> Cobb Tuning >
Cobb Access Port/Maps
 Old 03-30-2015, 02:56 PM   #1
mariosalguero's Avatar
Posts: 30   (View Stats)
mariosalguero will become famous soon enough
Default Accessport Maps/Custom Map - Help
Im Currently running the Stage 1+SF 91 off the shelf map on my 07 ms3. I recently upgraded my stock TMIC to the Street Unit TMIC. Is there a way to get a map that includes this upgrade without going stage 2 or without having it Dyno-tuned? Feel free to suggest any alternatives.
Thanks.
My current mods are:
-Cobb Short ram & inlet hose
-Cobb Rear Motor Mount
-Street Unit TMIC
-Corksport Race Pipe
-HKS Catback Exhaust
-HKS BOV
-Denso ITV22 Sparkplugs
mariosalguero is offline   Reply With Quote
 Old 03-30-2015, 03:43 PM   #2
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Why do you have all those mods and no hpfp upgrade?
But to answer your question, no, there is no map designed for your mods
 Old 03-30-2015, 06:07 PM   #3
I was looking into upgrading fuel pump internals. but what are the added benefits or differences between brands?
The Following User Says NO Thank You to mariosalguero For This Un-useful Post:
Thepedigree13 (03-30-2015)
 Old 04-07-2015, 03:55 PM   #4
pirate steve's Avatar
Posts: 248   (View Stats)
pirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the world
In a nut shell, the benefit is that you won't blow up your engine from fuel starvation. The stock CDFP internals can't maintain high enough fuel pressures that will come with increased boost levels.
I've got KMD internals (were on the car when I bought it) and I've had no issues with them.
2011 grey MS3: HTP TIP, COBB SRI, HPFP internals, CS TMIC, Dammond EGR delete, Dammond OCC, M2 full DP all of the cats deleted, freektune OTS+, denso ITV22, Maisonvi turbo bolt, CP-e S2 RMM
pirate steve is offline   Reply With Quote
 Old 03-30-2015, 03:59 PM   #5
AnubisFSU's Avatar
Posts: 117   (View Stats)
AnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond repute
I would suggest getting in touch with e-tuners (stratified or freektune) buy a ots+ tune until your ready for a full tune.
Edit: aftermarket fuel pump internals would be a smart investment aswell.
Last edited by AnubisFSU; 03-30-2015 at 04:02 PM. Reason: hpfu would be a smart move as well
AnubisFSU is offline   Reply With Quote
 Old 04-01-2015, 08:08 PM   #6
G1sdaname's Avatar
Posts: 519   (View Stats)
G1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the world
I'm no expert but Autotech internals have great reviews, can't go wrong with them.
CP-E Catted TBE | COBB: AP, RMM, EBCS | AutoTech Internals | Wheels - Montegi R116
BNR3 | JBR: Tru 3.0 Intake, Under-engine FMIC piping, SSP | TR8 | TurboSmart BPV
MilTuned - e85
Next up: Make more money for Meth (2x)
-Gabe-
G1sdaname is offline   Reply With Quote
The Following User Says Thank You to G1sdaname For This Useful Post:
HYDRO (04-01-2015)
 Old 04-01-2015, 10:08 PM   #7
Castillo817's Avatar
Posts: 745   (View Stats)
Castillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the world
Groaned at 44 Times in 12 Posts
+1 can't go wrong with Autotech's internals!
2013 VRM MS3
Freektuned--BNRS3--HTP 3" Sri--COBB apv3 & springs--CPE catted dp & safe seals--TS dual bov--AT hpfp internals--CFM rmm--JBR pmm, tmm, ssb, ebcs, TIGs, full egr delete, rsb & fmic piping/tr6--DM occ--CS cbe & ssp--SPC camber arms--Bosch 3Bar map--RA mudflaps
Ambit RE82 18x9.5 +38 255/35
-v8 swap in progress-
1994 Miata
DGR coilovers-Hard Dog Rollbar-STR 506 15x7.5 +15
-Sold-
2003 Protegé5 w/Hiboost turbo kit ihi vf22 turbo 5 speed
-Sold-
89' FC Rx7 vert S5 13B turbo swapped
Castillo817 is offline   Reply With Quote
 Old 04-05-2015, 05:48 PM   #8
lescano88's Avatar
Posts: 40   (View Stats)
lescano88 is a jewel in the roughlescano88 is a jewel in the roughlescano88 is a jewel in the rough
+2 for autotech. i wouldn't even run a tune without upgrading hpfp. had that issue with one of my speed6 turnout running dangerously lean.
