:14 PM. Reason: MSF Database - Automerged Doublepost
PUGENE (05-15-2014)
 Old 02-28-2014, 09:49 AM   #47
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Currently having problem with mine. After dyno day it clanks like its broken. Called @www.cp-e.com;, no response yet. Possible that vertical bolt hole got threaded, but IDK. Everything looks fine, but is clanking like a bitch and its not transmitting vibes into the cabin anymore. Fuck my life!
If you can remove it and inspect it and snap pictures that would help out greatly. PM sent with an email address to send pics to.
We are also curious about what you mean by threaded
Website: www.cp-e.com
rfinkle2 (02-28-2014)
 Old 02-28-2014, 09:54 AM   #48
I'm fat.
Are you sure the bolt is still in there? If you couldn;t get it to 85 ft/lbs then there's a good chance that it backed out. I'm assuming you're talking about the verticle bolt for the horse shoe part of the mount correct? If that bolt snapped or backed out then that would definitely explain the clanking. You should definitely get a look at this asap before the possibility of any more damage to your car.
Goodrich27 (02-28-2014)
 Old 02-28-2014, 12:51 PM   #49
The Nut's Avatar
tbat verticle bolt you mentioned is in there, and is most certainly the problem. Only thing holding it in now is some red Loctite and prayers. Threads are stripped in bolt hole. Helical repair needed. Anyway, mount not failing,
Shitty welded on nut design to subframe is.
 Old 02-28-2014, 01:04 PM   #50
As releived as we are that our product wasn't the failure we are still concerned for your safety. PLEASE get this fixed ASAP as we would hate to see any expensive damage to you car done by this and potentially anything happening to you. Keep us updated.
The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post:
2k4_8 (03-17-2014), rfinkle2 (02-28-2014), The Nut (02-28-2014), trancehead (03-14-2014)
 Old 02-28-2014, 01:32 PM   #51
The Nut's Avatar
Thanks and will do. Currently looking for someone local who has the tools and experience to do a helical fix.
 Old 02-28-2014, 01:55 PM   #52
macdiesel's Avatar
Can you cut/grind the bolt off?
 Old 02-28-2014, 02:09 PM   #53
How to repair stripped rmm nut with helical thread repair kit
 Old 02-28-2014, 02:22 PM   #54
The Nut's Avatar
Thanks Rob,
I actually started a thread in the Nator SoCal section to see if anyone has ever done this and has the tools to do it. In the thread I included the same link. I've read through it, and as you've seen the guy that started that thread helped John fix his 2 yrs. ago. John helped me find that thread and helped me verify that the hole was stripped. He put me in touch with Bigriver and he got back to me today. Unfortunately, he doesn't do work on other people's cars anymore. I can't do this job myself as I don't have a drill, the tap tool that doesn't come with the kit, or a lift to put the car up high enough to get a drill with a long ass bit on it into a usable position. So the search for help continues. I'm prob gonna have to pay a shop to do it at this point.
rfinkle2 (03-01-2014)
 Old 03-01-2014, 11:49 AM   #55
The Nut's Avatar
Can't even find a shop willing to do this...ugh!
 Old 03-14-2014, 09:27 AM   #56
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
wish i could try this mount. Ordered it from a local vendor in january and was informed it was on backorder for 2 months?!?! and now possibly a 3rd month?!? if thats the case i'll be seeking a refund and going elsewhere for a RMM
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
The Following 2 Users Say Thank You to tytanium For This Useful Post:
86AmishMs3 (03-14-2014), Royer366 (03-14-2014)
 Old 03-14-2014, 11:35 AM   #57
PUGENE's Avatar
Posts: 1,902   (View Stats)
PUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the world
Groans: 61
Willing to do what?
Sent from my beard...
Precision: PTE 5858
Kozmic: Downpipe//Dumptube//Oil Return&Feed//EGR Delete
Tial: 44mm EWG
HTP: 3.5" Intake + 51r Battery Tray
CPE: Stage 2 RMM//Manifold
JBR: SSP//Shifter Bushings//Knob//TMM//OCC
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
POWERED BY PURPLE DRANK
I'm from Jersey...the Drama State.
PUGENE is offline   Reply With Quote
 Old 03-14-2014, 11:55 AM   #58
Zoom66's Avatar
Posts: 281   (View Stats)
Had mine since I went BT and all I can say is WOW.... great job CP-e....
 Old 03-14-2014, 12:17 PM   #59
The Nut's Avatar
Originally Posted by PUGENE View Post
Willing to do what?
