Like Tree3Likes
  • 1 Post By LittleredMPS
  • 1 Post By www.cp-e.com
 Old 01-12-2013, 03:48 AM   #1
LittleredMPS's Avatar
Posts: 214   (View Stats)
LittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the world
Default What is it with Cpe and bolts?
Look, I love your gear, it is well designed (For the most part), and looks tits.
But honestly, how is it that you keep screwing up with bolt lengths?
I have just been fitting your, what would be driver's side tranny mount in the US, and when I have bolted down the lower mount piece, and re-used the 17mm bolt from the original mount, I have come up 1/4" from making contact with the mount plate before I ran out of thread depth....
Now if this was a one off, I would take it in my stride. BUT, this is the second time I have bought a mount from Cpe, and had an issue with bolt lengths.
I bought the Stage 2 RMM a while ago, and the main bolt, that joins the tranny piece (which is pure porn by the way) to the chassis fork piece, was so short that I could not fit your supplied spring washer and nut on. Hell, I could barely get a nut on it at all, there was so little thread left over.
Bolt lengths and the comparative thicknesses of mounting plates is not rocket science for craps sake.
Take a look at the OEM mounting plate that goes on the tranny, and see how thick it is. Now look at the thickness of your lower mounting plate....See a slight variance there?
Please...PLEASE, in the future, supply all new bolts and nuts for your Tranny mount kit, and make sure they will actually fit.
End rant.
DaDoctor likes this.
Time for some BT action...Bring it!!!
LittleredMPS is offline   Reply With Quote
The Following 3 Users Say Thank You to LittleredMPS For This Useful Post:
DaDoctor (01-12-2013), Easter Bunny (03-27-2013), SLOWHATCH (03-28-2013)
 Old 01-12-2013, 06:44 PM   #2
DaDoctor's Avatar
Posts: 276   (View Stats)
DaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the world
Had this same issue with tranny mount. I put a couple heavy duty spacers in there. Been on since February with no problems.
Sent from my HTC_Amaze_4G using Tapatalk 2
2011 Mazdaspeed 3 - Black Mica
NJSPEED3 PNP Manifold/Cp-e HPFP/Cp-e Catted DP/Cp-e FMIC/Cp-e Stage2 RMM 75a PMM and TMM/Cp-e Triton/CS Exhaust hangers/JBR SSP V1/3 Bar Map Sensor/Matt Jackson Harness/JBR Tigs
Suspension: KW V1 Coils/CS FSB & RSB/CS Front and Rear Endlinks/CS Aluminum Skidplate/CS Mid-Chassis Brace
Appearance:Lamin-X Smoke - Headlights, Taillights and reflectors/Corksport Antenna/TagArmur CF License Plate/Optima Yellowtop Battery/CS Interior Lighting Kit/DDM 3k/Block8head Defrost guage/ defi red boost guage
DaDoctor is offline   Reply With Quote
 Old 01-12-2013, 11:38 PM   #3
I cut 10mm off the bolt lol.
 Old 01-13-2013, 07:28 AM   #4
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Never had an issue with my stage 2 RMM, even if I had it would've been worth having the only correctly orriented rmm on the market, lol.
 Old 03-26-2013, 07:34 PM   #5
Phil85's Avatar
Posts: 44   (View Stats)
Phil85 is a name known to allPhil85 is a name known to allPhil85 is a name known to allPhil85 is a name known to allPhil85 is a name known to allPhil85 is a name known to all
The irony, now I am kind of flustered I did not see this post but I just installed the transmission mount and had the same dang issue, I called CP-e up immediately monday morning and they said they had not heard of this before I sent them a picture (to chunie) specifically...ugh.
2012 Liquid Silver MS3
MODS: K&N 69 Series Typhoon intake, Turbosmart high pressure bypass valve, Cobb FMIC, Cobb Boost Solenoid, Cobb 3" CBE, Cobb DP, AutoTech HPFP, Cobb AP (Stage 2), CPe RMM, CPe Driver and Passenger side MM, Corksport OCC, Corksport TIP, carbon fiber vinyls and race stripes, Gauge cluster.