2006 MS6 Sport
BNR S4,Grimmspeed 3port EBCS, Bosch 3 bar map,Autotech HPFP internals-AP V3/FreekTuned-COBB SF Intake,TIP,BPV
Mishimoto FMIC,TMM,PMM,RDM,RMM,Corksport Rear chassis brace,CPE DP w/Highflow Cat,Corksport CBE, safe injector seals-NGK 6510
JBR EGR Block Off Kit,JBR BPV Hose,Redefined Performance PCV Plate,OCC S2,Odyssey PC680MJ Battery,SU Short Shifter,JBR solid shift bushings/weight,Eibach Pro-Kit Springs,Koni Sport Adjustable Shocks,SPC Camber Adjustable Ball Joints
Michelin Pilot Super Sports 225/40ZR18(summer)/Continental Extreme Contact DWS 215/45zr18(winter)
TRS mini projector retrofit w/h1 Morimoto 55w,60mm STRI boost guage
2013 Mitsubishi Outlander Sport SE
Stock
lescano88 is offline   Reply With Quote
 Old 04-05-2015, 07:44 PM   #9
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Autotech or Corksport, get with a forum vendor for the best price.
Using bad grammar from my cell phone.
 Old 04-07-2015, 03:47 PM   #10
Chailly19's Avatar
Posts: 3   (View Stats)
Chailly19 is an unknown quantity at this point
CorkSport HPFP are a great product (what I run) or Autotech's cant go wrong with either. I wouldn't run a tune without them. I agree with SarcasticOne why don't you already have this mod with your current set-up? After that contact Will Dawson at Purple Drank Tuning for your E-tune he will have you dialed in no time
Chailly19 is offline   Reply With Quote
 Old 04-07-2015, 05:15 PM   #11
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
Get the autotechs..then go to freektune. Love the tune he gave me on my OTS+ map, and for a pretty good price as well. Best mod I've done so far.
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
 Old 04-08-2015, 04:17 AM   #12
ParkJoMS3's Avatar
Posts: 60   (View Stats)
ParkJoMS3 has much to be proud ofParkJoMS3 has much to be proud ofParkJoMS3 has much to be proud ofParkJoMS3 has much to be proud ofParkJoMS3 has much to be proud ofParkJoMS3 has much to be proud ofParkJoMS3 has much to be proud ofParkJoMS3 has much to be proud of
You should be running the safe mode ots map till you get the hpfp internals. I dont dare run tunes without hpfp internals done first as safety for your motor even if the ones are safe mode.. although the safe modes are designed to run with stock cdfp setup.
ParkJoMS3 is offline   Reply With Quote
 Old 04-21-2015, 02:33 PM   #13
Thanks!
I will definitely be upgrading my fuel pump internals. Most likely going with autotech, then hitting up one of the e-tunners.
ASHMS3 , what do you mean by forum vendor?
 Old 04-21-2015, 02:51 PM   #14
ParkJoMS3's Avatar
A forum vendor is the companies on the main page to buy from. Look at their sites for parts.
The Following User Says Thank You to ParkJoMS3 For This Useful Post:
mariosalguero (04-21-2015)
New AccessPORT Off-The-Shelf Maps for Australia Mazda3 and Mazda 6 MPS Cobb Tuning 2010 MS3 - ECU Computer Tuning 3 06-16-2012 06:01 PM
New AccessPORT Off-The-Shelf Maps for Australia Mazda3 and Mazda 6 MPS Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 0 06-15-2012 03:38 PM
Look for help with getting custom maps for AP RedLegSoldier81 MazdaSpeed 3/6 - ECU Computer Tuning 3 12-26-2011 05:28 PM
Page generated in 0.34823 seconds with 30 queries