Fix the trilogy of RMM bolt holes for the piece that attaches to the block. But it's getting fixed today by a SoCal Guy called "Eric the Bolt Guy". More info to come on the helicoil repair on the separate thread I have on here:
http://www.mazdaspeedforum.org/forum/foru...t-hole-165402/
rfinkle2 (03-14-2014)
 Old 03-14-2014, 12:55 PM   #60
Royer366's Avatar
Posts: 63   (View Stats)
Royer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant futureRoyer366 has a brilliant future
Groaned at 5 Times in 1 Post
Also ordered mine on Jan. 28th. Still waiting.............................
Royer366 is offline   Reply With Quote
 Old 03-14-2014, 12:59 PM   #61
@www.cp-e.com; These guys need their mounts.
Easter Bunny (03-17-2014), Royer366 (03-14-2014), The Nut (03-14-2014)
 Old 03-14-2014, 02:00 PM   #62
The Nut's Avatar
Found mine used, only reason I got to rock it so quickly. But haven't even got to enjoy it yet due to RMM bolt hole fail. Tonight, we ride!
 Old 03-14-2014, 02:24 PM   #63
Sparrow's Avatar
Posts: 49   (View Stats)
Sparrow has much to be proud ofSparrow has much to be proud ofSparrow has much to be proud ofSparrow has much to be proud ofSparrow has much to be proud ofSparrow has much to be proud ofSparrow has much to be proud ofSparrow has much to be proud of
I ordered mine this month. It just says processing. I wish they would have said if it was back ordered.
Tap tap tap.. Is this thing on?
Sparrow is offline   Reply With Quote
 Old 03-17-2014, 12:12 PM   #64
Sorry for the delay guys. We are having some issues with the CNC machine that makes this part. It should be up and running shortly. We will keep you updated on this when we have a better eta.
 Old 03-17-2014, 12:15 PM   #65
tytanium's Avatar
any guestimate atleast?
2007 CWP MS3
 Old 03-17-2014, 01:01 PM   #66
We are hoping soon. The repairs have taken a little longer than we hoped/expected.
 Old 03-17-2014, 04:10 PM   #67
The Nut's Avatar
Best RMM for out platform. Period.
The Following 2 Users Say Thank You to The Nut For This Useful Post:
Easter Bunny (03-17-2014), Goodrich27 (03-17-2014)
 Old 03-17-2014, 04:40 PM   #68
Royer366's Avatar
We wouldn't know..
 Old 03-17-2014, 05:15 PM   #69
The Nut's Avatar
We wouldn't know..
It's worth the wait.
 Old 03-17-2014, 11:03 PM   #70
tytanium's Avatar
guess I should have ordered from edge as it appears everywhere else including CP-e directly doesn't have any of these mounts in stock
2007 CWP MS3
 Old 03-17-2014, 11:11 PM   #71
The Nut's Avatar
Originally Posted by npoll212 View Post
I just ordered one from edge auto sports and will have it at my house in 3 days!!! should I upgrade the rest of the mounts now or is this ok as is?
follow up, how much vibs will I get from this? keeping car stock for now as it still has the powertrain warranty just want to fix this sloppy shifting action
You'll be very happy. Fairly minimal NHV for a mount that hold your engine in place so well. You'll def see an increase when you go to being fully mounted. As far as if it's time for you to get the other mounts, you might wanna consider listing the rest of your mods. For instance, if your otherwise stock, doing the other 2 should be further down on your list of priorities. Also, donate.
JgamB (03-18-2014)
 Old 03-18-2014, 02:31 AM   #72
Sparrow's Avatar
Thanks for the update.
 Old 03-18-2014, 11:11 AM   #73
JPPatterson's Avatar
Posts: 118   (View Stats)
JPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond repute
Edge doesn't have them although it doesn't show it as out of stock... I'm looking to replace my Corksport Race RMM with one and tried everyone and no dice.
JP
2012 Mazdaspeed 3
CP-E Stage 2 RMM, Autotech Internals, Cobb Accessport V3, Corksport SRI w/tip, JBR Solid Shifter Bushings, JBR Short Throw Plate, JBR Cylindrical Shift Knob, Corksport Catted Downpipe, Corksport Cat Back Exhaust, NGK Plugs, Corksport TMM Insert, AEM V2 Meth Injection, TSW Nurburgring 18x8.5 Wheels
FreekTuned
To Be Installed: Rally Armor Mud Flags (Mazdaru Style)
JPPatterson is offline   Reply With Quote
 Old 03-18-2014, 12:08 PM   #74
Well, I ordered one two weeks ago and they were out and the machine at CP-E hasn't been fixed so either you got lucky or I was unlucky.
JP
2012 Mazdaspeed 3
FreekTuned
 Old 03-19-2014, 07:40 AM   #75
I appreciate that very much @The Nut; but I totally understand the guys are not happy about not getting their mounts.