Goals: Enkei RP 03 wheels 19x8.5 +22 offset, BNRS3.
Phil85 is offline   Reply With Quote
 Old 03-26-2013, 07:58 PM   #6
@www.cp-e.com;
sidekick (03-27-2013)
 Old 03-27-2013, 07:17 AM   #7
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
@LittleredMPS; Just so we make it clear the problem is with the oem bolt that you reuse correct?
Website: www.cp-e.com
 Old 03-27-2013, 01:40 PM   #8
We are in the process of installing both driver and passenger side mounts on one of our vehicles to see if it's and install issue or if we are sending the wrong size bolt. Not pointing fingers, just trying to get to the bottom of this so we can resolve this and get the people affected by this a solution.
Jh8909 likes this.
The Following 9 Users Say Thank You to www.cp-e.com For This Useful Post:
ABolewski (03-28-2013), El_Diablo (03-27-2013), Jeremy (03-27-2013), Jh8909 (03-27-2013), Keko (03-27-2013), LittleredMPS (03-27-2013), Naaman (03-27-2013), SpeedRebirth (03-27-2013), stevehuff (03-27-2013)
 Old 03-27-2013, 10:58 PM   #9
Yes it is the re-used oem bolt.
If you look at the thickness of your mounting plate in comparison to the thickness of the oem mount plate, you can see how much more depth you would need to tighten it down. Sadly that depth is not present.
I worked out you would need to cut approximately 10mm off the oem bolt to get a safe torque, without bottoming out and potentially stripping the thread out of the gearbox.
 Old 03-28-2013, 07:53 AM   #10
We've tested this on several gen1 and gen2's and only now this issue has come up. Which is why we are investigating again. We will keep you updated on what we find.
 Old 03-28-2013, 08:04 AM   #11
ABolewski's Avatar
Posts: 1,279   (View Stats)
It is possible your Aus Pu has a slightly different (shallower threading) gearbox.
Just saying. If CP-E never had an issue with it, and the fact that many people are running this mount on these forums without issue, that could be the problem.
Also, aren't there three bolts that hold that piece to the gearbox? Are the bolts maybe different lengths?
(sold)
 Old 03-28-2013, 08:07 AM   #12
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
Cp-e's stuff is amazing quality, love it. I have the fmic, dp, and stage 2 rmm.
I had bolt issues with 2 of 3 though. The rmm didn't come with the main bolt that held the two parts together, and the fmic came with the two bolts to hold it to the crash bar but one was the wrong size (too thin).
Thankfully its nothing going to the hardware store can't resolve and not even $5.
like I said though, still great products and I'm really looking forward to the intake mani they've got coming!
just check the bolts before installing so you don't have to put your car back together to run down to the hardware store.
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
 Old 03-28-2013, 08:09 AM   #13
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
sub
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 03-28-2013, 08:25 AM   #14
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Measure the bolt hole depth
Skreets be calling...
The Following User Says Thank You to BobtailedSnail For This Useful Post:
ABolewski (03-29-2013)
 Old 05-09-2013, 05:28 PM   #15
Reedy's Avatar
Posts: 391   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
I'm gonna go ahead and resurrect this thread.
Once the CP-e exclusive Australian distributor bullshit rights are sorted out then I will be looking to get a S2 RMM for my Gen 2 MPS. I have the same year/model that LittleRedMPS has and I don't really want to encounter this problem. So what's the deal?
Reedy is offline   Reply With Quote
How To: Ugrade Your BPV Bolts ms3blackmica MazdaSpeed 3 - How-To's 29 09-26-2014 08:28 AM
Rod Bolts jordan4g63 MazdaSpeed 3 - Engine, Transmission & Driveline 18 05-23-2011 12:09 PM
How far to torque bolts? drenkel 2010 MS3 - Engine, Transmission & Driveline 4 05-16-2010 10:26 AM
Bolts for cover damianinpa MazdaSpeed 6 - Engine, Transmission & Driveline 3 04-25-2010 08:03 PM
Rod bolts 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 0 04-01-2010 11:57 PM
Page generated in 0.34758 seconds with 30 queries
