> Cobb Tuning >
Cobb Access Port/Maps
 Old 03-04-2009, 03:20 PM   #1
Matrix311's Avatar
Posts: 2,133   (View Stats)
Default Am I safe? Stage 2 v1.03 Final
This is a datalog of a recent run I did yesterday afternoon. This was logged with Stage 2 v1.03 Final 91oc+fmic+sri.
I just wanted to get some feedback if my fuel pressure looks good and my afrs look good and if there is anything I should be worried about. I'm not the best at reading these so any advice or feedback is appreciated.
Thanks for your help
Eric
 Old 03-04-2009, 03:24 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
fuel pressure looks great until 6000 rpms...
throughout this graph, your throttle is also at 74% at its highest...are you flooring it?
and the afr is kind of rich, but whatever
 Old 03-04-2009, 03:25 PM   #3
Matrix311's Avatar
Ya i'm flooring it, the peddle doesn't go any further lol.
phillyb (03-04-2009)
 Old 03-04-2009, 03:39 PM   #4
phillyb's Avatar
Groans: 1,940
gotcha...
 Old 04-22-2011, 07:52 PM   #5
bspearman88's Avatar
Posts: 5   (View Stats)
bspearman88 is on a distinguished road
mine datalogger shows the same exact thing its some kind of glitch or whatnot. he's wideopen though.
fuel pressure looks good. those are pretty good numbers. they say < 1400 psi is when you should start to become concerned, and you will also see some knock to go with the decreased fuel pressure.
bspearman88 is offline   Reply With Quote
The Following User Says NO Thank You to bspearman88 For This Un-useful Post:
wolly6973 (04-23-2011)
 Old 03-04-2009, 03:28 PM   #6
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
kr looks great
 Old 03-04-2009, 03:32 PM   #7
Matrix311's Avatar
Originally Posted by skeeter149 View Post
kr looks great
I only get KR immediately after I start my car. I can be in cruising mode or simply shifting gears and i'll get KR and it only happens after the car has been sitting. Once the car is up and running and warmed up I wont get any KR. Is this common with everyone else?
 Old 03-04-2009, 04:42 PM   #8
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
I've found letting the coolant get up to temp makes a big difference in KR also.
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 03-04-2009, 03:43 PM   #9
smakdown61's Avatar
Posts: 1,069   (View Stats)
Stock boost and rich afr ftl. Cobb 91 maps fail.
smakdown61 is offline   Reply With Quote
 Old 03-04-2009, 03:51 PM   #10
Matrix311's Avatar
So move back to v1.03 beta? I had good luck with v1.03L as my car ran nice with it.
 Old 03-04-2009, 04:21 PM   #11
Everything looks good and safe.
 Old 03-05-2009, 08:53 AM   #12
Matrix311's Avatar
thanks for the feedback, anyone else?
 Old 03-05-2009, 09:02 AM   #13
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
74% is max throttle reading on AP. your graphs look good. i think you FP drop at 6000rpm there is because you shifted or let off the throttle. nice log.
 Old 03-05-2009, 09:33 AM   #14
Matrix311's Avatar
I just switched back over to the Stage 2 v1.03L 91+FMIC+SRI map. This map runs a little leaner then the v1.03 final and i've always loved this map. I'll get a few hundred miles on this map and do another pull to compare results. So far with v1.03L my KR is slim to none and if it ever does result, it's usually only .7 at max where v1.03 final I would hit 5.1KR (after a cold start) intermittently and NOT at WOT.
 Old 03-05-2009, 08:43 PM   #15
evo2ms3's Avatar
Posts: 287   (View Stats)
evo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the world
Is that the stock fuel pump holding that good? I'm suprised that map runs so rich and has that low boost. I'd expect more from a stage2+fmic map. But safe it is, which is good.
