> Cobb Tuning >
Cobb Access Port/Maps
 Old 11-29-2013, 12:09 PM   #1
AlexanderLEE_MS3's Avatar
Posts: 19   (View Stats)
AlexanderLEE_MS3 can only hope to improve
Groaned at 18 Times in 6 Posts
Default New to this whole AP thing
So i am looking into getting an AP. But i am the biggest newb when it comes to "logging" and tuning. I just need to know what all you need to do when installing it and how you should go about doing it. Do i just plug it in, save my stock map, then choose a map that i think will fit my mods accordingly?
Just a clear explanation on how i should go about running the logs, which map to get.
My mods include a Forge BPV, CBE, and SRI
Thanks in advance for any input.
AlexanderLEE_MS3 is offline   Reply With Quote
 Old 11-29-2013, 12:51 PM   #2
shamie's Avatar
Posts: 952   (View Stats)
Just go here;
Accessport Off The Shelf Maps
or here;
Maps-Archives
and pick the map that's closest to your mods. I can't pick for you since your speed's year is a mystery.
The Following User Says Thank You to shamie For This Useful Post:
Mase (11-29-2013)
 Old 11-29-2013, 01:07 PM   #3
Its a 08
 Old 11-29-2013, 01:34 PM   #4
shamie's Avatar
Just select from the '08 archive Stage 1 for whatever your SRI is and what gas you can get - 91 or 93.
 Old 11-29-2013, 01:36 PM   #5
pharaoh313's Avatar
Posts: 120   (View Stats)
pharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the world
youtube also has some good how to vids'
pharaoh313 is offline   Reply With Quote
 Old 11-29-2013, 03:08 PM   #6
okay i will look up those thanks.
i also wanted to ask what "logging" was too. i mean i hear people saying they "logged" with this on or that or whatever and im lost with that.
 Old 11-29-2013, 03:26 PM   #7
pharaoh313's Avatar
think of a black box in a plane* it basicly means ur recording what ur motor did.....You just need to pick "what parameters" you want you AP to record (log) e.g. afr, timeing, boost levels etc
hope this helps
 Old 11-29-2013, 03:28 PM   #8
Thank you for being helpful. I'm not going to get any more in depth for fear of getting yelled at for not go ogling. I will Google the rest of my questions.
 Old 11-29-2013, 03:20 PM   #9
MADDOG 20/20's Avatar
Posts: 251   (View Stats)
MADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the worldMADDOG 20/20 is the leader of the world
Let me google that for you
2012 Black MS3
Cobb AP, CS SRI//TIP, AT FP Internals, JBR Wishbone RMM, CP-E TMIC, UR Catless Test Pipe.
Pirate Pu - Fog light mod.
"Karma doesn't have Turbo Lag."
MADDOG 20/20 is offline   Reply With Quote
The Following User Says Thank You to MADDOG 20/20 For This Useful Post:
Onelovesoccer (11-29-2013)
 Old 11-29-2013, 03:31 PM   #10
Searching youtube for access port how to log would also probably answer a lot of your questions.
2012 Black MS3
Page generated in 0.29652 seconds with 23 queries
