> Cobb Tuning >
Cobb Access Port/Maps
Like Tree3Likes
  • 1 Post By Cobb Tuning
Closed Thread
 Old 01-12-2017, 01:12 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default BETA TEST: Stage 2 and 3 maps (USDM only for now)
Hey folks it's Mike here. I've recently taken on Mazda calibration at COBB and made a few tweaks to existing OTS maps for stage 2 and 3 cars related to boost control. I've done so based on customer feedback, especially from cold climates, that some cars are over boosting significantly. While the Accessport allows for tweaking of wastegate duty cycle at time of reflash, the updates in these new OTS files will likely make those adjustments unnecessary and offer greater precision of boost control.
If interested, please email: mazda.beta@cobbtuning.com with your name, year/model vehicle, AP serial number and mods list. If your vehicle has the appropriate parts for use with COBB OTS stage 2 or 3 maps (listed below) I'll provide you with free beta maps for testing. In return, I expect anyone taking advantage of this beta map program to email me logs and feedback. That way I know if these maps are an improvement for you guys before we release them publicly.
Stage2 Parts Required:
COBB SF Intake, COBB Turbo Inlet Hose (TIH), Autotech High Volume Fuel Pump (CDFP), COBB Catback exhaust and COBB High Flow Downpipe. Stock engine, turbo, intercooler.
or
Stage3 Parts Required:
COBB SF Intake, COBB Turbo Inlet Hose (TIH), Autotech High Volume Fuel Pump (CDFP), COBB Catback exhaust and COBB High Flow Downpipe, COBB Front Mount Intercooler (FMIC). Stock engine and turbo.
If anyone has questions or concerns please let me know! Thanks guys!
Mike @ COBB
davros likes this.
MAZDASPEED EXPERT GROUP
Cobb Tuning is offline
The Following User Says Thank You to Cobb Tuning For This Useful Post:
Djohns (01-12-2017)
 Old 01-12-2017, 01:30 PM   #2
Will this stage 3 map work with a PTE 7685 turbo?
WetzMS3 is offline
CJ Speed6 (01-12-2017), g00s3y (01-13-2017), impossible (01-12-2017), KiwiFlavor (01-13-2017)
 Old 01-12-2017, 01:43 PM   #3
hehe sorry no, but that sounds like a lot of fun!
Mike @ COBB
 Old 01-12-2017, 02:51 PM   #4
CJ Speed6's Avatar
Posts: 443   (View Stats)
CJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the worldCJ Speed6 is the leader of the world
Did you buy Austins set up????
2006 Speed6- Versatune Tuned by Phate on e85 blend,Cobb Intake, Catless Downpipe, QTP Exhaust Cutout, HKS SSQIV BOV, HPFP, Tein Lowering Springs, Riced Out LED Tail lights, Moog Endlinks, RX8 Wheels, 5% tint all around
BNR S3 install coming soon.
CJ Speed6 is offline
 Old 01-12-2017, 02:54 PM   #5
Naw. His EFR isn't even that big.
WetzMS3 is offline
 Old 01-12-2017, 05:06 PM   #6
Correct. The biggest one is tiny compared to a 7685. You must be going for 4 digits.
Mike @ COBB
 Old 01-12-2017, 05:08 PM   #7
Mike @ COBB
Naw, just joking around with you cause I don't know what stage 3 is. Lol
WetzMS3 is offline
Cobb Tuning (01-13-2017), KiwiFlavor (01-13-2017), monkey.bones.007 (01-12-2017)
 Old 01-12-2017, 01:55 PM   #8
davros's Avatar
Posts: 1,021   (View Stats)
davros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the world
Much over boost when its cold as shit here.... Ugh.
2009 Metro Gray Mica Mazdaspeed 3
Cobb AP - HTP INTAKE - HKS BPV - GrimmSpeed EBCS - Autotech HPFP - ATP catless DP - JBR EGR full delete - Damon RMM PMM TMM- TR8/CX Piping - Damon Catch Can - FREEKTUNED
davros is offline
 Old 01-12-2017, 01:58 PM   #9
Do you have a COBB stage 2 or 3 setup? Let me know what you have and hopefully one of the updated maps can help!
edit: I just saw the mods mentioned in your signature. With your combination of the catless downpipe, upgraded intake, unfortunately the stock turbo is likely to experience significant boost creep especially in the cold, and there's only so much you can do about that in the tune. The new OTS files are only designed for use with a COBB catted downpipe, but they do have the ability to bring the boost controller all the way down to 0% duty cycle (off), if necessary, in order to counteract boost creep. Since boost creep is a mechanically induced condition, it can only be truly fixed mechanically. Tuning can only band-aid it some. Switching to a catted downpipe helps some, porting the wastegate outlet on the turbine housing can help some, reinstalling a stock cat back reduces boost creep as well to give you a few ideas. Worst case, you could always move away from cold weather as I did.
davros likes this.
 Old 01-12-2017, 01:59 PM   #10
davros's Avatar
Lol true. Ya I have a very very modded stage 3ish map. But, will go custom time in the spring. I'll just keep my foot out of it for a while longer as i usually do.
davros is offline
 Old 01-12-2017, 02:09 PM   #11
Emailed you back.
Mike @ COBB
davros likes this.
 Old 01-12-2017, 02:35 PM   #12
nindoja's Avatar
Posts: 2,395   (View Stats)
Are you basically allowing the ECU to pull 100% WGDC in overboost conditions, or is there new logic being introduced to support this?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
nindoja is offline
 Old 01-12-2017, 02:36 PM   #13
New calibration values in a few tables, existing logic.
 Old 01-12-2017, 10:11 PM   #14
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Stage 3?
monkey.bones.007 is offline
 Old 01-13-2017, 12:17 AM   #15
That's only 2 stars
Sent from my Pixel XL
MS3Shadow is offline
KiwiFlavor (01-13-2017), monkey.bones.007 (01-13-2017)
 Old 02-07-2017, 02:36 PM   #16
Beta testing complete. Thanks!
Closed Thread
COBB BETA MAPS! bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 51 05-20-2010 10:47 AM
Looking for old v1.03 beta maps Stan-O MazdaSpeed 3/6 - ECU Computer Tuning 12 03-13-2009 10:30 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
8 10-15-2008 06:48 AM
Page generated in 0.37600 seconds with 26 queries
