> Cobb Tuning >
Cobb Access Port/Maps
 Old 06-06-2011, 08:17 PM   #1
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Default AP wont load maps
Uploaded a new map to my ap.. It was opened first in atr and re-saved. Everything i have done dozens of times before.. But when i plug it into my car it won't load any maps..
I click tune then change map and it says "communicating with ecu" then "loading and verifying map files" then just gets stuck on the cobb logo..
I have unplugged everything a few times, deleted and re-loaded the map, same thing..
I could uninstall the ap, but im worried about not being able to load anything back on..
Im sure this has happened to someone else at some point..
Any ideas?
p.s i searched and couldn't find anything..
Thanks in advance.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
 Old 06-07-2011, 11:27 AM   #2
801MS3's Avatar
Groans: 30
Anyone? could it be from conflicting ATR versions?
 Old 06-09-2011, 05:45 PM   #3
Travis@Cobb
Lurkers
Travis@Cobb's Avatar
Posts: n/a
Did you recently update your version of AccessTUNER Race? What version is your AccessPORT is it a v2 with the silver OBDII connector/dongle or is it the v2b with the black cable? If its a dongle style, try a new USB cable. That might be the issue there. If its the black cable, it may be a fault with the cable itself. Are you able to flash on OTS mapping? My guess is that this is an issue with the AP and not the maps. Does datalogging or any other featues not work?
Travis
COBB Tuning
 Old 12-01-2012, 11:45 AM   #4
Danwelford's Avatar
Posts: 24   (View Stats)
Danwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to all
Did anyone find an issue for this as I'm having same problem. It just won't let me load maps or even view a map to load. I just get a blank screen the after a few attempts says contact support?
I am able to set it up to take logs which is strange??
Cobb AP / CS Tip & Sri /Sure Flow M3 /Solid Shifter Bushes / SSP / REM Inserts / Forge BPV
Danwelford is offline   Reply With Quote
 Old 09-22-2013, 08:22 PM   #5
OCspeed's Avatar
Posts: 168   (View Stats)
OCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond repute
Groaned at 7 Times in 5 Posts
the EXACT same thing is happening to me at the moment...any input? I flashed a new map like 2 days ago and today this happens? Did anyone figure it out?
Self Tuned: 310 HP / 355 TQ on E85 50/50
2012 black speed3 - AP - CxRacing FMIC - COBB SF - COBB TIP - Ebay catless long DP - XS Power Exhaust Manifold - ARK CBE - AutoTech internals - Rotella T6 - JBR 88 Duro RMM - JBR MudFlaps - DevilsOwn M.I. - GFB Respons 50/50 - AEM DryFlow - NGK Step Colder
Instagram @ mpodboj
www.matiaspodbojracing.yolasite.com
OCspeed is offline   Reply With Quote
 Old 10-11-2013, 05:34 PM   #6
Vegasspeeed's Avatar
Posts: 274   (View Stats)
Vegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond repute
Groaned at 8 Times in 7 Posts
ANY ANSWERS? must be the updated version of ATR or APTUNER fucking up cuz the same exact thing is happening to me..without the map from ATR on the ap I can load maps but with it on the ap i get stuck on the loading screen
sure test pipe, both resonators deleted, RL coilovers, XXR 521's machined silver, muteki gold lug nuts
Vegasspeeed is offline   Reply With Quote
Cobb AP, greyed out maps, can't load - WTF flyrevs2 MazdaSpeed 3/6 - ECU Computer Tuning 8 03-07-2013 09:13 PM
Cobb AP Wont work car wont start boosted_speed6 Mazdaspeed3/6 General Discussion 30 05-09-2011 11:11 PM
Is my Cobb Ap married even if I didn't load any maps on it anubis-mzd6 MazdaSpeed 3/6 - ECU Computer Tuning 7 11-24-2009 08:40 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
8 10-15-2008 06:48 AM
17x9's wont fit? Laloosh Mazdaspeed3/6 General Discussion 43 08-01-2008 10:09 AM
Page generated in 0.27090 seconds with 23 queries
