Closed Thread
 Old 11-30-2008, 01:36 PM   #161
possom's Avatar
Posts: 27   (View Stats)
possom will become famous soon enough
I just installed my SB and the car is stuttering at 3k. I've never had this problem before but seen it described for stock vehicles i think. At WOT revving up from 2.5k, it rocks violently. I had it happen around 5k as well once.
My SB is zeroed out other than the default settings in the main section.
Is this normal and should level out as my stock ECU resets from having the battery disconnected during the install? Should i give it some more time before attemtping to tune or is this a sign of a problem? I see zero knock during the spike.
possom is offline
 Old 11-30-2008, 04:58 PM   #162
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
No that is not normal. Do you have the PnP or the hardwired version. Sounds like a bent pin or bad connection on a wire.
As far as my knock, I've got another issue going on now too. My Synapse is fluttering like crazy too. Aviator had the same problem with his and the SB too. I diconnected the SB this morning and got no knock or flutter in stock config. I just reloaded a zeroed map with only 15 and 17 psi boost control. I'll work on this and then get with Jordan when he is back in the office.
jmhinkle is offline
 Old 11-30-2008, 05:20 PM   #163
possom's Avatar
I am going to start a new thread on this so not to pollute this already great one
thread is here
possom is offline
 Old 02-26-2009, 02:13 PM   #164
boostedminime's Avatar
Posts: 251   (View Stats)
boostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant future
Groaned at 16 Times in 4 Posts
i hpe i can do this by myself
2010 mazdaspeed3 (current) jbr rmm, jbr stage 2 intake, jbr shifter bushings, cpe hpfp, obx cbe, catless downpipe, cobb fmic , bosh 3 bar map , jbr 3 port ebc,jbr IM and TB thermal gaskets, jbr egr delete, HKS ssqv,jbr short shift plate .
boostedminime is offline
 Old 02-26-2009, 02:13 PM   #165
or you guys recomend taking it to someone
 Old 02-26-2009, 04:57 PM   #166
robms6's Avatar
Posts: 3   (View Stats)
robms6 is an unknown quantity at this point
Guys I need some help with my tunes.
Just put my cpe ems back in since I finally got myself a DH
I have reverted back to stock thanks to a huge FUEL cut runnin on 17.9
I backed it down to 16.9 and moved the boost clip from 13 to 9
I am also somewhat puzzled by the fact that a mean fuel cut doesnt trigger a knock reading but w/e
log 1 is the stock 17 psi
log 2 is for pure entertainment
robms6 is offline
 Old 02-28-2009, 02:33 AM   #167
wassup61's Avatar
Posts: 1,232   (View Stats)
YGPM
All wagon, No traction
wassup61 is offline
The Following User Says Thank You to wassup61 For This Useful Post:
robms6 (02-28-2009)
 Old 02-28-2009, 09:35 AM   #168
robms6's Avatar
Thanks man if you can email me @ Robproskier@comcast.net
robms6 is offline
 Old 03-05-2009, 02:55 PM   #169
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
So I'm in the process of tuning right now and I'm getting 1.1 knock in the 5500-5700 range at WOT. Now would I pull 1 degree of timing across that whole rpm range or should it be at a certain point of the MAF. A little confused on the timing thing I guess. Any help would be really appreciated.
Thanks
spnkr21 is offline
 Old 03-06-2009, 06:59 AM   #170
ms3powa's Avatar
Posts: 15   (View Stats)
ms3powa is an unknown quantity at this point
Laloosh get back on here!!
ms3powa is offline
 Old 03-25-2009, 09:53 AM   #171
phailerider's Avatar
Thanks
soory...i havent kept up with this thread much. youd pull it through that range. then see what happens.
phailerider is offline
 Old 04-02-2009, 10:33 PM   #172
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Glad to see your back reading this post. Ill be tuning this weekend hopefully and was worried nobody checked this thread anymore.
Now with my current mods, what would you suggest my boost be set at? I was thinking 17.5 to 18...Whats the "downside" to having it set higher? Having it run lean?
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline
 Old 04-02-2009, 10:41 PM   #173
Smoker6's Avatar
Posts: 984   (View Stats)
Smoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the world
I don't see an aftermarket intercooler on your mod list. With the stock TMIC there is a 2 PSI pressure loss across the core (that's how an intercooler that small can work). If you set your target psi at 18, that means the turbo is actually working at 20psi to deliver that boost, and by then it's out of its efficiency range and you're just blowing hot air, not making more power.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout.
Smoker6 is offline
 Old 01-23-2010, 10:45 PM   #174
FearUndersteer's Avatar
Posts: 189   (View Stats)
FearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the world
Alright first thanks everyone for putting all this great tuning info out there. Right now I am shooting for peak boost of 17psi, tapering off to 16 by redline(stock tmic) and I have got my AFR between ~11-11.5. As long as I do not see knock do I add a degree of timing at a time and see what happens?
The car is running great and pulling hard. Once I dial it in a bit more I would be willing to post the file if anyone is interested.
2009 MazdaSpeed3 | True Red
35% Tint
CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC
FearUndersteer is offline
 Old 01-24-2010, 07:49 PM   #175
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Timing not worth it... You can safely add timing at 17 psi IF u have meth. U prob can add a degree or to safely without meth but only for a while and the knock will creep up on you. Its not worth it. Bring you arfs up to a little and raise the boost to 17.5 to 18psi if you want power where your at. And of course ALWAYS make sure you tune is knock free and do a 3rd gear log every couple of weeks to stay in tune with your tune.
gsrtype1 is offline
Closed Thread
Standback Tuning Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 60 10-04-2013 05:59 AM
PnP Standback? Anklh Custom Performance Engineering (cp-e.com) 3 08-07-2008 08:38 PM
Cp-e standback oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 2 08-03-2008 06:28 PM
Page generated in 0.36345 seconds with 32 queries