I do know that there are guys who work closely with CP-E who are members of our forum and it doesn't go unnoticed that you guys need your mounts.
The mount really is very nice, although I would be cranky about waiting too.
jdmage_mx5 (03-19-2014), Nliiitend1 (03-19-2014), Royer366 (04-02-2014)
 Old 03-22-2014, 11:42 AM   #76
montyspeed388's Avatar
Posts: 302   (View Stats)
montyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the worldmontyspeed388 is the leader of the world
Groaned at 8 Times in 3 Posts
I recently picked up this mount after removing the JBR 88 which nothing against them it's a great mount possibly the best performance wise I've felt but the NVH was just too much being that I haz vagina mod and cant take the dashboard rattling to pieces. I didn't even get to choose between the black design and the steel which kind of disappointing me but then again I'm glad cause you never see it anyways and I'd be under there cleaning it lol.
this thing right off the bat isn't as noisy and shaky right when you start it up and during toe in it was a bit harsh before break in but now you don't even know it's there. once in a while under WOT at the top end of 1st gear i'll get some wheel hop but thats about it. after the break in you barely even feel it during toe in unless you let your revs drop too much before letting off the clutch
overall I couldn't be happier I'll be looking forward to upgrading the rest of the mounts in the future!!
www.cp-e.com likes this.
montyspeed388 is offline   Reply With Quote
The Following 2 Users Say Thank You to montyspeed388 For This Useful Post:
rfinkle2 (03-25-2014), www.cp-e.com (03-24-2014)
 Old 03-25-2014, 11:18 AM   #77
From CP-E's facebook page:
Custom Performance Engineering
Timeline
Recent
Liked
We reaching out to you in regards to your backorder for a cp-e™ Stage 2 Rear Motor Mount for either the Mazdaspeed3 or the Focus ST. All of us at cp-e™ would like to thank you for your patience and continued support. As many of you may know, we have had some issues with our main CNC machine that mills these mounts. The repairs to this machine have recently been finalized and, pending successful testing, production will begin again very soon. Let’s keep our fingers crossed that we don’t see any more issues!
We wanted to let you know that these mounts are our number one priority when these machines come back online, and we will be fulfilling orders as quickly as possible. With that being said, we are asking for you to help us - help you! We would like each and every one of you to contact us at orders@cp-e.com. We would like you to respond to this email by choosing one of the two choices below:
1. You would like to receive your mount as soon as possible. cp-e™ will skip the anodizing step, and skip the laser engraving step. cp-e™ will send you a raw billet mount that is 100% functional and will not perform any differently.
2. You would like to continue to wait for the mount. cp-e™ will send you a mount once it is anodized black and laser engraved. This will take an additional 2-4 weeks after machining has finished.
Again, thanks for your patience and understanding! Please respond to this email by contacting orders@cp-e.com or calling us at 301-576-6142. If you do not respond to this email, we will fulfill your order as quickly as possible by sending you a mount that is raw billet with no anodizing and no laser engraving.
We will take responses up until April 1st, after which all back orders will be filled with raw billet mounts.
This announcement will also be posted on the cp-e™ Blog, the cp-e™ Facebook, the cp-e™ Section of FocustST.org, and the cp-e™ Section of MazdaspeedForums!
Nliiitend1 (03-25-2014), The Nut (03-25-2014), trancehead (03-25-2014)
 Old 03-25-2014, 11:32 AM   #78
tytanium's Avatar
i passed the link with that info to my local vendor who ordered mine for them to let CP-e know my decision
2007 CWP MS3
 Old 03-25-2014, 11:39 AM   #79
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I bought mine before they even started anodizing/laser engraving them...
Skip that shit!
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
08.5MS3 (03-26-2014)
 Old 03-25-2014, 02:22 PM   #80
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
Skip that shit!
@Nliiitend1; was one of the firsts!
cp-e stage 2 RMM Review/walkthrough Grumpyjap Custom Performance Engineering (cp-e.com) 180 06-07-2015 09:58 PM
Powerpath Stage 2 Review Oni JAMES BARONE RACING 21 05-31-2013 04:06 PM
JBR Stage 3 Short Shift Kit Product Review poqsccrkid 2010 MS3 - Engine, Transmission & Driveline 0 04-24-2013 08:47 PM
EM Stage III+ Clutch Review Tomas MazdaSpeed 3 - Engine, Transmission & Driveline 44 09-16-2012 03:39 PM
Jbarone SSP Stage 2 Plus Knob install and review asall667 MazdaSpeed 3 - Engine, Transmission & Driveline 11 01-25-2011 09:50 AM
Page generated in 0.60446 seconds with 34 queries
