| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Jan 2010 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 188
(Thread Starter) | Not Ranked : 0 score But honestly, how is it that you keep screwing up with bolt lengths? I have just been fitting your, what would be driver's side tranny mount in the US, and when I have bolted down the lower mount piece, and re-used the 17mm bolt from the original mount, I have come up 1/4" from making contact with the mount plate before I ran out of thread depth.... Now if this was a one off, I would take it in my stride. BUT, this is the second time I have bought a mount from Cpe, and had an issue with bolt lengths. I bought the Stage 2 RMM a while ago, and the main bolt, that joins the tranny piece (which is pure porn by the way) to the chassis fork piece, was so short that I could not fit your supplied spring washer and nut on. Hell, I could barely get a nut on it at all, there was so little thread left over. Bolt lengths and the comparative thicknesses of mounting plates is not rocket science for craps sake. Take a look at the OEM mounting plate that goes on the tranny, and see how thick it is. Now look at the thickness of your lower mounting plate....See a slight variance there? Please...PLEASE, in the future, supply all new bolts and nuts for your Tranny mount kit, and make sure they will actually fit. End rant.
__________________ Time for some BT action...Bring it!!! [SIGPIC][/SIGPIC] |
| The Following 3 Users Say Thank You to LittleredMPS For This Useful Post: |
![]() Join Date: Mar 2011 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 414
| Not Ranked : 0 score Had this same issue with tranny mount. I put a couple heavy duty spacers in there. Been on since February with no problems. Sent from my HTC_Amaze_4G using Tapatalk 2
__________________ 2011 Mazdaspeed 3 - Black Mica NJSPEED3 PNP Manifold/Cp-e HPFP/Cp-e Catted DP/Cp-e FMIC/Cp-e Stage2 RMM 75a PMM and TMM/Cp-e Triton/CS Exhaust hangers/JBR SSP V1/3 Bar Map Sensor/Matt Jackson Harness/JBR Tigs Suspension: KW V1 Coils/CS FSB & RSB/CS Front and Rear Endlinks/CS Aluminum Skidplate/CS Mid-Chassis Brace Appearance:Lamin-X Smoke - Headlights, Taillights and reflectors/Corksport Antenna/TagArmur CF License Plate/Optima Yellowtop Battery/CS Interior Lighting Kit/DDM 3k/Block8head Defrost guage/ defi red boost guage |
(Thread Starter) | Not Ranked : 0 score I cut 10mm off the bolt lol.
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score Never had an issue with my stage 2 RMM, even if I had it would've been worth having the only correctly orriented rmm on the market, lol.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() Join Date: Jul 2012 Location: O'ahu, Hawaii
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score The irony, now I am kind of flustered I did not see this post but I just installed the transmission mount and had the same dang issue, I called CP-e up immediately monday morning and they said they had not heard of this before I sent them a picture (to chunie) specifically...ugh.
__________________ 2012 Liquid Silver MS3 MODS: K&N 69 Series Typhoon intake, Turbosmart high pressure bypass valve, Cobb FMIC, Cobb Boost Solenoid, Cobb 3" CBE, Cobb DP, AutoTech HPFP, Cobb AP (Stage 2), CPe RMM, CPe Driver and Passenger side MM, Corksport OCC, Corksport TIP, carbon fiber vinyls and race stripes, Gauge cluster. Goals: Enkei RP 03 wheels 19x8.5 +22 offset, BNRS3. |
| The Following User Says Thank You to superskaterxes For This Useful Post: | sidekick (03-27-2013) |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score @LittleredMPS; Just so we make it clear the problem is with the oem bolt that you reuse correct?
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
| Not Ranked : 0 score We are in the process of installing both driver and passenger side mounts on one of our vehicles to see if it's and install issue or if we are sending the wrong size bolt. Not pointing fingers, just trying to get to the bottom of this so we can resolve this and get the people affected by this a solution.
| The Following 9 Users Say Thank You to www.cp-e.com For This Useful Post: | ABolewski (03-28-2013), El_Diablo (03-27-2013), Jeremy (03-27-2013), Jh8909 (03-27-2013), Keko (03-27-2013), LittleredMPS (03-27-2013), Naaman (03-27-2013), SpeedRebirth (03-27-2013), stevehuff (03-27-2013) |
(Thread Starter) | Not Ranked : 0 score Yes it is the re-used oem bolt. If you look at the thickness of your mounting plate in comparison to the thickness of the oem mount plate, you can see how much more depth you would need to tighten it down. Sadly that depth is not present. I worked out you would need to cut approximately 10mm off the oem bolt to get a safe torque, without bottoming out and potentially stripping the thread out of the gearbox.
| Not Ranked : 0 score We've tested this on several gen1 and gen2's and only now this issue has come up. Which is why we are investigating again. We will keep you updated on what we find.
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
| Not Ranked : 0 score It is possible your Aus Pu has a slightly different (shallower threading) gearbox. Just saying. If CP-E never had an issue with it, and the fact that many people are running this mount on these forums without issue, that could be the problem. Also, aren't there three bolts that hold that piece to the gearbox? Are the bolts maybe different lengths?
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
![]() ![]() Join Date: Dec 2011 Location: San Marcos, TX
Rep Power: 692 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,138
Groans: 38
| Not Ranked : 0 score Cp-e's stuff is amazing quality, love it. I have the fmic, dp, and stage 2 rmm. I had bolt issues with 2 of 3 though. The rmm didn't come with the main bolt that held the two parts together, and the fmic came with the two bolts to hold it to the crash bar but one was the wrong size (too thin). Thankfully its nothing going to the hardware store can't resolve and not even $5. like I said though, still great products and I'm really looking forward to the intake mani they've got coming! just check the bolts before installing so you don't have to put your car back together to run down to the hardware store.
__________________ 06 MS6 & 06 MS6 [SIGPIC][/SIGPIC] The beauty is the beast Daily driven |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,419
Groans: 81
Groaned at 30 Times in 25 Posts
| Not Ranked : 0 score sub
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler |
![]() Join Date: Apr 2011 Location: Millsboro, De
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,597
| Not Ranked : 0 score Measure the bolt hole depth
__________________ 2006 Mazdaspeed 6 GT-unDISI swap in progress 1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5 Skreets be calling... [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to BobtailedSnail For This Useful Post: | ABolewski (03-29-2013) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score I'm gonna go ahead and resurrect this thread. Once the CP-e exclusive Australian distributor bullshit rights are sorted out then I will be looking to get a S2 RMM for my Gen 2 MPS. I have the same year/model that LittleRedMPS has and I don't really want to encounter this problem. So what's the deal? |
| How To: Ugrade Your BPV Bolts | ms3blackmica | MazdaSpeed 3 - How-To's | 29 | 09-26-2014 08:28 AM |
| Rod Bolts | jordan4g63 | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 05-23-2011 12:09 PM |
| How far to torque bolts? | drenkel | 2010 MS3 - Engine, Transmission & Driveline | 4 | 05-16-2010 10:26 AM |
| Bolts for cover | damianinpa | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 04-25-2010 08:03 PM |
| Rod bolts | 06Speed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 04-01-2010 11:57 PM |
