| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Mar 2008
Rep Power: 0 ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score I bought a used SB 2 that I'm ready to install but I want to zero out everything before I do. How do I do that? Do I just hit back to factory default button? Also would it be safe to have everything zero out and up the boost to 17 psi? |
![]() Join Date: Oct 2008 Location: KY - Bardstown
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score zeroing out the maps means click each table on the left, like under MAF, MAP, Timing, etc and make sure the table reads all 0's. Putting it to 17psi with everything 0'ed out is pretty much how everyone else has started out that I've seen. Run a few pulls with it like that and data log it, then begin making changes from there.
__________________ -bryan CP-E CAI | CP-E FMIC | CP-E Standback v2 | CP-E PnP | CP-E Flash | CP-E SSQV BOV Kit | Cobb STS | Cobb Shifter Weight | SU MM | SU Test Pipe | Boost Gauge | Black out Side Markers | SU Bushings | DashHawk To Be Installed: DNP Turbo Manifold |
(Thread Starter) | Not Ranked : 0 score Thanks man I just did zero everything out, installed the SB at 17.5 psi, ran great with no problems. I just have to now install my Cobb FMIC and Denso plugs to begin tuning Thanks again |
| Not Ranked : 0 score no problem. i'm still new to the sb as well, but i'm running a map that is decent for now. my boost is set at 17 for now.
| CP-E Standback | jhershorin | MazdaSpeed 6 - Engine, Transmission & Driveline | 9 | 10-30-2008 09:53 PM |
| Cp-e Standback???? | oskinosmee | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 08-25-2008 06:35 PM |
| Standback Questions | JimmyMac | Custom Performance Engineering (cp-e.com) | 1 | 07-23-2008 07:26 AM |