//Cobb AccessPORT//Cobb E-Tune@20psi//SU TMIC//Mazdaspeed CAI//HKS SSQV//RPMC Turbo Inlet//CP-E HPFP//Corksport Race Pipe//Resonator Delete//Corksport MM Inserts//TWM STS//TWM Bushings//Denso ITV22//Prosport Premium Boost//RX-8 Wheels//Kumho Ecsta XS's 235-40//Valentine One//35% Tint//TRADED IN
WW EVO X GSR//SSS//Navi//Advan Racing RS 19x10//BC Racing Coilovers//Cobb AccessPORT//Perrin 3-port/AMS FMIC//UR UICP//Works Air Filter//UR Test Pipe//Trust PE II Exhaust//Defi Boost Gauge//APR Vortex Generator//Ralliart Tails//20% Tint//Valentine One//
evo2ms3 is offline   Reply With Quote
 Old 03-06-2009, 08:23 AM   #16
Matrix311's Avatar
Yes I am running the stock fuel pump still as that has never been changed out or adjusted.
 Old 03-06-2009, 07:38 AM   #17
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
I don't think that map is supposed to have such low boost and run that rich. What are your ltft's? Why would stage 2+sri+fmic only hold 15psi when on stage 1+ sri I hold close to 19psi? Something is not right.
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
 Old 03-06-2009, 07:51 AM   #18
bova's Avatar
Groans: 45
my guess is boost leak, that would signal why its running rich as well.
 Old 03-06-2009, 08:26 AM   #19
Matrix311's Avatar
What is the easiest way to check for a boost leak? I must have had a boost leak for quite sometime then, when I ran my last dyno I was running Stage 2 v1.03L 91+fmic+sri beta map and my best run with my mods was 281whp/339lb-ft with a max boost of 16.1psi is what the dyno pulled. I was running on a Maha 3100 dyno.
I guess I can tear my car apart and check to make sure all t-clamps are tight. I've heard of people having issues with the HKS SSQV BOV, should I consider putting the stocker back on or would that have bigger chances of leaking?
 Old 03-06-2009, 09:03 AM   #20
bova's Avatar
Groans: 45
you can build a simple tester. just search google for boost leak tester and i'm sure there will be tons of examples. i just bought a pipe cap that fits on my 2.25" piping and drilled a hole int he middle and put a tire valve stem. that way i can use my air compressor to fill the pipes.
 Old 03-06-2009, 09:09 AM   #21
Matrix311's Avatar
Maybe buy a tester from here?
Boostpro.net : Specializing in performance
 Old 03-06-2009, 09:41 AM   #22
bova's Avatar
Groans: 45
you could make one for like $5 no joke.
 Old 03-06-2009, 09:54 AM   #23
Matrix311's Avatar
hmm we'll see what i can find as far as making one. I'm not to handy when it comes to fabricating things. The one that is already made looks like a cheap way out. For $20 and saving me time may be worth it.
 Old 03-06-2009, 07:16 PM   #24
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
Is your dp catted?
As others have stated your boost is too low for your mods.
Speedn3 is offline   Reply With Quote
 Old 03-07-2009, 08:20 AM   #25
Matrix311's Avatar
My DP is catted yes.
I took off the bumper yesterday and went through and tightened all my t-clamps for all the intercooler piping. Checked all the vaccum lines that I could find to make sure they were secure. I have no idea why I can't maintain my boost.
Lets say I DONT have a boost leak, what other problems could it be? Could the wastegate be a problem from allowing me to keep 18-19psi through 6k rpm?
 Old 03-07-2009, 04:21 PM   #26
evo2ms3's Avatar
I'm bet it's just the 91oct map that is giving you low boost. On stage1+ 91oct I held 16-17psi. Same map but 93oct, I held 18-19psi.
 Old 03-07-2009, 04:36 PM   #27
ill_eagle94's Avatar
Posts: 36   (View Stats)
ill_eagle94 is a jewel in the roughill_eagle94 is a jewel in the roughill_eagle94 is a jewel in the rough
Leaky HKS valve maybe?
2007 Mazdaspeed 3 GT
Best ET: 13.886@102.00
Best Trap: 14.056@105.85
Best 60' 2.209
3250 lbs full interior with driver, spare, etc...
255WHP 267WTQ on Dynojet. Odd, no?
ill_eagle94 is offline   Reply With Quote
 Old 03-12-2009, 03:22 PM   #28
Matrix311's Avatar
When you switched to the 93oct map, what oct fuel were you running? Were you putting 91, 92 or 93 oct fuel in your car?
