> Cobb Tuning >
Cobb Access Port/Maps
 Old 09-23-2008, 01:41 PM   #1
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
Default CEL ON A BETA MAP
testing out the last stage 1 Christian sent me (stage1 ms cai 103b) and I got a PO234 CEL overboost, but I got a new one ABS (cannot remember the numbers) and like a dumbfuck I cleared it without wrtiting it down.
Anyone familiar with that ABS CEL, and please dont say its the brakes...
 Old 09-23-2008, 01:43 PM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
weird, did you spin the wheels like crazy or anything
 Old 09-23-2008, 01:44 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
no, its not abs related, its an engine CEL...if you look at the batches of beta testing Christian mentions ABS....just dont know what it stands for
 Old 09-23-2008, 01:45 PM   #4
aaronc7's Avatar
Groans: 370
absolute throttle position?
 Old 09-23-2008, 01:46 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
heres a copy of an email, parts anyways
MAF Batch 2:
RPM
AbsTPS
Mass Air Flow Sensor
LTFTB1
MAF Volts
MAF Batch 3:
RPM
AbsTPS
STFTB1
LTFTB1
MAF Volts
dont know what it is
 Old 09-23-2008, 01:47 PM   #6
aaronc7's Avatar
Groans: 370
absTPS is absolute throttle position. if the CEL said ABS i would assume it means related to the abs system
 Old 09-23-2008, 01:48 PM   #7
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
so you are still getting overboost?
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
 Old 09-23-2008, 01:50 PM   #8
aaronc7's Avatar
Groans: 370
I dont get the overboost code. Isnt boost cut supposed to prevent it? I got the overboost code was...just driving around town out of boost, lol
 Old 09-23-2008, 01:50 PM   #9
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well I hit it yesterday at the top of 3rd racing a modded sti, like someone slapped me with a turkey leg. I doubt that its wheel speed related, has to be some engine function.....then again who knows.
 Old 09-23-2008, 01:56 PM   #10
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
this version doesnt overboost as much, I only have 75 miles on the map, knock is best its ever been, afr 11.5, LTFTs still moving so holding off for now, boost builds from 16 at4k to 16.5 at 4.5k 17+ at 5k and building more as it climbs....so the boost is there....keep in mind I have NEVER seen more than 16.2 in stock, and all other stage 1 were lower.
I dont want to post a full report yet because I am still settling the map..... but it looks decent.....a little of the low end grunt was taken away....but top end looks just as strong
 Old 09-23-2008, 02:14 PM   #11
smakdown61's Avatar
Posts: 1,069   (View Stats)
Its possible that excessive wheelspin could trigger the ABS light. When I had my car on a dynojet the ABS light came on apparently because the speeds of the front and back wheels were too far apart. It went off as soon as I started rolling all 4 again.
smakdown61 is offline   Reply With Quote
 Old 09-23-2008, 02:20 PM   #12
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
I was at the top of third...if I had wheelspin then I would never be heard from again!!!
 Old 09-23-2008, 06:44 PM   #13
Boother's Avatar
Posts: 139   (View Stats)
Boother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant future
I just got two CEL's on the Stage 1+ Beta.
P2188 and U2064
Too rich at idle and warning indicator from another module. Will be discussing with Christian tomorrow.
Boother is offline   Reply With Quote
 Old 09-23-2008, 07:38 PM   #14
speed_3's Avatar
Posts: 345   (View Stats)
speed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant future
i got a p0234 the otherday on a non beta map i found a loose cold pipe boost hose. Check your clamps you never know.
2007 silver ms3
speed_3 is offline   Reply With Quote
 Old 09-24-2008, 10:56 AM   #15
Boother's Avatar
Christian has sent me a new Stage 1+SF map to try. He is sending me +SF maps to be used with the CPE intake, which goes against what we had done previously on V1.00-1.02.....
 Old 09-26-2008, 07:20 AM   #16
brecker's Avatar
Posts: 121   (View Stats)
brecker will become famous soon enoughbrecker will become famous soon enough
Lenny.. I had the CEL come on yesterday. When I read the codes there were around 5 different numbers. I ended up clearing them to see if they repeat - if they do I'll post the info..
brecker is offline   Reply With Quote
 Old 09-26-2008, 06:25 PM   #17
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
the oberboost condition is easily explained...the ABS I believe is a surge in voltage that for some reason drops volts at the power supply for that circuit..... it has nothing to do whit wheelspin..it happened at 5500-6k in third gear...no way I am spinning then.....I wish.
Windows Vista/XP 64 Bit/MAC OSX Users Beta Test Haltech MazdaSpeed 3/6 - ECU Computer Tuning 49 02-02-2009 10:07 AM
MSD DashHawk V2.5 Beta 9 Download Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 27 12-02-2008 10:37 PM
I beta tested AP mazdaspeedjay
113 05-30-2008 01:26 PM
Page generated in 0.34213 seconds with 26 queries
