Closed Thread
 Old 01-28-2011, 03:31 AM   #1
dspider's Avatar
Posts: 119   (View Stats)
dspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud of
Default Where to get a tune ?
anyone know where i can get my standback installed and tuned in or around Toronto (Canada) ?
[SIGPIC][/SIGPIC][/SIGPIC]Just to be fair i hate everyone equally , so dont feel left out.
dspider is offline
 Old 01-28-2011, 05:47 AM   #2
blackwidow's Avatar
Posts: 85   (View Stats)
blackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud of
I'm from Montreal , and i got tuning from P3 in 2009 on the CP-E dyno , i will return for a new tuning in a few months because i have a new turboback exhaust and the BNR stage 2 turbo so will see ... It's 12 hours of road from here but i will have result . No Standback tuner in Canada.
Mazdaspeed6, CP-E dyno 275WHP/255 WT ,BNR turbo ,CP-E intake,CP-E turbo inlet,CP-E flash,CP-E standback,CP-E fuel pump,CP-E mount,Turbosmart bov,Corksport catback,ATP catted downpipe,ETS tmic ,Saikou Michi OCC, Turbinetech mounts,TWM short shifter stage II + bushings + shifter plate ,Aem boost et wideband gauge,Dashhawk,Autoexi tower bar, Apexi turbo timer,Mazdaspeed mags,huiles Amsoil,Fiberimages CF hood & truck ,Speedline CF grill, R1 concept disques de freins,EBC red stuff pads,Hankook tires,Megan racing coilover ,Kicker amplifier .
blackwidow is offline
 Old 01-28-2011, 07:56 AM   #3
stefan's Avatar
Posts: 2,216   (View Stats)
stefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the world
Groans: 140
Groaned at 116 Times in 64 Posts
or you could take some dashhawk / standback logs and ask one of the knowledgeable guys on the forums if they could help you out with an e-tune.
Originally Posted by NJSPEED3:
you see here in NJ when you meet the nj nator crew ...its a wrap for your warranty son
stefan is offline
 Old 01-28-2011, 04:16 PM   #4
dspider's Avatar
cool thanks guys , i might have found a place my mechanic recommended. gotta go check it out ,if they cant then i might be hitting up the guys on the forum.. i want to go local so i can set up for the different seasons..(winter/summer) from what i understand the temp makes a difference .. i am thinking two maps one summer one winter , if i can
dspider is offline
Closed Thread
E-Tune with CP-E 11cruzito11 Custom Performance Engineering (cp-e.com) 23 05-05-2010 05:41 PM
tune necessary if i have ... Lvis 2010 MS3 - ECU Computer Tuning 3 04-14-2010 10:48 PM
Page generated in 0.23949 seconds with 22 queries
