> Cobb Tuning >
Cobb Access Port/Maps
 Old 06-02-2019, 07:17 PM   #1
CA_MS3's Avatar
Posts: 22   (View Stats)
CA_MS3 has a spectacular aura aboutCA_MS3 has a spectacular aura about
Default Stage 0 (Emulation of Stock) Map Stronger than Stage 1?
I installed an Accessport v3 on my 2011 Mazdaspeed 3 last weekend. The car has 65k miles, has been well-maintained, and is in essentially stock configuration. The only engine modification is a Cobb cat-back exhaust. I loaded the Stage 1 map and was shocked to find a substantial reduction in mid-range torque, from roughly 2700 to 4500rpm. It almost felt like a safe mode, but no trouble codes were thrown. I drove it for a week like this, figuring the ECU might “learn” and improve, but it did not. Loading the Stage 0 map yesterday brought back the power and seemed to resolve the issue.
Does this seem like a normal response for a stock car?
Has anyone else experienced something like this?
CA_MS3 is offline   Reply With Quote
 Old 06-02-2019, 07:47 PM   #2
Police - Grammarhead
Vansquish's Avatar
Yes. Cobb's off-the-shelf maps are atrocious, neutered, and calibrated to try and be "safe" on any car to which they're installed. You need a tune customized for your modifications by a professional tuner.
CA_MS3 (06-02-2019)
 Old 06-02-2019, 11:24 PM   #3
CA_MS3's Avatar
Thanks, I appreciate the feedback.
 Old 06-03-2019, 07:19 AM   #4
Posts: 2,233   (View Stats)
you may datalog both tune and compare data to see what is going on. You may post it here and we will take a look...
As stated above these tunes are not the best but did you make sure you got the proper one based on what is listed from Cobb website?
I don't know all details about them but if you flash a tune made for a slightly larger intake and still have the oem, it may read higher load values and choke your car power a bit....
Back in time, i remember the biggest change i did notice with stage 1 was removing the boost limit of first and second gears without much feeling of power gains but it was 10 years ago lol.....
Stage 1, Stage 2, and Stage 3 Dual OCC kits Matt@DamondMotorsports Damond Motorsports 0 11-10-2015 04:09 PM
Stock using - Stage 0 vs. Stage 1 vs. Stage 2 BAT-man MazdaSpeed 3/6 - ECU Computer Tuning 30 12-20-2012 08:51 AM
Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences bast525
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.26167 seconds with 22 queries
