> Cobb Tuning >
Cobb Access Port/Maps
 Old 03-15-2011, 02:26 PM   #1
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
Default Please take a look at my first ever logs
Hey guys, I did my very first data logs today. I currently am running a stage 1 + SF 93 V108 map. Only mod that matters is my sure intake. These arent the best logs ever (I ran out of road) but I have essentially 0 tunning knowledge so I would appreciate your feedback.
From what I know fuel pressure seems OK? It doesn't dip bellow 1500, I think thats the cutoff people have been using?
Some KR.....thoughts?
Also when im cruising I see high KR from time to time of 6's and 7's im not sure what that means. My understanding is KR during WOT is what matters. I will do some cruising logs.
If everything seems safe my next step is to calibrate the MAF.
Thanks for taking a look
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
 Old 03-15-2011, 02:45 PM   #2
R.MS3's Avatar
Posts: 987   (View Stats)
R.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the world
Boost is a little low, AFR is a little lean, Fuel pressure looks good, WG looks good, a bit of KR but that's probably because of the lean AFR.
The KR at cruising is not to worry about it. The more you cruise on the map, the less it will happen.
Need to calibrate MAF to make the AFR's a little richer and tweak your tune using ATR. Look at the stickies under the COBB ATR section to help you with these tweaks.
R.MS3 is offline   Reply With Quote
The Following User Says Thank You to R.MS3 For This Useful Post:
kunfu (03-15-2011)
 Old 03-15-2011, 07:09 PM   #3
kunfu's Avatar
Groans: 56
Thanks R.MS3....anyone have anything to add?
Speed 3 2007:
Can someone please look at these logs bcmurphy87 MazdaSpeed 3/6 - ECU Computer Tuning 2 12-26-2010 10:42 PM
ATR 1.8.6.0 Before and After Logs hnda etr MazdaSpeed 3/6 - ECU Computer Tuning 174 12-13-2010 02:56 AM
Take a look at my AP logs? supraman MazdaSpeed 3/6 - ECU Computer Tuning 6 11-26-2010 05:06 PM
AP logs SRTie4k MazdaSpeed 3/6 - ECU Computer Tuning 24 11-12-2010 09:34 AM
AP LOGS RGV_MS3
Cobb ATR Support
3 07-31-2009 09:47 AM
Page generated in 0.24151 seconds with 22 queries
