> Cobb Tuning >
Cobb Access Port/Maps
 Old 08-16-2017, 10:27 AM   #1
Posts: 2,233   (View Stats)
Do the stage 0 mode first and get the car up and running well without mods. ( putting back the stock downpipe may be enough to restore a near stock restriction + stock BPV to seal the boost lines correctly)
Put back the stock tune and make it run as it should from the factory.
You may have more than 1 issue if you don't know anything about the historic of the car...the engine may have something, the wiring could have been tempered with etc........
There is tons of possibility...
Is the engine timing fine/VVT, chain, crank sprocket and crank sensor? When was it last replaced ?
Do the intake valves are cleans in the head or completely clogged by oil and EGR?
Do the VTCS works well to open the second set of runners ?
Do the turbo/wastegate/EBCS is fine. Is the turbo wheel loose on the bushing? Is it still a K04 from a speed engine ?
Is the fuel pressure fine ?
Do all sensors signals returns a correct reading in the logs ?
How does this 3rd Gear pull look?? Kiwipaulie MazdaSpeed 3/6 - ECU Computer Tuning 8 12-16-2013 04:50 PM
3rd Gear Pull on Stratified OTS Stage 2 Map therza2169 Stratified Automotive Controls 2 07-11-2013 06:42 PM
stage 1 1st-3rd pull chintastic Gen2 MS3 General Discussion 5 11-05-2011 07:11 PM
Stage 2 OTS 3rd gear pull mrFanel 2010 MS3 - ECU Computer Tuning 32 05-19-2011 12:29 AM
3rd gear pull log cageyvet MazdaSpeed 3/6 - Big Turbo Builds 2 11-27-2010 07:39 PM
Page generated in 0.22882 seconds with 22 queries
