Like Tree3Likes
  • 3 Post By superskaterxes
 Old 02-25-2013, 09:22 AM   #1
Default Updates on CP-e Stage 2 Pistons
so when i took my motor apart after lifting my head i found some startling things. I had a few knicks on the top of my pistons from my exhaust valves making contact and i had also lost all 4 of my oil squirters. Now i do have aftermarket cams and i never checked the piston to valve clearance before i installed them because i diddent remove the head. However, the marks below indicate that there is no way i had actual interference and that it must have been an isolated valve float event that cause them to kiss the pistons.
im also not entirely sure why i was missing all of my oil squirters because the machine shop that bent them for me has done it several times in the past and i did not have any interference problems when checking the motor rotation on the stand. They could have bent back due to heat or who else knows lol.
I brought this to the attention of @www.cp-e.com; and asked them if they could make some basic changes to their stage 2 pistons to avoid even the remote chance of this happening in the future. They were technically never designed to be run with aftermarket cams and so far they had not seen a problem with the oil squirters coming off but they decided it would be in their best interest's to remove even the chance of this happening again. So they went back to their supplier and had them add reliefs for the exhaust values and for the squirters to give them even more clearance. I have been told that these will be manufactured like this from here on out but so far they havent seen any problems with their already released sets.
Picts of the changes:
The Following 50 Users Say Thank You to superskaterxes For This Useful Post:
6oost3d (02-25-2013), ASHMS3 (02-26-2013), atvfreek (02-25-2013), blackms3_71 (02-25-2013), BlueStreak (02-25-2013), Boosted Beluga (02-25-2013), captain slow (02-25-2013), Celestspeed3 (02-25-2013), cld12pk2go (02-26-2013), cocoanton (05-14-2013), Code Monkey (02-28-2013), cshunter (03-01-2013), CWP_MS3 (02-25-2013), daafisch (02-25-2013), Dano (02-25-2013), dantes5823 (03-20-2013), djuosnteisn (02-25-2013), fishin53 (02-25-2013), Grumpyjap (02-25-2013), GunGuru727 (02-28-2013), helmetface (02-25-2013), HTP (02-25-2013), jack_hammer (02-25-2013), jeopardy98 (02-26-2013), jmhinkle (02-25-2013), JP@edgeautosport.com (03-01-2013), jracer (02-26-2013), kritz (02-28-2013), leon78 (02-25-2013), Mike@Stratified (02-25-2013), Mr Wilson (02-25-2013), ms3blackmica (02-25-2013), MS3inDC (03-20-2013), nighthawk358 (03-02-2013), psychophyr (02-27-2013), qtrmile beast (02-25-2013), Raider (02-28-2013), RichieRichness (02-25-2013), sidekick (02-25-2013), SPEED6 KILLAH (02-26-2013), SpeedRebirth (02-25-2013), super_pablo_ (03-01-2013), taf0422 (02-28-2013), theschrum (02-25-2013), TiGraySpeed6 (02-25-2013), Tomas (02-25-2013), TWOptSL0W (02-28-2013), UnknownSuperhero (02-25-2013), Vader (02-25-2013), www.cp-e.com (02-27-2013)
 Old 02-25-2013, 11:29 AM   #2
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
What are the specs on your aftermarket cams?
 Old 02-25-2013, 12:20 PM   #3
check out the web cams GB thread. i have the @Tomas; grind
 Old 02-25-2013, 01:45 PM   #4
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
And that's why you failz. Who is that eejit anyway.
The Following 10 Users Say Thank You to Tomas For This Useful Post:
802MS3 (02-25-2013), atvfreek (02-25-2013), djuosnteisn (02-25-2013), helmetface (02-25-2013), jeopardy98 (02-26-2013), ms3blackmica (02-25-2013), superskaterxes (02-25-2013), super_pablo_ (03-01-2013), Tokay444 (02-25-2013), Vader (02-26-2013)
 Old 02-25-2013, 12:25 PM   #5
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
RichieRichness is offline   Reply With Quote
 Old 02-25-2013, 01:06 PM   #6
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
In for teh win!
Thank you for working with them on this, Anthony.
Crack a 10 now please.
www.tunedbynishan.com
The Following 3 Users Say Thank You to ms3blackmica For This Useful Post:
p057 (02-25-2013), qtrmile beast (02-25-2013), superskaterxes (02-25-2013)
 Old 02-25-2013, 01:07 PM   #7
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Yeah, catch up to that Ukrainian.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 02-28-2013, 06:18 AM   #8
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
@www.cp-e.com;
I am thinking about replacing my OTS Wisecos with these since I have everything apart already. Anthony said they will manufacture the pistons with the revision from now on, but if I ordered today would I receive what's left over from the old stock?
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
 Old 02-28-2013, 08:19 AM   #9
This is a step forward. Compression remains the same?
 Old 02-28-2013, 07:03 PM   #10
Originally Posted by theschrum View Post
@www.cp-e.com;
you would have to call and find out.
with the exception of the tiny bit of material missing from the exhaust reliefs, yes
 Old 03-01-2013, 05:12 AM   #11
Tokay444's Avatar
Groans: 793
So then no.
Demodded.
The Seals
Fatguy729 (03-01-2013)
 Old 03-01-2013, 05:26 AM   #12
So then no.
not enough to change 9.5:1 even after rounding to the tenths place.
 Old 03-01-2013, 07:33 PM   #13
cletusb's Avatar
Posts: 488   (View Stats)
I have stage 2 pistons that I got over Xmas that are not installed yet, but no aftermarker cams nor will I ever I would say...
Is it worth returning mine to get the updated version
 Old 03-08-2013, 03:07 PM   #14
theschrum's Avatar
These won't be available for a little while yet. JP from EdgeAutosport contacted CP-e for me. These will be put into production once their old stock is gone, but JP offered to place them on order so they will ship out as soon as they produce them if needed.
Keep in mind that the original design works just fine as long as oil squirter clearances are checked. The new design will give a little more peace of mind with upgraded cams though.
Please verify this post for accuracy @JP@edgeautosport.com;
08 Speed 3|SOLD
The Following 2 Users Say Thank You to theschrum For This Useful Post:
magicka (03-08-2013), superskaterxes (03-11-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f330/updates-cp-e-stage-2-pistons-138971/
Reedy's Engine Rebuild Bonanza! - Page 11 This thread Refback 10-12-2014 10:11 PM
CP-e Stage 2 pistons compared to stock for some discussion jmhinkle MazdaSpeed 3/6 - Build Diaries 59 01-19-2013 02:03 AM
CPE stage 2 pistons available now ! jracer Mazdaspeed3/6 General Discussion 0 03-22-2011 09:37 AM
Page generated in 0.36330 seconds with 28 queries