 Old 03-16-2009, 12:34 PM   #29
timv's Avatar
Posts: 179   (View Stats)
timv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud of
Matrix,
I have almost the exact same mods as you except I have hks step colder plugs, stock BPV, RPMC inlet, and pg cdfp internals.
I just bought a used AP to run and compare to what I was able to tune my standback for. I removed my standback completely and loaded up this same map on my car. I have about 100 miles on it right now and did a quick 4th gear WOT log just now up to almost 6000 rpm.
My boost falls to 16 towards 6000 rpm but not close to as quick as yours and my AFR's are closer to 12....
Here's my graph.....
Maybe try your stock bpv???
timv is offline   Reply With Quote
 Old 03-16-2009, 12:57 PM   #30
Matrix311's Avatar
Originally Posted by timv View Post
Matrix,
Ya your car is nearly identical to mine and you sure do hold boost a lot better. I did put my stock BPV back on over the weekend, i'll take it out and get a solid 4th GR WOT run to compare the differences. Hopefully I can 16psi+ through redline so we'll see. I'm losing a ton of power
 Old 03-17-2009, 11:07 PM   #31
timv's Avatar
Matrix,
Here are the graphs from logs i did today.
I'm really liking how this final 103 map feels and how my logs look.
I was never able to tweak in my boost or AFR this good with the standback.....
I did 6 runs, 2 of them had a bit of knock but i could see from the logs that the ecu pulled timing and went rich to counteract the knock.....
Here are the other 4 logs....... I'm definitely holding boost better then you were with your earlier logs...
 Old 03-18-2009, 11:17 AM   #32
Matrix311's Avatar
lookin good. I'm going to go out behind my house and do a few runs to see how the stock bpv is holding my boost vs the hks ssqv. That may or may not be a problem so we'll see. The car overall feels more zippy to me with the stock bpv, but who knows.
 Old 03-18-2009, 11:22 AM   #33
LBV
LBV's Avatar
FWIW, I just did a log on the Cobb no meth versus with meth and this is on the stock BPV ... take a look at that boost curve - yep that's 19 psi in the mid-6000's ... stock BPV FTW!
P.S. I love that AFR and boost curve ... Christian's done a bang-up job on this map (MS6 not MS3).
 Old 03-31-2009, 07:08 PM   #34
Scottybones's Avatar
Posts: 10   (View Stats)
Scottybones will become famous soon enough
Eric
You probably could lean it out a bit in spots, but looks like a safe tune. The question is, how does it feel to you? Don't forget, unless someone is doing on the spot tuning on a dyno, your never going to get a perfect tune. Safe is perfect in this case.
Scottybones is offline   Reply With Quote
 Old 04-01-2009, 09:44 AM   #35
Matrix311's Avatar
ok thanks! I actually switched from the v1.03 final map to the v1.03L beta map. I like this map the best. Knock is next to non and it feels more zippy.
 Old 04-01-2009, 10:48 AM   #36
timv's Avatar
What do your logs look like with the L beta map???
Could you post some?
Still using the stock BPV or your HKS again?
Thanks...
 Old 04-01-2009, 11:03 AM   #37
Matrix311's Avatar
I'm still using the stock BPV, i'll run out back and do another run here during lunch and post up the log from today.
 Old 04-01-2009, 11:10 AM   #38
Matrix311's Avatar
Here is a 4th gear run from 3-18-09 with about 90 miles on the ECU after I put the stock BPV back on. This was with Stage 2 91oct v1.03L beta map. I want to go do another run today, i've got over 500 miles on the ECU with the v1.03L beta map and stock BPV together. So it may be a little more accurate.
3-18-09 v1.03L Beta Stage 2 91oc fmic+sri with stock BPV
Will this be SAFE? SLOMS3 MazdaSpeed 3/6 - Wheels & Tires 4 09-27-2008 11:44 PM
reworked turbo - to be safe i should... xcoldricex MazdaSpeed 3/6 - ECU Computer Tuning 3 08-23-2008 09:17 PM
SentrySafe FIRE-SAFE Combination Safe (1.2 Cubic Ft) $143.97 Haltech Hot Deals Section 0 03-28-2008 07:40 PM
Page generated in 0.56928 seconds with 33 queries
